LG 70UH6350 (UB.BUSMLJr)
  • Diah
    • Feb 2013
    • 6370
    Re: LG 70UH6350 (UB.BUSMLJr)
    MB issue
    take it out from tv... and measure at the socket resistances value reference to boards chassis point... or replace it... to me it sound BGA issue...
    • nonsub
      • May 2018
      • 84
      Originally posted by Diah
      MB issue
      So you are confident panel, BL, TCON and PSU are all good yes?
      Other board I actually tried to heatgun the BGA but made the problem worse.
      So sorry but which socket pins to measure resistance? All 28 of them? Look for short right?
      • Storyteller12
        • Jun 2020
        • 624
        Yes, the main board is bad. I mentioned this in post #6.
        I had this exact same tv and fixed with new mainboard
        • nonsub
          • May 2018
          • 84
          Yes this was the consensus but after replacing twice with E-pray boards and having the same problem I wanted to be sure.
          • nonsub
            • May 2018
            • 84
            PN: EBT64174323 is for UB.AUSMLJ
            PN: EBT64174324 is for UB.BUSMLJ
            Would you guys trust the following which suggests that they are interchangeable?
            https://lgparts.com/collections/elec...8e91f662&_ss=r
            Thanks!
              • 12187
              • U.S.
              #46
              suppose its ok, info comes straight from the lg site.
              • nonsub
                • May 2018
                • 84
                Thanks. Let's see what master DIAH says too
                • Diah
                  • Feb 2013
                  • 6370
                  i am not master..... all users are Master include whom didn't joined your threat,,, as it refund agreement for yours MB you have, i would go with any TV size from 6350 series . other things if it run and you have display screen at any matter or issue.. it can be adjusted with e-z adj menu.
                  by the way did yours tv worth such huge investment ..? or u plan to sell it later
                  if i am in yours place will repair the MB .. repairing MB never being difficult if you do know how to read value and using DMM
                  so if you are ready to repair the MB.. start with high resolution photos from top and down side after removing the metal heat sink
                  • Storyteller12
                    • Jun 2020
                    • 624
                    Yes, that board will work. But that price is steep.
                    • nonsub
                      • May 2018
                      • 84
                      Actually I have a board EBT64174323 on the way that cost 140 $USD shipped so not bad (but shipping $$.) It should arrive this week.
                      As far as investment it is mostly stubbornness. It really bothers me that a TV only lasted 3years and with almost no parts available and would go in garbage. So with you guys helping me I will be most happy to get it back on the wall. I will have 2 X bad main boards leftover; I would like to troubleshoot them as a project if possible but I think BGA's are toast.
                      • nonsub
                        • May 2018
                        • 84
                        bad luck today... board stuck in customs and my fridge (also LG!) just dieded!
                          • 12187
                          • U.S.
                          #52
                          well the first thing is see if the compressor is still kicking on.
                            • 12187
                            • U.S.
                            #53
                            could troubleshoot the fridge right here, but theres a member whos little mind gets confused and starts complaining, maybe open it in the appliance section.
                            • nonsub
                              • May 2018
                              • 84
                              lol thanks! Yeah I'll spin up another thread. Every 5 years or so the water line coupler fails it seems (pretty high pressure in this building.) So woke up to a lot of water on the floor. My guess is it found it's way through the back cover and into electronics. I have no light/no sign of life. Will check the power boards fuse I guess
                                • 12187
                                • U.S.
                                #55
                                I see, hopefully the fuse popped and there's no damage.
                                • Diah
                                  • Feb 2013
                                  • 6370
                                  hope its not bad luck 2023 ..LOL
                                  my advice always to my friend and i do.. are to disable ice cube maker and the special Meat / Fish section at Korean fridge.. air flow door break after while or as you facing with water ..
                                  • nonsub
                                    • May 2018
                                    • 84
                                    That is funny so like you were saying... there is a sealed hatch at the back for the PSU but open it up and out pours water lol. So it sealed the water inside. Fuse is good though so will blast with alcohol then have to test components I guess.
                                    • nonsub
                                      • May 2018
                                      • 84
                                      oh thank goodness.... air blasted the board without removing, then flushed with 99 IPA, let dry and all good now
                                      • Diah
                                        • Feb 2013
                                        • 6370
                                        happy new years 2023
                                          • 12187
                                          • U.S.
                                          #60
                                          good to hear.
                                          • Michael Long
                                            No Standby Light on Samsung UN65MU6300FXZA with Mainboard BN94-12440E
                                            by Michael Long
                                            I had a Dead Samsung UN65MU6300FXZA with Mainboard BN94-12440E
                                            Dead / No Power / No Standby Light results after power company had three
                                            consecutive power outages on/off/on/off/on/off after which TV was rendered unresponsive.
                                            After exploring the issue found Mainboard was the fault. Then with research on this site determined IC1604 was the suspect. The IC1604 is a surface mounted device (SMD) EEPROM, Winbond Model 25Q40CLSIP. A read on this EEPROM came back with all FF FF FF FF FF in all registers blank and empty of data. I had a spare mainboard with intact IC1604 and utilized...
                                            09-13-2022, 06:55 AM
                                          • noinimod
                                            Sony 55X900E no standby light, no power. Replaced mainboard already
                                            by noinimod
                                            No standby red light, nothing
                                            This Sony has a separate AC->DC power adapter supplying 19.5V to the TV power board (JK3)
                                            Disconnected JK3 power board from main board, checked voltages on all the pin outs
                                            At a few pins I can see the power supply providing 19.5V to the main board
                                            Based on the service manual triage.. it seems to be pointing towards the power board (JK3) being the most possible culprit
                                            LED light turns on when I disconnect LED driver board ribbon from mainboard (so i thought it is the mainboard,...
                                            12-22-2021, 12:58 AM
                                          • stylishconsultant
                                            un60j620dafxza - Samsung No Display Problem
                                            by stylishconsultant
                                            Hi All,
                                            Need help.
                                            I have a samsung un60j620dafxza led tv. When I plug it in it has no display, no sounds, and no standby lights.
                                            So I opened the tv and disconnected the power to the mainboard and the backlight powered up. This according to many people says that this is a mainboard
                                            problem. I checked the voltage coming from the stb and I read 1.3 volts on pins 1,3,5 and 7 which are low volts instead of 13 volts which i think the lcd panel
                                            might be drawing too much power from the power supply that it prevents the right voltage going to the mainboard....
                                            09-04-2024, 03:26 AM
                                          • tvguy12012012120
                                            by tvguy12012012120
                                            02-07-2025, 05:13 PM
                                          • Mirenia
                                            Dell Latitude 7420 - Touchscreen not working since Mainboard replacement
                                            by Mirenia
                                            I've got a little "problem child": my Dell Latitude 7420 2-in-1, which had a faulty mainboard.
                                            I replaced it, but ever since, the touchscreen no longer works — and honestly, I’m running out of ideas…
                                            In Windows Device Manager, I just see an I2C HID Device with error code 10. Sporadically, the touchscreen is recognized correctly for just a few seconds, but I haven’t been able to determine under which circumstances this happens.
                                            The touchscreen also doesn’t work in UEFI/BIOS, although it’s enabled...
                                            03-30-2025, 06:47 AM
