Is this screen cracked?
  • Storyteller12
    • Jun 2020
    • 625
    I've never seen a screen cracked like this and still have a perfect picture.
    Maybe it's the diffuser cracked like on some of the Samsung NU series.
    Just curious what you guys think. TV is for sale in my area and thinking of maybe trying my luck.
    Wanted some other opinions before I pull the trigger
  • ajshoe
    ajshoe
    • Dec 2012
    • 477
    • usa
    Re: Is this screen cracked?
    posting this without a model # and asking for help ? screen is definitely cracked. Odd - yes but tv is still use-able. depends what your using it for. Not fixable
    • Storyteller12
      • Jun 2020
      • 625
      I don’t have the model #. It’s an 8K TV. That’s all I know.
      How can you be sure it’s not the diffuser?
      • Diah
        • Feb 2013
        • 6582
        its crack at the 3rd layer of the LCD. cells will remain displaying color as it should . the crack will be more noticeable at black / dark picture.
        one time i did 55 repaired BL and at time put panel back its curved and the same crack happened at the middle. but Panel remain displaying full picture over the crack.
        • Davi.p
          Hobbist Tech
          • Sep 2009
          • 4540
          • Italy - Milan
          I suspect it has a front covering hard sheet like gorilla glass but it broke.. don't buy this unless you know a company that replaces it.. you can see it by the boubble near the crack, maybe it craked because of a temperature shock, the screen glass has maybe a different dilatation factor..
          • Storyteller12
            • Jun 2020
            • 625
            Thanks for everyone’s input. Appreciate it
              • 12330
              • U.S.
              Would make a nice big security monitor for the vision impaired, even for regular vision people, nice to have a big screen for split screen viewing from multiple cameras.
              • Ryan.man
                by Ryan.man
                02-04-2025, 12:23 PM
              • reformatt
                by reformatt
                07-31-2025, 08:37 PM
              • Chrissygizmo
                by Chrissygizmo
                02-10-2025, 12:33 AM
              • spice_disc
                Vizio TV M50-C1 reboot cycle and static on screen
                by spice_disc
                I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
                The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
                09-08-2024, 02:37 PM
              • ipatch
                ipad pro 9.7" blew a SMD component while replacing the screen 🤦‍♂️
                by ipatch
                i have an ipad pro 9.7" (1st gen) A1674 where i replaced the screen, but never attached the screen to the frame/chassis (glued down) due to the ipad being previously dropped so the new screen would never fit in the frame properly. so i need flex/bend the chassis to eventually fix the new screen in properly. so i temporarily just applied blue tape around the edges of the screen to keep it in place. when watching videos with the ipad the screen started flicker, so i though maybe the new quasi cheap amz screen i purchased was going out. so i disconnected then reconnected with power still on,...
                08-24-2024, 02:36 PM
