Blinking power light fix for DVP642 DVD Player
  • rmg_hrr
    • Mar 2012
    • 27
    • India
    #61
    Re: Blinking power light fix for DVP642 DVD Player
    Hi SellDoor,
    Also can you please let me know any reason why the Vibratto Chip ( ES6698FD) is over heating quickly on other circuit board.
    Is this how it work on normal DVP642?
    Also there is some green marking on top of C805 100uf 10V but no bulging.
    What are these markings for?
    • selldoor
      Slow Learner
      • Dec 2010
      • 7870
      #62
      I know nothing about this player the chip may normally run hot - is there space to add a heatsink? Check out a datasheet for it - may give an indication of running temperature. If the caps are not doing their job correctly the voltage regulators may have a problem keeping the voltage steady with the knock on effect of overheating the chip with overvoltage which might be picked up as an error causing the shut down.
      Without pictures it is difficult to comment - could the board have been worked on before?
      I believe they do some checking when boards are assembled and it may just be a mark to show a voltage check has been carried out at that cap.
      • rmg_hrr
        • Mar 2012
        • 27
        • India
        #63
        Found schematic here
        It plays for just a minute and then goes to standby and suddenly the 5 volt decreases to 2-3 V and 12 V decreases to 8V in standby.
        I am desperate. This is second electronic Item which gone bad in a matter of few months be cause of Capacitors issues, first one being 2043NWX monitor .
        But neither of these are working even after I replace the CAPS.
        • rmg_hrr
          • Mar 2012
          • 27
          • India
          #64
          Now its not turning on atll, just Blinking LED.
          12v and 5 v pins oscillates between 5-3 and 2.5-1.5 respectively.
          Already replaced C316 with 1000uf 16v
          • keithl
            • Mar 2013
            • US
            #65
            The C316 cap fixed worked for me. I pulled the 1000uF/10V "TBOR" brand cap, and measured it at 110uF instead of 1000uF (which shows how bad it can get before it actually fails). I replaced it with a 920uF/12V cap out of my random capacitor stash (which measured at 1020uF, good enough) and the player is working OK so far.
            What's funny about this is that one of the first switchers I ever fixed was in one of the early Sun Microsystems "pizza box" workstations, back in 1990 or so. I posted a description of the diagnosis and repair on usenet, possibly the first on the internet, before there was a world wide web. I got email questions about that post for almost 20 years, from PC power supplies through laptops and consumer goods. It is way cool that there are forums like this, where we are all helping each other now.
            Thanks for the suggestion, it let me know that the fix was simple enough to do in 30 minutes (mostly opening and closing the case).
            • YasaCh
              Sony kdl 40p5500 red light keeps blinking 3 times
              by YasaCh
              Hello...
              my tv almost 2 years not powerd on and when i turned it on nothing happened and only 3 red light keeps blinking
              i opened the back cover no sign of damage on the powery suply or motherboard
              when i plug in the power i hear the reley sound like tik first and another tik..after that only red keep blinking..
              another thing is even after i unplugged the power, The tv keeps red blinking 3 times for 2 almost 2 munites
              07-07-2025, 11:53 AM
            • Fergal22
              Samsung UE40F5300AK blinking red light
              by Fergal22
              I have the above tv that just shows a red light blinking twice 5 times, i have taken the back off and all the capacitors seem ok,
              When i disconnect the mainboard from the PSU all the led's light up blinking fast but as soon as i reconnect the mainboard back to the power supply i get the red light blinking again twice 5 times,
              I have attached pictures of the Mainboard, PSU and a small video (zipped) showing what happens when i disconnect the lead from the psu
              Any help would be appreciated...
              02-02-2023, 09:19 AM
            • norbiszoke
              Samsung 50AU7172, only blinking red light
              by norbiszoke
              We have this set here in our shop that is not ginving sign of life besides red light that is blinking one time after pressing the button and nothing more... After detaching the mainboard from the PSU (this set has separate board thank god?! or not...) the backlight comes on. After reattaching nothing besides red light.... Can anyone from the forum help me here? Thank you in advance. Here's a link with images of the mainboard and the memory IC's that are on it.
              Regards, Norbert!...
              04-17-2024, 06:54 AM
            • matty24
              Samsung UE50MU6172 - red light blinking
              by matty24
              Hello. I have problem with Samsung UE50MU6172.
              TV won't turn on, red standby light is blinking.
              Power supply BN44-00807A is fine. I replaced it with the new one.​
              Main board BN41-02568B (BN94-12530E)
              I've read a dump (W25Q40CL). Can someone check it od fix it for me?...
              03-02-2025, 08:57 AM
            • huzo
              HP 470 G5 blinking amber light no power
              by huzo
              The board is daox8cmb6eo and i can't find no boardview or schematics on the forum or anywhere...
              So i plug in the charger, amber light starts blinking ,there is 3.3V and 5V present, and 2.4V on the power button,board doesn't turn on, no shorts...
              I've tried flashing the bios...
              interesting thing is the battery was around 7,8V, and it's 11.1V battery, the mosfet near the battery is open, but not charging,i desoldered it,tested it and it's fine ,but the amber light kept going on the charger so i charged the battery with power supply and got it to about 10.5V...
              06-08-2023, 04:08 PM
