hi, i'm looking for the firmware for this tv on which i had to change the panel because it was broken, but it's a bit different and the image is upside down and not normal, the panel is: ves315wnda-2d-n04 the main it was connected to is: 17mb82s. ..I should connect it to main:17mb82-1a whose broken panel was:ves 315wndl-01,can I write the firmware of the first main on this or is there a firmware for this main?
tvled telefunken te32180b29c10
Re: tvled telefunken te32180b29c10
You need the panel profile. Do you know the installation procedure?Attached Filesif you find these attachements useful please consider making a small donation to the site
1. Format a stick with fat32
2. Unzip and put the 2 files on the stick
3. Turn on the TV and insert the USB stick
4. Type MENU 4725 and go to USB Operations
5. Press OK on the remote control and wait 5 seconds
6. Exit the menu and turn off the TV from the remote control. Wait until the stby LED stops flashing.
7. Unplug the TV and wait until the stby LED goes out.
8. Remove the USB stick and turn on the TV.Comment
by joby91Hello,
I have SONY KD-55AF9. Mainboard MAIN-BM3-1-983-356-11 with defekt EMMC.
I wanted to buy new EMMC and Flash the firmaware on it. Does anyone have the firmware for this TV. I would be really grateful.
I found one chat about firmware on ************** forum but i cannot read the comments.
https://**************/forum/108-114100-1#880537
by Dani_2024Hi and thanks in advance for any input you might provide!
Last Sunday I was watching a dvd and fell asleep for about half hour, when I awoke the tv screen was black and couldn't get the dvd menu to show, so I changed the input to antenna and had sound but no picture, turned it off. I then got online and found this great site! ....read many troubleshooting tips and this...5 Photos -
by zklgfsHi,
I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...-
08-11-2025, 02:14 PM -
by TheUserHello to everyone ,
This is my first post here, and i would like to share with you a small story in case you can help me.
Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help... -
by gurj1979Hi guys.
I've got a Ubiquiti US-8-150W POE switch which has issues with updating the firmware.
Turned out to be a bad EEPROM chip. It would read the firmware and work as normal, but failed to write new firmware to it.
So I took off the chip and read on EEPROM and saved it. Wrote to old chip and failed to write
Got New chip and writes good.
THE PROBLEM...
It fails to fully load the firmware, POE lights fail to work during g firmware test during load. I'm suspecting bad EEPROM Read.
Does anyone have a Good Firmware I can have?...-
Channel: Troubleshooting & Designing Networks
- Loading...
