Philps QLED Q60B Model:QE65Q60BAU
  • Diah
    • Feb 2013
    • 6614
    Re: Philps QLED Q60B Model:QE65Q60BAU
    this is android 8 upgrade_loader firmware QM163E_U_0.26.70.1 –Date: 2021/03/05 --. usb stick should formatted in MBR mode FAT32
    • Maalobs
      • Jun 2016
      • 120
      • Sweden
      For reference, you can download the service manual from this page:
      https://www.electronica-pt.com/esque...ileinfo/37202/
      • bohaboha
        • Nov 2012
        • 1047
        • sweden
        I am very grateful for all the help that you pour on me. As Diah has written "its look there are issue at LED BL so some of logo dim" therefore Davi.p I will try to update first as Iotas,Diah and Maalobs have suggested to give it a go and then try your suggestion .I will search for a usb stick. but I don't know and can't see which version is already on tv because I think you have to have a newer version . Or do you know a way to shine out which version is already installed? I don't know how to make multiple "Quote"
        • Diah
          • Feb 2013
          • 6614
          never never play firmware before you repair the BL. other wise you will kill the main boards, because of shutting down protection active right now.
          i just linked the firmware to be under your hands for future not for repairing right now
          • bohaboha
            • Nov 2012
            • 1047
            • sweden
            ok thank you
            ok thank you then it's to start with Davi.p suggestions and then try to repair the BL and it may not be anything difficult to fix if you are lucky
            • Diah
              • Feb 2013
              • 6614
              Originally posted by bohaboha
              ok thank you
              he is wrong and don't know what he talking about... don't follow any... go head to repair BL only
                • 12323
                • U.S.
                #27
                What am I looking at in the first picture? is the back cover in 2 sections, what is leaning on the wall? also clean out the dust on powerboard, dust can be a killer.
                  • 12323
                  • U.S.
                  #28
                  Any progress on that video?: https://www.google.com/search?client...o+post+a+video
                  • Davi.p
                    Hobbist Tech
                    • Sep 2009
                    • 4546
                    • Italy - Milan
                    #29
                    The same battle against the same users, i repeat my suggestion, backlight fault and software fault are isolated and you can decide which one to repair first, this is an overvoltage damaged tv, since this is a giant tv and replacing leds is not comfortable i was suggesting to ensure first the led problem is present by starting a tcon auto test with jumpering, but if you find the usb update its ok to start with it so you have a full image to judge the BL state.. i'm tired of the mad deutch Diah and the other one behaviour, decide yourself to which one give listening to.. bye..
                    PS: you don't have to know the actual version of sw, if the update takes place then you have a lower version, normally an update fails if version is same or newer, Lotas states this is a service update so it's different and must take always place i guess, get usually a 4gb max key and try.. do not hesitate..
                    • Diah
                      • Feb 2013
                      • 6614
                      i wrote to you at other threat,, don't spread wrong info caused other TV more damage.. read and learn.
                      upgrade_loader firmware for ANDROID OR NATIVE LINUX can be used any time to downgrade or upgrade.... so again you are wrong and don't know what are you talking about.
                      i am acting here and there only to protect people to being victim of wrong advice. and not against you or other...so stop and learn.
                        • 12323
                        • U.S.
                        #31
                        +1000, davi really needs to stop trying to make people try his little experiments on their tvs.
                        • bohaboha
                          • Nov 2012
                          • 1047
                          • sweden
                          #32
                          It is quite clear that there are problems with the backlight . and the tv is big and heavy to handle i will order bl kit and do everything at the same time otherwise there is risk that something will break. Now it has changed behavior because it now responds to the remote I can turn it on and off with it and the light in the back cover changes color to pink/red steadily but the TV itself starts trying to boot over and over again. have taken some measurements of CN9101/9102 the 5V= 3.2V the 12V was ok. But we'll see afterwards a question can you trust eBay for this ? plus please is there anyone who can modifie the title of this thread so that it will be right
                          • Davi.p
                            Hobbist Tech
                            • Sep 2009
                            • 4546
                            • Italy - Milan
                            #33
                            don't worry about the title, have you found the file Lotas is talking about? Lotas is one of the masters here you can trust him, i can assure you that *never* an official update software can ruin a tv except if a power outage happens in those few minutes but is a risk you can run.. i feel stupid to spend money on parts when after this you aren't able to fix the software, historically Philips spare main boards are rare as a white fly, Maalobs that is a Philips expert can confirm you, so whitout eproms/flash direct reprogramming skills/devices your chance of fixing the sw is not as high, in 13 years of studying tv problems i've never seen an lcd tv that blocks on the start logo due to bad backlight only, so someone here heavily needs an holday well far.. it has no sense because if the sw would block itself is for bl totally stopping in a protection state like Sony and Sharp does, you would see a blinking led and stop...
                            • bohaboha
                              • Nov 2012
                              • 1047
                              • sweden
                              #34
                              i search still haven't found lotas file can you help me find it.because sure i can do it first as you say
                              • Davi.p
                                Hobbist Tech
                                • Sep 2009
                                • 4546
                                • Italy - Milan
                                #35
                                Here you can find the official upgrade, i don''t know which file Lotas is talking of.. format usb in FAT, but reading the SM it seems tv must be functional, otherwise try different local keys combinations to go into recovery mode, or insert power cord while pressing OK or arrow down on remote..
