Samsung 65" UE65TU7000KXXU VER:02/UTU7000 TV Blue screen
  • gbbradshaw
    • Feb 2023
    • 55
    Hi.
    I have the Samsung TV Model: UE65TU7000KXXU VER:02/UTU7000 which has developed the following issue: blue screen while the sound it's still working. This happened after the screen developed some horizontal lines at first and then the next day suddenly turned into blue background. the screen was not damaged or anything. I can't access the menu. I have taken the tv to a local tech to have a look and he said that he thinks that it might be the pcb board as the back-lights are working and the sound aswell . I was hoping maybe you can guide me if I should buy the pcb board or not? Thanks
  • gbbradshaw
    • Feb 2023
    • 55
    Samsung UE65TU7000KXXU VER:02/UTU7000 tv pcb board cap
    The problem on my Samsung TV Model: UE65TU7000KXXU VER:02/UTU7000 is more likely to be a bad capacitor (smd?) On the pcb board. The local tech has recommended to buy a second hand pcb but he isn't sure if this will eventually sort the issue. I have a blue screen with sound working.
    Is there any way I can check the capacitors myself before taking the risk and buying the pcb that might not work?
    There is a picture of the board. Thanks alot!
    Last edited by SMDFlea; 02-22-2023, 07:11 AM. Reason: UE65TU7000KXXU VER:02/UTU7000
    • Storyteller12
      • Jun 2020
      • 624
      Re: Samsung 65" TV Blue screen
      Can’t say 100% without and kind of troubleshooting. But these “TU” series TVs have had a lot of panel failures/ problems.
      • gbbradshaw
        • Feb 2023
        • 55
        Re: Samsung tv pcb board cap
        I have tested with the multimeter for continuity (beep) and also tested by setting it on 20k ohms and some of them are charging while some are not showing any value.
        • gbbradshaw
          • Feb 2023
          • 55
          My theory is that while he was checking the tv, the tech has "played" with the ribbon cables that connects the bottom lvds stripe and that's why the next morning he announced me that the screen is blue. I've only found out later that these can cause problems by not connecting them back properly, so there's too late to complain about it now.
          • nomoresonys
            • 12206
            • U.S.
            Re: Samsung 65" UE65TU7000KXXU VER:02/UTU7000 TV Blue screen
            post straight on clear pictures of each board and one of the whole back, as to see how everything is connected.
            • gbbradshaw
              • Feb 2023
              • 55
              I will certainly do that once I get home, thank you!
              One thing, it appears that the pcb has a heating shield on it which has thermal paste on. The reason why I am mentioning this is because there are more capacitors under the heating shield but I am not sure if I should take that apart.
              • nomoresonys
                • 12206
                • U.S.
                should probably do some voltage checking before removing anything.
                • yokoono
                  • Apr 2010
                  • 488
                  Is CN1 closed correctly?
                  • nomoresonys
                    • 12206
                    • U.S.
                    easy stuff first, try a simple reset, with tv unplugged, hold power button on tv for 30 seconds, then plug it in and try it.
                    • nomoresonys
                      • 12206
                      • U.S.
                      yep, make sure those cables are positioned correctly, can clean them too: https://www.youtube.com/watch?v=aOCLpJub2l0
                      • gbbradshaw
                        • Feb 2023
                        • 55
                        I will do clear pictures and then maybe you can guide me to do so please.
                        • gbbradshaw
                          • Feb 2023
                          • 55
                          I have already did that last night just to tick this off the to do list. No success with that. One thing I have to mention, removing the white lvds cable , the long one, does nothing. But with it connected, when I switch through the tv channels I can see the screen light changing from dark blue to lighter. Which mean somehow thr pcb board is not sending enough signal to the display.
                          • gbbradshaw
                            • Feb 2023
                            • 55
                            Already tried that, more than 60 seconds.
                            • gbbradshaw
                              • Feb 2023
                              • 55
                              Yes , everything was cleaned with contact cleaner and put back together as normal to the lines.
                              • Davi.p
                                Hobbist Tech
                                • Sep 2009
                                • 4367
                                • Italy - Milan
                                don't waste money buying a main board, it's almost surely the panel, since you are not a tech and the fault is very difficult i suggest you to sell the whole thing as a defective unit.. bye..
                                • gbbradshaw
                                  • Feb 2023
                                  • 55
                                  I am not sure I want to sell it for £50 while I paid more than 10 times this price last year. I am sure there are specialists in here who might have encountered this kind of problem over the years and that might be able to help. Thanks for replying though.
                                  • gbbradshaw
                                    • Feb 2023
                                    • 55
                                    But OUT d pee, if you don't want to help, keep your SARCASM to yourself.
                                    Thanks dude! Just stay tuned, I will upload the pictures at around 6pm uk time.
                                    • nomoresonys
                                      • 12206
                                      • U.S.
                                      you could check the little mlc caps on the panel driver boards for shorts or very low ohms.
                                      • gbbradshaw
                                        • Feb 2023
                                        • 55
                                        Is this the right way to do it? Please check the picture
                                        I know that if the caps beeps when I use the multimeter, in most occasions its a bad capacitor.
                                        I also know that if I set the multimeter to 20k to check the ohms and the value is not going from 0 to higher, that's also a bad cap.
                                        Correct / guide me if I am wrong please. Thanks
                                        • mar1in
                                          Samsung TU8000, backlight and sound on, stuck in blue screen
                                          by mar1in
                                          I've got this Samsung here that would be stuck in a boot loop.
                                          After opening up and doing the tape block method, I was able to get it to turn on and play sound from the HDMI input, but with a blue screen.
                                          Does that mean there is another combination of pins that I need to block in order to get a picture, or is there something more serious, faulty mainboard or faulty panel?
                                          Thanks in advance
                                          11-08-2023, 05:43 PM
                                        • Mgiffune
                                          by Mgiffune
                                          06-09-2024, 10:28 AM
                                        • Chrissygizmo
                                          by Chrissygizmo
                                          02-10-2025, 12:33 AM
                                        • Chrissygizmo
                                          samsung galaxy ao2s very temperamental after screen replaced
                                          by Chrissygizmo
                                          Hi , I've recently replaced the screen in my Samsung galaxy ao2s, at first it wouldn't even turn on, it had the charging symbol on the screen when plugged in but the green circle wasn't going around to show it charging....
                                          Ive eventually managed to get it on and working but it's very temperamental...
                                          The battery icon always reads as 50% , when the phone goes into lock screen mode i sometimes can't get the screen back on unless I plug the charger in to get it to light up, also it keeps putting the camera app on.. u think it could be something to do with the side buttons. ...
                                          05-26-2024, 12:05 AM
                                        • bohaboha
                                          Samsung UE70TU6905 BACKLIGHTS AND SOUND ON NO PICTURES BUT SCREEN NOT DARK
                                          by bohaboha
                                          Hi it looks like everything works don't know where to test except the 390v in the 2 capacitor in the hot side of the power supply and the weird 180v in the diodes in the cold side that should be discharged it is writin on the circuit no more you can read what is written on the circuit quite srrange color mixiing yellow and white
                                          anyhow i couldn't t read anything else
                                          the backlight is on strong and the screen does not get dark or very dark but no pictures
                                          the mainborad feels a bit hott on the black part i test it to 52 degree's against 34 to 40 on the rest of it
                                          01-02-2025, 08:04 PM
