Samsung BN44-00284A Backlight problem
  • sandinemail@hotmail.com
    • Feb 2023
    • 15
    • Sweden
    Re: Samsung BN44-00284A Backlight problem
    Shows 32,4uf when measuring on a 33uf new capacitor.
      • Feb 2023
      • 15
      • Sweden
      Yes because they are parallel.
        • Feb 2023
        • 15
        • Sweden
        Did an ohm measurement 3 transformer are the same readings.
        1 is another model with different values
          • 12082
          • U.S.
          did check your transistors, easiest is the short test, see if any of the three pins test short to either of
          the other 2 pins of the transistor.
          • vinceroger69
            • Mar 2012
            • 6714
            what are the readings from one of the three and the diffrent model transformer as i would of thought all should match ohm wise
              • 12082
              • U.S.
              #26
              did you have any pinkish hue off looking colors, you get that sometimes when a ccfl is on its way out.
                • Feb 2023
                • 15
                • Sweden
                #27
                I havent noticed any color difference.
                  • 12082
                  • U.S.
                  #28
                  so what happens when you unhook the cable from powerboard to mainboard and plug power cord in, do backlights come on and stay on?
                    • Feb 2023
                    • 15
                    • Sweden
                    #29
                    Backlight turns on for two seconds then turns off.
                    • Diah
                      • Feb 2013
                      • 6346
                      If I turn up backlight settings to 10 it immediately turns off backlight.
                      replace LED BL
                        • 12082
                        • U.S.
                        #31
                        they are ccfl.
                        • Diah
                          • Feb 2013
                          • 6346
                          they are ccfl.
                          oopsss.... ccfl..... i just read it the set from 2009....
                          • vinceroger69
                            • Mar 2012
                            • 6714
                            #33
                            this thread maybe worth a read https://www.badcaps.net/forum/showthread.php?t=10419
                              • Feb 2023
                              • 15
                              • Sweden
                              #34
                              Thanks for your help.
                              Time to buy a new TV.
                                • 12082
                                • U.S.
                                #35
                                LOL^^^^ I have to agree with that.
                                • fanaticgames
                                  Samsung UE32D4010 Backlight problem, led ok
                                  by fanaticgames
                                  hello I have a backlight problem on this TV, if I unplug the cn201 cable the backlight works perfectly and the voltages are 13v if I connect the cn201 cable the backlight goes off and the voltage drops to 12v, I assume it's a motherboard problem, the question is has anyone had a similar problem? I want to understand if the motherboard is repairable or it's not worth wasting time...
                                  02-22-2023, 09:46 AM
                                  09-07-2024, 05:50 AM
                                • sansanpartida
                                  Samsung QE82Q70RAT no backlight
                                  by sansanpartida
                                  Hi everyone!
                                  Hope you're all having a great day, and thank you very much for stopping by and taking the time to read this post to help me with my parents' Samsung TV.
                                  My issue: No backlight.
                                  Model: QE82Q70RAT
                                  Type No: QE82Q70RAT
                                  The TV was already serviced by Samsung once under warranty for the exact same issue, but six months after the fix, the backlight went out again. Now, Samsung is asking for nearly the same price as a brand new TV to fix this with the same 6-month guarantee.
                                  So hopefully, I can fix this cheaper.
                                  05-22-2024, 06:56 AM
                                • Bloopeta
                                  Samsung UE55H8000 Backlight Power Problem
                                  by Bloopeta
                                  Have a Samsung UE558000, which I thought was just going to be a straightforward backlight replacement, as the screen was dark in the middle.
                                  After stripping it down, I noticed it was exactly the same lights out on both sides (see pic)
                                  I tested the strips with LED tester, and no bulbs were out, so I tested the voltage going to the strips, both at the board side, and at the strip.
                                  On Blue, there is 30.5v on pin 3 and 9, but nothing on the others.
                                  Same situation on White, 30.5v pin 2 and pin 8
                                  All caps look ok, anyone any idea?...
                                  01-30-2023, 01:34 PM
                                • Ierwin
                                  by Ierwin
                                  05-13-2025, 03:31 PM
