Samsung BN44-00284A Backlight problem
  • sandinemail@hotmail.com
    • Feb 2023
    • 15
    • Sweden
    Re: Samsung BN44-00284A Backlight problem
    Shows 32,4uf when measuring on a 33uf new capacitor.
      • Feb 2023
      • 15
      • Sweden
      Yes because they are parallel.
        • Feb 2023
        • 15
        • Sweden
        Did an ohm measurement 3 transformer are the same readings.
        1 is another model with different values
          • 12276
          • U.S.
          did check your transistors, easiest is the short test, see if any of the three pins test short to either of
          the other 2 pins of the transistor.
          • vinceroger69
            • Mar 2012
            • 6714
            what are the readings from one of the three and the diffrent model transformer as i would of thought all should match ohm wise
              • 12276
              • U.S.
              #26
              did you have any pinkish hue off looking colors, you get that sometimes when a ccfl is on its way out.
                • Feb 2023
                • 15
                • Sweden
                #27
                I havent noticed any color difference.
                  • 12276
                  • U.S.
                  #28
                  so what happens when you unhook the cable from powerboard to mainboard and plug power cord in, do backlights come on and stay on?
                    • Feb 2023
                    • 15
                    • Sweden
                    #29
                    Backlight turns on for two seconds then turns off.
                    • Diah
                      • Feb 2013
                      • 6440
                      If I turn up backlight settings to 10 it immediately turns off backlight.
                      replace LED BL
                        • 12276
                        • U.S.
                        #31
                        they are ccfl.
                        • Diah
                          • Feb 2013
                          • 6440
                          they are ccfl.
                          oopsss.... ccfl..... i just read it the set from 2009....
                          • vinceroger69
                            • Mar 2012
                            • 6714
                            #33
                            this thread maybe worth a read https://www.badcaps.net/forum/showthread.php?t=10419
                              • Feb 2023
                              • 15
                              • Sweden
                              #34
                              Thanks for your help.
                              Time to buy a new TV.
                                • 12276
                                • U.S.
                                #35
                                LOL^^^^ I have to agree with that.
                                • fanaticgames
                                  Samsung UE32D4010 Backlight problem, led ok
                                  by fanaticgames
                                  hello I have a backlight problem on this TV, if I unplug the cn201 cable the backlight works perfectly and the voltages are 13v if I connect the cn201 cable the backlight goes off and the voltage drops to 12v, I assume it's a motherboard problem, the question is has anyone had a similar problem? I want to understand if the motherboard is repairable or it's not worth wasting time...
                                  02-22-2023, 09:46 AM
                                  09-07-2024, 05:50 AM
                                • sansanpartida
                                  Samsung QE82Q70RAT no backlight
                                  by sansanpartida
                                  Hi everyone!
                                  Hope you're all having a great day, and thank you very much for stopping by and taking the time to read this post to help me with my parents' Samsung TV.
                                  My issue: No backlight.
                                  Model: QE82Q70RAT
                                  Type No: QE82Q70RAT
                                  The TV was already serviced by Samsung once under warranty for the exact same issue, but six months after the fix, the backlight went out again. Now, Samsung is asking for nearly the same price as a brand new TV to fix this with the same 6-month guarantee.
                                  So hopefully, I can fix this cheaper.
                                  05-22-2024, 06:56 AM
                                • howardc64
                                  Samsung UN55NU7300F Curved TV. Half side backlight out. Fixed by just removing the rear snap cover
                                  by howardc64
                                  TV was fixed just after removing Samsung's rear snap cover.
                                  This curved TV's construction is rather interesting. When the snapped on back is removed, rest of the TV will relax the curvature. Top of LCD panel is loose as it wants to straighten out against the slightly curved bezel. Snapped back provide most of the curvature shape. So just simple disassembly of rear cover will allow the rest of the TV frame to relax its curvature. Thats probably what fixed it but no idea which connection. 4x LEDs are edge lit.
                                  Maybe PSU->backlight connector didn't have a good contact?...
                                  07-23-2025, 12:34 AM
                                • howardc64
                                  Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
                                  by howardc64
                                  • Prior owner tried a replacement main board. No difference.
                                  • Samsung 2x red blinking standby LED = panel fault
                                  • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
                                  • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
                                  • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
                                  07-19-2025, 10:54 PM
