Re: Samsung UE55MU6120K Boot loop with backlight no video
not sure, but probably retaining a lot more heat if it's snug against the wall, well was it sitting straight when running for 30 hours as in same position as on the wall.
it was installed on the wall, maybe some bad welding and with the deformation of the weight... I don't know what the hell to think, it's the strangest thing that happened to meLeave a comment:
my buddy tampatec fixed one by putting some good heatsinks on every chip that got pretty warm on the mainboard, might not do the trick but something pretty easy to try.Last edited by nomoresonys; 03-01-2023, 11:34 AM.Leave a comment:
almost seems like something on the mainboard is just getting too hot once you get the back on and it back on the wall.Leave a comment:
bad news, the tv was installed on the wall in its old place with only the power cable and tv antenna connected, the first time it was turned on the error again ... it has been turned on 4:5 days lately without problemsLeave a comment:
comparison not comparation sorry..Leave a comment:
and the comparation what says?Leave a comment:
No, i think the more possible responsible is the main settings eprom, that is the 24c series epromLeave a comment:
25Q80 is responsible for T-Con.Leave a comment:
which of the two eeprom? because I made a backup before doing other tests (I wanted to understand if it had a damaged firmware), I could do a new dump and compare if there are differencesi am developing from also other threads an idea that the main board stores in an eprom something like an error flag, the forcing of the tcon outputs can restore a visualization and reset that flag, maybe in certain cases the error flag is set due to a temporary malfunction, i'm following another interesting thread, if i have some news i'll let you inform..Leave a comment:
has been on more than 10 hours without problems, I don't know what to say but it worksLeave a comment:
out of curiosity I disconnected all the flats and reconnected (just to rule out a false contact) and I mounted the cover behind, it still works. Now I'm going to leave a movie playing, let's see...Last edited by fanaticgames; 02-24-2023, 01:19 PM.Leave a comment:
As obvious i don't know what happened, no schematics, no answers, i have a doubt but i let it stay in silence.. we will seeLeave a comment:
but the jumper was held for 4/5 minutes with the TV on, now there is no jumper, I also turned it off for 5 minutes and turned it on again and it works regularlyno, nothing discharged, pwm4 might be the signal that goes to the power board and is for brightness level setting, T-RDY1 might be a fixed 3v i guess, putting pwm4 set to steady 3v could have set brightness of part of the backlights bars to full brightness.. nothing to do with lcd panel i think.. those 2 mosfets are probably final switching transistors for the pwm signals
I also redid this wrong jumper last timeLast edited by fanaticgames; 02-24-2023, 12:52 PM.Leave a comment:
no, nothing discharged, pwm4 might be the signal that goes to the power board and is for brightness level setting, T-RDY1 might be a fixed 3v i guess, putting pwm4 set to steady 3v could have set brightness of part of the backlights bars to full brightness.. nothing to do with lcd panel i think.. those 2 mosfets are probably final switching transistors for the pwm signalsLast edited by Davi.p; 02-24-2023, 12:40 PM.Leave a comment:
it certainly won't last for now it's been on for 30 minutes, maybe I'm talking bullshit could it be that some component "discharged" during these days of inactivity? the esd diodes??Last edited by fanaticgames; 02-24-2023, 12:34 PM.Leave a comment:
by TakeatrySamsung QLED QN50Q — purchased 2022 started experiencing a delay in the picture coming on in the morning less than 2 years later. Did not know the term boot loop at that time. As the loop delay ran into a few minutes did all the recommended troubleshooting, soft and hard reset, changing cables and outlet locations, no help. As the delay increased contacted Samsung tech group and allow them remote access the tv. Tech was moving too fast to see exactly what he was doing but this ultimately it was also no help. Lived with the delay until it stretched out over 6 hours. Pulled of off the back cover...2 Photos
by torchzackHi Team - just joined to see if anyone can offer some expertise in diagnosing an issue with a TV.
I've done a few hours googling and youtubing but just seeing if anyone has any insight here. I got a 55" Samsung UE55MU6470U which seems to boot loop and then after 10 mins will boot, work for a few minutes, then turn off and repeat.
Whilst it's on into the normal Samsung menu/boot screen it looks perfect - so I can't see there being any screen issues. I've seen lots of videos with taping across clock lines to diagnose which particular one may be an issue but i don't... -
by NolesFanHello all... TV started boot looping. Opened the back panel and tried to isolate the problem. Just PSB no boot loop. PSB and MB no boot loop. Plug in the LVDS from panel to MB and boot looping starts up. It doesnt matter of order that I plug the LVDS ribbons back in, only 1 and no boot loop but as soon as 2nd one plugs in boot looping. I then noticed a flicker on the screen when I was closing the clip on the harness to the LVDS. Shut the lights off so I can see better, and I noticed as i slowly close it, I will get a picture, but as soon as it clips in, I lose picture and booting happens. So I...2 Photos
by eigmaHi, I rescued a Samsung UN40H5003AF (H = 2014 FHD) from the curb. Symptoms are: standby (red) light comes on, stays on for 8 seconds, flickers off, then comes back on, and the cycle continues.
Service manual: https://www.electronica-pt.com/esque...is-u8la-71272/
SMPS board: checked voltages, all seem normal (A13V = 12.8V, UD = 3.3V, PWM_BLU = 0.77V, PS_OnOff = 5.5V). Remove 10p cable to main board -> backlight comes on. I think this means SMPS board and backlight are good.
Main board: BN94-07592P / BN97-08922R...1 Photo -
My Samsung TV had a black patch on the left side of the screen for a while. One night it shut off and then became stuck in a boot loop. I initially believed the back-light was the issue and replaced the LEDs but it still boot loops. I've since replaced the main board and the issue persists.
With the main board unplugged, it powers on and the back-light comes on. I've tried the tape method but I gave up as I don't know what pins I need to cover.
I suspect the panel itself it broken but have no multi-meter to test. Is it worth investing in one to test?... - Loading...
