Black spot and vertical lines on Sony KD-55x9300C
  • syedshueeb@gmail.com
    • Mar 2023
    • 6
    • india
    Can experts please share their opinion on this issue where i have a black spot and vertical lines all over the screen.
    Is this fixable or needs a new panel?
  • diif
    • Feb 2014
    • 6978
    • England
    Re: Black spot and vertical lines on Sony KD-55x9300C
    Yes, new panel required.
      • Mar 2023
      • 6
      • india
      Any specific reason to why the panel cof bonding will not fix the issue.
      • diif
        • Feb 2014
        • 6978
        • England
        The black spot indicates the panel is damaged.
        • dan8139
          • Jul 2004
          • 57
          Did something happen to that part of the screen?
          • Davi.p
            Hobbist Tech
            • Sep 2009
            • 4539
            • Italy - Milan
            not fixable, sell the boards, or... if the device is less than 2 years old you can hope for a warranty substitution
              • Mar 2023
              • 6
              • india
              No impact at all, just normal usage
              • visionbluedemon
                Help. Sony kd-65x85dj vertical lines
                by visionbluedemon
                First. it has no picture at all. i solved it by covering the ckv lines using tape to to block the connections
                Second. now has picture but with vertical lines that follow the image. tcon board ic overheating
                tried blocking LC lines too, but same results
                is it lcd panel issue or tcon board issue?...
                07-25-2025, 04:56 AM
              • gpo23
                Sony KDL-40V3000 - Vertical lines
                by gpo23
                i order a t-con because i had bad colors on my SONY KDL-40V3000 :
                With the new t-con the color are good but there are vertical lines on all the screen :
                I've tried the old t-con and it returned to the initial issue (bad colors but no vertical lines)
                Is there a way to fix the vertical lines on the new t-con ?
                Thank you for your help
                gpo23...
                10-04-2023, 09:11 AM
              • Firentiosi
                1/3rd of screen black with occasional vertical lines - repair attempt for learning! - Kogan KALED58RT9220SVA
                by Firentiosi
                Thanks for offering your assistance with this. I'm an electronics enthusiast with moderate level of competence (have a decent lab with two power supplies, microscope, DSO, hot air, good iron, can competently work at a component level on SMDs, design and solder own PCBs etc). I really enjoying fixing things and learning new stuff so took up a free 58" LED TV and have been googling and watching Youtube videos to see if I can fix this! I am happy to go down to individual component replacement/strip replacement etc - it's all in the name of learning.
                The issues are as follows: the...
                11-27-2024, 12:33 AM
              • Stanley1843
                by Stanley1843
                06-29-2024, 11:54 AM
              • noisykid
                Sony XBR-85X950G Gray horizontal lines and vertical picture shift diagnosis?
                by noisykid
                5.5 year old 85 inch Sony Bravia X950G started showing gray horizontal lines across the bottom of the screen and the picture shifts slightly vertically when it happens. The lines sometimes get bigger/smaller vertically and bounce back. See the video for the problem. It seems to be happening after it warms up after an hour or so. Happens regardless of source. Right now there's nothing but power cable connected and it's happening. We did hook up a new Nintendo Switch to our HDMI switching receiver today, and played for a while with no issues, but this problem didn't occur til a few hours later while...
                12-30-2024, 07:15 PM
