Samsung QE50Q50TUA power cycling.
  • stav242
    • Jan 2014
    • 61
    • United Kingdom
    I picked up this Samsung 50" QLED, QE50Q50TUA.
    MB is BN41-02756C.
    PB is BN44-01058A
    no dedicated TCON - its on MB.
    fault symptoms are:
    TV powers on, Backlights come on, no picture, then restarts and repeats.
    Power from PB to MB is good, 13V is present as detailed on the PB board diag info.
    i can find some 1.3v and 3v power on the MB, but nothing higher.
    there is no VGH on the buffer boards, again some 1.5v and 3v, nothing higher.
    found this SMD device (diode ?) which doesnt register on ESR/cap/diode tester, removed it and still tests the same.
    SMD code : NE1 EN7
    label near it : IC4000_UT
    cant find it anywhere -any suggestions what it might be and what i could replace it with ?
  • lotas
    • Jan 2016
    • 4753
    • Russia
    Re: Samsung QE50Q50TUA power cycling.
    It's not a diode, it's a Polymer Chip Tantalum Capacitor.
    • stav242
      • Jan 2014
      • 61
      • United Kingdom
      ok, thanks.
      ill see if can find a suitable replacement from a spare board.
      • stav242
        • Jan 2014
        • 61
        • United Kingdom
        replaced with a 33uf 50v cap. no change though.
        anywhere i can find a circuit digram for the MB ?
        • alfatv
          • Sep 2020
          • 353
          Disconnect the cable from main board to panel and see if it's still restarting
          • lotas
            • Jan 2016
            • 4753
            • Russia
            Disconnect the LVDS cable and try turning on the TV and see if it reboots.
            • stav242
              • Jan 2014
              • 61
              • United Kingdom
              if i disconnect the LVDS cable the set boots and doesnt reboot. (optical port LED stays on continuous).
              if i reconnect the main LVDS cable, but then disconnect the right (view from the rearview) side buffer board from the left buffer board. the set still boots.
              ive checked all caps on the buffer boards, cant find any shorts.
              no signs of panel damage and COF cables look fine.
              i was looking for 12v or 24v on the buffer board, but cant find anything - which led me back to the MB.
              is this likely to be a buffer/panel board short - or a MB power fault ?
              • lotas
                • Jan 2016
                • 4753
                • Russia
                The problem is in the panel itself, take a photo of the full buffer strips and on which strip, if it is connected, the reboot occurs.
                • Davi.p
                  Hobbist Tech
                  • Sep 2009
                  • 4464
                  • Italy - Milan
                  in our country in this case we say Flic Floc!
                  • stav242
                    • Jan 2014
                    • 61
                    • United Kingdom
                    ok, photos attached.
                    2x of main board with LVDC connector - no markings i can identify any volatages to check.
                    2x of left board - this is connected and TV powers on, optical port on MB lights up constant, remote works, but no sound or picture.
                    4x of right board, this connects to leftboard, and when connected the TV reboots every 10 seconds. - can see the MB optical light and backlights power cycle.
                    ive checked the cof tabs, cant see anything visually wrong, no burns or damage.
                    this TVs a QLED and cant immediiatley see hwo to get the LCD panel away from the frame to do a more intrusive panel check atm ... will see if i cant figure it out.
                    • alfatv
                      • Sep 2020
                      • 353
                      Looks like another TU.
                      Why do you need to remove the panel?
                        • 12276
                        • U.S.
                        It's a samsung QExxxxx POS, problem is the panel as stated, don't really need to look at the backlights, so no reason to tear all the way down.
                        • usbdevice
                          Acer X223HQ (Version Bbd) on/off-power-cycling
                          by usbdevice
                          Hi all
                          There's two other threads about this monitor with seemingly the same problem. The problem was resolved in one case by replacing the entire PSU board and in the second one by replacing an unknown IC.
                          https://www.badcaps.net/forum/showthread.php?t=50657
                          https://www.badcaps.net/forum/showthread.php?t=40512
                          The first one has pictures of the pcbs and I noticed that there's one IC and assorted caps not populated on mine (but the PCB itself looks identical) so I thought that'd warrant a new thread.
                          It's my dad's old monitor. He...
                          08-05-2022, 02:21 AM
                        • valvashon
                          Samsung UN55FH6030: random power cycling
                          by valvashon
                          Samsung UN55FH6030, perfect size for my office and does OTA well but isn't a smart TV. That's OK because I am a TV station engineer and only need it for OTA monitoring.
                          About a month ago it started power cycling itself once or twice a day and now it's nearly continuous once it's been on for a few minutes. Changing channels would really start it cycling and it would take several minutes to stabilize but now it's just doing it almost non-stop without changing channels.
                          Once I disconnected the antenna I found that I could change channels with no issues. My guess is...
                          10-20-2023, 09:59 AM
                        • Journey11
                          Samsung TV won't turn on ... keeps cycling the power relay on & off
                          by Journey11
                          Hi All,
                          First time posting here ... my name is Kevin but my friends call me Journey.
                          I have a Samsung 75" LCD model UN75RU8000FXZA that I don't remember the original fault other than it wouldn't power up anymore.
                          After it sat for many month's I decide to look at it again. The motherboard seemed to have power regulation issues. After much fussing I decided to just get a new MB.
                          It came a few days ago and I installed it now just cycles the power relay on and off ... when on the backlights light up and then dim and then relay kicks off and the whole things starts again....
                          07-04-2024, 02:44 PM
                        • mrtek
                          Samsung UN43NU6950FXZA No power
                          by mrtek
                          Hi
                          Picked up another TV. Samsung UN43NU6950FXZA. No power and no standBy led on. Removed back cover and:
                          Main fuse = OK
                          Back light LED = OK. Power them with aux power source
                          LED output = OK 156V
                          I do get 12 V DC out of the power supply going to the digital section but no 5V or 3.3V. PS_on voltage is only 1.8V. I have looked everywhere on the PCB , I could not find i reference for 5V output.
                          Also removed connections to panel, speakers and remote but no luck. One strange thing is that even with the LED power supply working, backlight LED do not turn on...
                          07-20-2025, 08:06 PM
