Hisense 50P6
  • viewerau
    • May 2020
    • 305
    Re: Hisense 50P6
    Update....
    Hi again,
    I spent around 2 hours reseating and wiggling all the tcon and cof strips, but I cannot stop that pulsing loss of video on the last bit of the screen.
    I did note that when I had my finger on the spot where I removed the D004 chip, that I could feel voltage on my fingertips...like heat.
    I took out the solder iron again and used some more solder wick to clean the area, just in case there was still some solder residue etc, but that also didn't seem to stop it.
    I'm sort of reluctant to want to try to remove another chip, as if I do so, and it ends up with no picture etc, then there is no way I can put a replacement chip in it's place.
    Any suggestions please?
    So close...yet so far !!!
    Signature:Seemingly hopeless tv fixer
    • viewerau
      • May 2020
      • 305
      Re: Hisense 50P6
      I cleaned all my desoldering with isopropyl today...it is nice and clean, but unfortunately, I still have the little 3 second micro busrt happening at the bottom of the picture......suggestions please?
      • nomoresonys
        • 12276
        • U.S.
        #163
        Re: Hisense 50P6
        Well as per post 140, BOTH esd diodes were shorted, may be your problem too? you will not lose the picture if you remove the other one, just be careful not to damage anything during removal.
        • viewerau
          • May 2020
          • 305
          Re: Hisense 50P6
          I wonder if it is the diode on the same end to remove, or one of the two on the other edge board?
          When I tested all four diodes, the one that was removed was the only one showing a fault.
          • viewerau
            • May 2020
            • 305
            Re: Hisense 50P6
            Just adding to this, unsure if it should really be a different thread? If so, please advise and I will repost it there.
            In regards to these edge boards on tv panels, why do they insist on making them so that they are permanently fixed (bonded) via cof to the panel itself?
            On all the other parts of the panel, the tcon, main board etc all use the little clips to undo and disconnect them, so replacements can be fitted.
            Why can't the same be done to edge strips? I can understand the strip itself being bonded to the panel, but if the connection between the edge board and the cof strip were the same a tcon connections, surely many panels could easily be substituted/repaired, in a very easy fashion?
            • viewerau
              • May 2020
              • 305
              Re: Hisense 50P6
              I removed the diode chip next to the one previously removed, the tv is back to working in all areas again, no picture problems now.
              Special thanks to ruckusman.
              • viewerau
                • May 2020
                • 305
                Re: Hisense 50P6
                update....still working after repair
                • snowangel27
                  • Aug 2023
                  • 45
                  #168
                  Re: Hisense 50P6
                  Please take a look my theard
                  https://www.badcaps.net/forum/showthread.php?t=124448
                  Maybe i should check the eds diodes on buffer boards again
                  • Prott
                    [RoG Ally] Fault in one of the onboard RAM chips. Any way to diagnose which?
                    by Prott
                    Hello dear badcappers!
                    The title pretty much says it all - do you, please, know if there's any way to troubleshoot which of the integrated RAM chips (LPDDR5X in this case) is faulty?
                    Backstory:
                    After replacing the 4 onboard (soldered) memory chips on a RoG Ally (4x4 GB to 4x8 GB) it got stuck on the RoG logo. I assume one of the chips is either not soldered properly or faulty. However after reflowing and replacing bunch of them I am still stuck at the same place.
                    If there is a way to narrow down which memory module is faulty it would make my life much...
                    06-03-2024, 12:05 PM
                  • Kiberge
                    Samsung LH82QENELGC/EN Help needed - Static line on screen
                    by Kiberge
                    HI guys!
                    I've got a Samsung LH82QENELGC/EN with a problem and need some advice and I hope this is the forum to use?
                    I'm from Norway so I'd like to apology in advance if my description of the fault is kind of simple or the names on the components are way off. 😊
                    the TV is powering up, working as normally and picture is all good, except a 1.5-inch-wide vertical line of snow/static across the screen.
                    This TV is a Signage Display/Public Display version and it's been used at my work for 4-5 years showing commercials 24/7. The fault occurred when...
                    04-22-2024, 11:28 AM
                  • Rictech
                    Panasonic SA-MAX770PU SMPSU board fault....
                    by Rictech
                    Hello everyone. 😀
                    As per thread title, this unit has a serious SMPSU fault. It blows F1001, which is a 10A M205 in the phase from the mains input.
                    Very first thing I tried, was simply replacing the fuse, but the replacement ceramic fuse blew immediately.
                    Looking at the schematic for this PSU, I then removed what I thought was the next likely candidate: D1001 - the HV main bridge rectifier.
                    This isolated the fault(no longer blows the main fuse), but does not point me to the actual fault.
                    There are no devices that have exploded or otherwise show signs...
                    08-26-2024, 01:05 AM
                  • Diah
                    Hisense 2020 ULED 55U8QF Little Factory Fault end with Big damage !!
                    by Diah
                    this set delivered today to my home to inspect and write report to company sold this set 2 weeks before and the customer reject it as it had fault at picture. its look the transport damage happened during the customer sending it back to the company or on the way to me.. who care its not may fault. LOL
                    this ULED had full array LED backlight. from first look after remove the back cover with dozens of screws as 2 part cover. i found the ribbon cable at the panel side they was not correct fitting in place ( see photos before take the T-CON driver boards & After.) my wounder which...
                    11-14-2020, 01:43 PM
                  • tomketcz
                    schematic power board RSAG7.820.9713 from HISENSE TV Hisense 55E76GQ
                    by tomketcz
                    Does anybody have schematic power board RSAG7.820.9713 from HISENSE TV Hisense 55E76GQ ??
                    10-01-2025, 03:13 AM
