LG LCD power supply
  • Dmuggy
    • Feb 2014
    • 15
    • Uk
    Re: LG LCD power supply
    1
    • Dmuggy
      • Feb 2014
      • 15
      • Uk
      2
      • Dmuggy
        • Feb 2014
        • 15
        • Uk
        3
        • Dmuggy
          • Feb 2014
          • 15
          • Uk
          4
          • Wrog
            • Oct 2009
            • 472
            C202 and C208 look physically damaged to me, but others with better eyes may be able to tell for sure. Remember what vinceroger said though, it doesn't have to "look" bad for it to actually be bad. Unfortunately you'd need access to some test equipment to tell for sure. Since you're already replacing at least C202 and C208 (maybe more), you may as well replace them all while you're in there.
            The Samxon GK and GF series are common value low ESR, so these will be readily available. Personally, I'd ask for replacements in this order (not all values are available in every can size):
            Panasonic FR series, FM series or FC series
            The Samxon BD series (high temperature) are not low ESR, but you want to match or exceed the ripple current from the spec sheet. For the 1000uf 25v, the ripple current is 575 but the 1000uf 50v looks like it's custom (no spec sheet available). Suitable replacements with these characteristics may be UCC GPA series or Nichicon BW or BX series. The UCC has the highest ripple current at 2.62A, but any should work fine.
            Good luck!
            • selldoor
              Slow Learner
              • 7870
              #26
              Id agree 202 and 208 are bad, also the one to the right of 208 ,others dont show signs yet. I had a quick look and cpc dont seem to have high temp caps in those values personally Id just use the panasonics. Another snag is they sometimes only sell in packs of 5 so if you only need 1 its sometimes worth looking at Rubycon -they are sometimes a few p dearer but if you can buy singly they work out cheaper. ( unless you are going to make a habit of mending things and want to build up a stock )
              Also when you come to taking the boards out give them a good dust - nice cosy jacket helps the components overheat
                by sam_sam_sam
                03-31-2024, 02:12 PM
                by sam_sam_sam
                After all of...
                07-13-2024, 08:14 PM
                by sam_sam_sam
                07-01-2024, 06:34 AM
              • shamsudeen
                Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
                by shamsudeen
                Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
                I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
                i know that in linear power supply the noise will be very low comparing to SMPS supply....
                07-19-2025, 07:14 AM
