Panasonic 55DX600u repair help - no display fast green then slow red led flash
  • Diah
    • Feb 2013
    • 6374
    Re: Panasonic 55DX600u repair help - no display fast green then slow red led flash
    its edge or direct BL? can we see the the defect one? you wrote 3030 it sound direct LED with lens
      • 12196
      • U.S.
      #42
      Nice, yes that's what I was trying to say, I deleted it, I didn't want people to think that I didn't know that Melbourne is a very big city, lol.
        • 12196
        • U.S.
        #43
        saw some on ali, whole sets for like 20-35 bucks, maybe the right ones are in there somewhere: https://www.aliexpress.com/w/wholesa...list.1000002.0
        • fixxy88
          • Feb 2023
          • 27
          Sure :-)
          • fixxy88
            • Feb 2023
            • 27
            Thanks for the link. Some of those would probably fit and work, but apparently there are different color temp versions of this strip, and the DX600u isn't specifically listed, so I'm not sure if it would work 100% without affecting colour calibration.
            Haha all good. I'm not actually in Melbourne itself, but it's within driving distance :-)
            • Diah
              • Feb 2013
              • 6374
              so direct LED. you need to test one LED which working to chech if it build in zinner diode or with out. to be sure of the replacment one
              --- when you test with DMM diode mode will lit dimm and when you reserve the probe will read diode round 0.635 if no read mean with out zinner
                • 12196
                • U.S.
                #47
                Diah, is there a way to tell if the ones for sale have the ziner or not? is it in the label somewhere?
                • Diah
                  • Feb 2013
                  • 6374
                  some sellers write down led diagram und there pointed to the ziner build in.
                  • fixxy88
                    • Feb 2023
                    • 27
                    Thanks Diah :-) No zener on these LEDs. I just have to work out the colour temperature now. I think it might be more toward the blue end.
                    • fixxy88
                      • Feb 2023
                      • 27
                      Just thought I'd post a follow up to this. I fitted a new 3030 LED from Aliexpress to the strip and found it was not really close enough in colour temp, so using a purple marker pen I added some color to the lens and got it pretty close and refitted it. I moved that LED to the bottom corner where it would be less obvious.
                      The TV now works but has another fault. On the other side of the display to the replaced LED, the brightness is a little less, but briefly pulses to what I guess is normal brightness every 2 seconds. I'm not sure where to start with that one, and I think I've put enough time into it now and may just move it on. Also this display has terrible DSE, you can make out the LED lens circles on some scenes. Really strange, I don't know if it is just a bad model or even if some diffuser sheet was left out on a previous repair. I doubt this, as it all seemed normal when I pulled it apart.
                      Anyway, thanks for all the help, I learned a lot on this one!
                        • 12196
                        • U.S.
                        #51
                        Prolly another led on it's way out, does turning down the backlights or brightness effect it any?
                        • fixxy88
                          • Feb 2023
                          • 27
                          I actually suspect it's the panel drive rather than the backlight LEDS. It's a perfectly timed brightness pulse, and I can't seen any brightness change on the LEDS from the rear of the TV. Maybe I damaged a COB driver or flat connector somewhere....
                          • ekozeko333
                            [Help] Lenovo Yoga Slim 7-14ARE05 (DA0LS3MBAF0) – 25Q80DVN1G Flash Is All FF, USB-C PD Stuck at 5V
                            by ekozeko333
                            I’m trying to recover a Lenovo Yoga Slim 7-14ARE05 with board DA0LS3MBAF0 Rev:F. I’ve run into an unusual issue where USB-C PD is stuck at 4.7–5V and the system won’t boot (keyboard lights flash briefly, then nothing).
                            🔥 The Problem Started After Suspected ESD/PD Fault
                            I experienced a power issue or ESD event through a USB-C charger
                            After that, the NX20P5090 power switch was visibly burned and was replaced
                            Now the PD controller always negotiates 5V @ 2A, even with known-good chargers
                            🧠 What I’ve Done So Far
                            Flashed...
                            06-21-2025, 02:48 AM
                          • corrize
                            Nikon D800 camera - flash don’t work and capacitor don’t charge
                            by corrize
                            Hello, I'm stuck in troubleshooting…
                            The flash system works like that : when the (mechanic) flash button is pressed, the flash mecanically pop up, and a circuit buck boost elevate 7v (batt) to 200-300v (?) for charging the big capacitor. And when the photo shoot button is pressed, the capacitor is discharged in the xeon light.
                            In the D800, there is a first « power board » close to the battery. 2 wires (batt 7v) goes to another little « flash board ». I measured 7v, so ok.
                            When I press the flash button, it's detected by the system, flash icon appear on LDC display....
                            10-01-2022, 10:02 AM
                          • James Jackson
                            Panasonic CF-20G0247VM BIOS Bad Flash Help
                            by James Jackson
                            I usually try to figure these things out on my own but am asking for help now as I have been beating my head against a wall.
                            Backstory, I initially ended up with a CF20 Mk2 with a locked BIOS. I used aptio to read the BIOS and made the adjustments to the .rom file and attempted to write it back with aptio before reading other users problems with that setup. Well it bricked the BIOS go figure. Computer no longer boots, black screen. I found a clean BIOS on this forum but now I am having ME issues. So I would rather hand over the aptio dump(pre BIOS brick) and a hardware reader dump(post...
                            05-01-2025, 11:28 AM
                          • x_orange90_x
                            TCL 50S535 bad tcon or panel issue?
                            by x_orange90_x
                            Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                            03-29-2025, 11:02 PM
                          • jimjoe123
                            LCD TV Green/Pink screen problem
                            by jimjoe123
                            I have a Dick Smith 37" LCD TV, Model GE6804. I am using it as PC extended monitor only.
                            Problem is while watching tv, I hear a semi loud click(like a electrical breaker tripping due to overload, just sound like it but no actual electrical overload), then screen is covered with green or pink. I can still see the original picture image but overlayed by green or pink. See attached images. Pink.jpg is what I see, and Normal.jpg is before green or pink screen, What I captured was pink screen, but about 80% of time it's green and 20% of time it's pink.
                            Then each time...
                            02-23-2020, 01:29 AM
