Lg 55lf6000 will not turn on.
  • sputnikoff
    • Feb 2016
    • 203
    • canada
    I have this unit lg 55lf6000 with 2 issues.The first was faulty lamps ...problem 1 solved.Problem 2 is as goon as unit plugged in get the sold red light on front and pressing power does nothing.I shorted vcc 3.5 vdc and pwr and drv-on to ground on power supply and lamps fire up so thats good.On the module eax65391003 i see the optical lamp is on i trace the voltages as far as i could to no avail.Anyone has and success with this issue?
    • 12206
    • U.S.
    Re: Lg 55lf6000 will not turn on.
    sounds like a mainboard issue.
    • sputnikoff
      • Feb 2016
      • 203
      • canada
      Yes definitely a main board looks like main chip has failure due to bad bga soldering.
        • 12206
        • U.S.
        Hit it with a hairdryer for a few minutes, then see if it comes on for a bit.
        • sputnikoff
          • Feb 2016
          • 203
          • canada
          Will do thanks
          • sputnikoff
            • Feb 2016
            • 203
            • canada
            No luck applied heat to no avail ,have to order board.
            • Davi.p
              Hobbist Tech
              • Sep 2009
              • 4366
              • Italy - Milan
              No bad soldering in this case!! Use immagination.. bad lamps means overvoltage , then also overvoltage to the main board! check the standby software memory first.. is there a spi flash? rewrite it..
              • pajdek
                Lenovo Y700-17ISK turn on and off
                by pajdek
                Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
                09-20-2023, 02:49 AM
              • RdeveLabs
                MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
                by RdeveLabs
                To all the members here...
                Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
                So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
                05-05-2025, 04:59 AM
              • robante15
                Acer Aspire 4520 won't turn on after reboot
                by robante15
                Hello, I have an Acer Aspire 4520 from a couple of decades ago and I want to repair it solely for nostalgia.
                It happens that when I turn it on after having been disconnected for a long time, it turns on without problems, it tells me that the BIOS has been reset and that it will load the factory settings, if I tell it to continue, the computer turns on and everything works fine.
                The moment I turn it off and want to turn it back on a second time, or restart it and try to start it again, it no longer gives an image, and it no longer responds.
                If I remove the...
                04-06-2024, 06:50 PM
              • masoksian
                Dell latitude e7470 not turn on .power buton on off and Run Power problem
                by masoksian
                I am dealing with the problem of turning on and off my Dell e7470 notebook.
                The battery charge light is solid white, I press the button, the power indicator and the light on the button are solid for 1-2 seconds and immediately turn off.
                The system does not turn on, there is no post.
                I removed the RAMs and changed them, changed the battery, RTC battery, AC adapter, removed them and waited, tried again, it does not turn on.
                The problem continues in the same way.
                I tried to turn on the Fn key, nothing came to the screen....
                02-15-2025, 12:08 PM
              • dqtech
                lenovo x240 nm-a091 wont turn on
                by dqtech
                i got this laptop with no power issue....i flashed the bios and laptop can turn on and use normally....but when i shut it down and rest for few minute (2-3 minutes), it wont turn on....i have to flash bios again...any idea what is the problem?...when i shutdown and suddenly press power button to turn on, it will turn on normally....problem happen when i rest the laptop 2-3 minutes after shutdown, it will not turn on....i need to flash bios again
                board number VIUX1 NM-A091 REV:1.0...
                02-07-2024, 01:57 AM