                                • lotas
                                  • Jan 2016
                                  • 4909
                                  • Russia
                                  #36
                                  Official firmware will not help! What is needed is the service firmware "upgrade loader" with the extension "pkg". (upgrade_loader.pkg).
                                  • bohaboha
                                    • Nov 2012
                                    • 1047
                                    • sweden
                                    #37
                                    Hi and thanks do you have an idea where to find this file because it looks to be some especiall one
                                    • Davi.p
                                      Hobbist Tech
                                      • Sep 2009
                                      • 4546
                                      • Italy - Milan
                                      #38
                                      yes i supposed that , i'm try to find it, so since it seems a long journey to find it, i have found a list of the sofware names where there is also Lotas one, but also newer versions, i can suggest to search for those strings, but the file name i don't know which form has, maybe one can add .zip or .rar?
                                      https://cdn.badcaps-static.com/pdfs/...4c79070095.pdf
                                      PS: https://toengel.net/philipsblog/firmware-download/ << is this correct? search for year 2016
                                      have you tried the one in post#21?
                                      • lotas
                                        • Jan 2016
                                        • 4909
                                        • Russia
                                        #39
                                        In post 21, Diah gave a link to the firmware.
                                        • lotas
                                          • Jan 2016
                                          • 4909
                                          • Russia
                                          #40
                                          Android 5 Lollipop
                                          Service_QM163E_0.1.15.15_upgrade_loader
                                          autorun_QM163E_0.1.15.108
                                          Android 6 Marshmallow
                                          autorun_QM163E_000.006.152.000
                                          autorun_QM163E_R000.006.188.012
                                          autorun_QM163E_000.010.077.002
                                          Android 7 Nougat
                                          autorun_QM163E_000.015.209.001
                                          autorun_QM163E_000.015.251.001
                                          Service_QM163E_0.16.56.0_upgrade_loader
                                          autorun_QM163E_000.016.056.000
                                          Service_QM163E_0.16.102.9_upgrade_loader
                                          autorun_QM163E_000.016.102.009
                                          Android 8 Oreo
                                          autorun_QM163E_000.025.238.000
                                          Service_QM163E_0.26.17.0_upgrade_loader
                                          autorun_QM163E_000.026.017.000
                                          autorun_QM163E_000.026.039.000
                                            Samsung 13.3IN CHROMEBOOK 2 8GB/128GB FHD QLED MERCURY GRAY I3-10110U Chromebook Specification for Upgrade or Repair
                                            This specification for the Samsung 13.3IN CHROMEBOOK 2 8GB/128GB FHD QLED MERCURY GRAY I3-10110U Chromebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 13.3IN CHROMEBOOK 2 8GB/128GB FHD QLED MERCURY GRAY I3-10110U boardview and 13.3IN CHROMEBOOK 2 8GB/128GB FHD QLED MERCURY GRAY I3-10110U schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help...
                                            09-07-2024, 12:10 AM
                                          • cstout
                                            DeLonghi AC Remote only accepts 3V
                                            by cstout
                                            Hello all, I've been looking into this portable air conditioner's remote control and can't find what could be causing the problem - or possibly this remote is just terribly designed.
                                            The remote only works at exactly 3V - if I drop it any lower, using my bench power supply, to say, 2.9V then the remote will not flash the display and turn off. I don't have any AAA batteries that are exactly 1.5V each so I'm not sure if this remote is designed this way - to only use the freshest possible batteries, or if there's a failed component in the mix.
                                            I can't find any schematics...
                                            06-03-2024, 03:53 PM
                                          • Mc_Millian
                                            Toshiba 50lf711u20 fire tv remote not pairing
                                            by Mc_Millian
                                            I was wondering if anyone could help my in pairing a remote with a Toshiba fire tv?
                                            The Tv model number is: 50lf711u20 Rev B.
                                            I've already replaced all the the circuit boards within the tv along with the I.R. sensor receiver.
                                            I've tried 3 different remotes which should be fully compatible with this TV.
                                            Oddly enough. A few if the buttons on all of the remotes actually work. Even without pairing...which makes no sense.
                                            The power button, along with the volume,back,select, and directional...
                                            04-07-2022, 12:15 PM
                                          • edugimeno
                                            HiSense 55A7500F won't obbey to remote after power on
                                            by edugimeno
                                            Hi! I have this TV set that does the following:
                                            1) I press the red power button on the remote
                                            2) The TV turns on normally
                                            3) After that it won't take any other command from the remote, neither power off, volume, channel, NOTHING
                                            4) We need to either pull the main cable or use the built in button at the bottom to select funcion OFF
                                            Then after it's off, it would again accept the TURN ON from the remote and same again
                                            BUT:
                                            -The remote does show the correct IR beam while observed thru a phone camera
                                            -The TV works fine while using the MiRemote...
                                            03-14-2023, 11:22 AM
                                          • rustinjust
                                            Please help, where can I get a remote for my subwoofer?
                                            by rustinjust
                                            I’ve got a subwoofer that I’ve had for nearly 20 years, it did come with a basic remote which I’ve lost. It’s a generic make of subwoofer, I can’t see a brand sticker on it. It comes with 2 speakers.
                                            Question recently I’ve connected it up to my tv which has greatly improved the sound on my tv, however I’d like to be able to mute the subwoofer when ads come on or just mute it when the phone rings etc. I tried using a cheap all in one tv remote on the subwoofer and the volume button would only work to increase volume but not turn it down or mute it
                                            Is there...
                                            10-28-2023, 03:43 AM
