Sony KD-65X7000E - Screen double images for first few minutes then back to normal
  • beetle1303
    • Jul 2019
    • 279
    • Singapore
    I have gotten this Sony KD-65X7000E TV completely dead. According to owner TV was working fine and suddenly blackout and not able to power on again.
    Checked and found D751 rectifying diode shorted, replaced and now power up and working almost normally:
    1) On power up - display double images, and flicker once every few seconds.
    2) After 3-4 minutes at this state - display suddenly back to perfectly normal (although there are few horizontal lines at the bottom of screen).
    3) Leaving on for few minutes, power off and on again will repeat the same issue; but leaving it on for longer (like >30 mins) then power off and on again will not have this issue.
    I experimented with T-Con ribbon cables during cold start:
    1) Disconnected left-side cable - right-side display still double images
    2) Disconnected right-side cable - left-side display is good.
    3) Swopped the 2 ribbon cables - not difference
    3) Taped a small section on the right-side cable - display is normal at cold start also.
    Initial googling research seems to indicate shorted signal(s) path between left and right sides of panel PCBs, and taping method seems to have eliminated it. But why, presumably, after TV has wormed up the issue goes away?
  • chrismurphy
    • May 2014
    • 251
    • australia
    Re: Sony KD-65X7000E - Screen double images for first few minutes then back to normal
    faulty panel
    • beetle1303
      • Jul 2019
      • 279
      • Singapore
      Originally posted by chrismurphy
      faulty panel
      Any insight into why the display is normal few minutes after cold-start?
        • 12330
        • U.S.
        maybe check the little mlc capacitors on the faulty side panel driver board for shorts or very low ohms.
        • beetle1303
          • Jul 2019
          • 279
          • Singapore
          Will do and report back later when it's setup properly.
          *with power off presumably ?
            • 12330
            • U.S.
            Yes tv unplugged from power.
            • beetle1303
              • Jul 2019
              • 279
              • Singapore
              Just want to be sure this is not a potential root cause:
              The shorted D751 was a SB5150 - a 5A 150v diode, and was replaced with a 6A 200v diode unknow brand from local hardware shop.
              Would this caused the symptoms observed?
              • lotas
                • Jan 2016
                • 4861
                • Russia
                SB5150 is Schottky Diode
                • beetle1303
                  • Jul 2019
                  • 279
                  • Singapore
                  I am not well verse with electronic components... Does it mean it must be replaced with this exact part number?
                    • 12330
                    • U.S.
                    Doesn't seem like there would be much difference, best way is to look up both datasheets and compare.
                    • beetle1303
                      • Jul 2019
                      • 279
                      • Singapore
                      No benchtop space to lay flat the huge TV, so tried remove all the screws while standing the TV upright - can't seems to remove the cover plates to access the shielded the LCD driver boards...
                      • beetle1303
                        • Jul 2019
                        • 279
                        • Singapore
                        Checked and can't see any significant differences between SB5150 and SR5200
                        other than the voltages...
                        Also can't find SB5150 from the usual online shops, so will just get 4x SR5120 to try out.
                        • Diah
                          • Feb 2013
                          • 6565
                          could you show us the mainboards?
                          did you warm up the mb with hair dryer then turn on ?
                            • 12330
                            • U.S.
                            Be careful, easy to break those screens.
                              • 12330
                              • U.S.
                              Ok, I bet it's similar to this 60X690E, if so it's tougher than most to get to those boards, being that you can't easily lay it down, might want to try all other troubleshooting before tackling that: https://www.youtube.com/watch?v=Zr42F0JYq38
                                • 12330
                                • U.S.
                                something to try, go into menu and try turning backlights very low, if no backlight adjustment try turning the brightness down, see if the double image changes any.
                                  • 12330
                                  • U.S.
                                  Although if you could get it down that far it would be easy to apply a little pressure around the tab bonds and see if the picture clears up, of course while testing all the boards need to be connected.
                                    • 12330
                                    • U.S.
                                      • 12330
                                      • U.S.
                                      ok, forgot what I read in first post, you already taped it.
                                        • 12330
                                        • U.S.
                                        Here the tech gets it down to one line covered but sometimes more need to be covered: https://www.youtube.com/watch?v=pfrRhw7-ZII
                                        • rimwall
                                          Sony KD-65x7500D - double image - Tcon or Panel?
                                          by rimwall
                                          This TV was showing a fine image and pulsing with a partial double image (offset vertically) every few seconds. I taped 8 clock pins on one ribbon cable from the Tcon to the panel. It stopped the double image, but some pulsing in intensity was still visible. I then taped another 8 clock pins on the same ribbon cable and the image is now ‘fixed’. Although I understand this results in some loss of resolution, presumably because the clock signal degrades as it passes horizontally across the screen.
                                          I am wondering - do these symptoms and ‘fix’ mean that it’s a Tcon fault or...
                                          11-18-2025, 02:09 AM
                                        • ivtec
                                          sony kdl 32 bx 300 turns off and back on help
                                          by ivtec
                                          Hi my old Sony i turn it off and it turns itself back up and many times remote wont work have to unplug tv...
                                          07-03-2024, 10:52 AM
                                        • NolesFan
                                          sony kd-85x85j Looking for info on how to remove back cover
                                          by NolesFan
                                          Like the title states. TV is 3 years old and Im getting 6 red blinks, which is backing lighting issue or driver. I just cant find any info on how to remove the panel to access. Any info would be greatly appreciated.
                                          03-14-2025, 08:23 PM
                                          Linear Garage Door Opener Control board took a crap install a new control board back normal
                                          by sam_sam_sam
                                          I have been having issues with this garage door opener for a while first the range of the remote was a lot less and sometimes it would start to go down and stop for no reason that I could find and would every once in awhile to start with then it started going more frequently until last Saturday when I opened the garage door it refused to close so I cranked up force all the way maximum limit this did not work also the sensor on one side that has a green and red lights that are supposed to be on when the door is open and there are no obstacles in the way on the original board the only light that...
                                          02-08-2025, 06:52 AM
                                        • Carlos#2003%
                                          Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                                          by Carlos#2003%
                                          Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                                          02-15-2024, 07:52 PM
