Hitachi 50HK6100U Screen fault?
  • Ukdigger
    • May 2020
    • 121
    • England
    I've seen this for sale, any ideas about the fault.
    • 12306
    • U.S.
    Re: Hitachi 50HK6100U Screen fault?
    It could be a bad panel, maybe something else hard to tell but from the looks I wouldn't be too optimistic, if it's bad panel it's junk, worth very little, maybe just for parts and can be hard to tell what parts may be good, in that condition.
    • Ukdigger
      • May 2020
      • 121
      • England
      The price was reduced to £15 so I bought it thinking I can sell the parts if I can't get it working. I removed the right hand side cable from the T-con board and I get a good clean half black and half white screen. If I plug and aerial in I get a slightly polorised picture but no striping. When I removed the left hand side cable from the T-con board and plug the right hand side back in, I get striping and no picture. I tried the tape trick but it didn't work. I tested all the caps on the screen buffer boards but there are no shorts. I tested the T-con board (CCPD-TC495-008 V4.0) and Vcom is 6.8v VGL is -5.8 VGH is 24v and VDD is 15.2v.
      • Ukdigger
        • May 2020
        • 121
        • England
        • Diah
          • Feb 2013
          • 6496
          show me the main boards please
          • Ukdigger
            • May 2020
            • 121
            • England
            Vestel mb 230
            Vestel 17IPS72
            • Diah
              • Feb 2013
              • 6496
              search over here the Vestel mb 230 firmware with urs panel no. its firmware issue
              my 3910 reached stay healthy
              • lotas
                • Jan 2016
                • 4803
                • Russia
                The firmware will not help, the problem is in the panel.
                  • 12306
                  • U.S.
                  maybe try tape cut-off method, can check the little mlc caps on panel driver boards for shorts or very low ohms, been over both procedures many many times here.
                  • Diah
                    • Feb 2013
                    • 6496
                    lotas .... Dont be @Davi.p No 2..
                    this is exception post... where are the fault in Panel.... show us
                    • lotas
                      • Jan 2016
                      • 4803
                      • Russia
                      The right side is not working. Let him turn off the left side and connect the right side and post a photo of the image.
                      Ukdigger take a high-quality photo of the completely left bar (when viewed from the back of the TV) and the T-con board.
                      • Diah
                        • Feb 2013
                        • 6496
                        vestel Firmware had section called MFC. its related to Panel. when its at half buffer state,, the screen will act at dummy action
                        • Ukdigger
                          • May 2020
                          • 121
                          • England
                          Picture with right hand side cable removed, as viewed from the back of the TV with aerial plugged in.
                          • Ukdigger
                            • May 2020
                            • 121
                            • England
                            • Ukdigger
                              • May 2020
                              • 121
                              • England
                              Pictures with right hand side cable removed, as viewed from the back of the TV. In my original post it should have said left cable removed gives a picture.
                              The screen changes from one picture to the other every couple of seconds
                              • lotas
                                • Jan 2016
                                • 4803
                                • Russia
                                Can you take clearer photos of a non-working bar, otherwise you got very muddy ones?
                                • Ukdigger
                                  • May 2020
                                  • 121
                                  • England
                                  Non working side, changes every few seconds
                                  • Ukdigger
                                    • May 2020
                                    • 121
                                    • England
                                    • lotas
                                      • Jan 2016
                                      • 4803
                                      • Russia
                                      You can measure the resistance of these test points to ground (GND) with the cable disconnected from the T-CON.
                                      • Ukdigger
                                        • May 2020
                                        • 121
                                        • England
                                        They all read 1.58 in diode mode
                                        I checked the other board and they all read 1.57 apart from 2 which read 1.56
                                        • Ryan.man
                                          by Ryan.man
                                          02-04-2025, 12:23 PM
                                        • reformatt
                                          by reformatt
                                          07-31-2025, 08:37 PM
                                        • smic717394
                                          by smic717394
                                          07-25-2024, 10:16 AM
                                        • MDY94
                                          Hitachi 50HK6100U display issue
                                          by MDY94
                                          I own a Hitachi 50HK6100U with a display fault. After some troubleshooting, I've found that removing one tcon cable produces a clear image on the side still connected. Removing the other tcon still provides display output; however, this is a heavily distorted image. With both cables connected, only the top ~25% of the screen provides display output which is still distorted. It's only when both are connected that most of the screen no longer provides output. The attached images show the screen with each tcon cable disconnected, and one with both connected. The red line shows where the display cuts...
                                          12-18-2024, 12:31 PM
                                        • kdaniel
                                          Hitachi 58HK6100U - Horizontal Lines (Bottom third of the screen)
                                          by kdaniel
                                          As stated by the person I collected the TV from, it just stopped working overnight. However, I still gave it a go to try and repair it.
                                          There is a thread on the same TV but with slightly different issues where they had to tape connection points on the ribbon cable, so I want to see if this is repairable by any chance.
                                          After bringing it home and plugging it in, the TV turned on with its backlight working but had no picture. After removing the back cover, the first thing I tried is to unplug one of the ribbon cables and the situation is as follows.
                                          Left...
                                          11-16-2022, 09:23 AM
