Samsung UE40F5300AK blinking red light
  • Fergal22
    • Feb 2021
    • 50
    • United Kingdom
    I have the above tv that just shows a red light blinking twice 5 times, i have taken the back off and all the capacitors seem ok,
    When i disconnect the mainboard from the PSU all the led's light up blinking fast but as soon as i reconnect the mainboard back to the power supply i get the red light blinking again twice 5 times,
    I have attached pictures of the Mainboard, PSU and a small video (zipped) showing what happens when i disconnect the lead from the psu
    Any help would be appreciated
    • 12201
    • U.S.
    Re: Samsung UE40F5300AK blinking red light
    suppose thats usually a backlight issue, test cnm803, see the map/legend near it, report all voltages both in standby and turned on if possible, for example pin #14 ps-on, standby 0 volts, tv on 3.3 volts, etc.
    • sintv
      • Feb 2015
      • 37
      • scotland
      I replaced all leds in a samsung recently but noticed what looked like one that was out giving a black smudge. Lasted for 2 weeks then set went off with blinking led. Turned out half a row was faulty though I couldnt use old leds as they were blue. Replaced faulty led, looked like it had finally went s/c, and set now works. So flashing led is probably faulty backlights.
      • Fergal22
        • Feb 2021
        • 50
        • United Kingdom
        Hi thanks for the quick replies
        @nomoresonys
        Power on
        1 = 7
        2 = 2.3
        3 = 7
        4 = 0
        5 = 7
        6 = 2.4
        8 = 0
        9 = 0
        10 = 0
        11 = 4.36
        12 = 4.94
        13 = 4.36
        14 = 3.0
        Power off all read 0 except
        14 = 3.0
        12 = 4.94
          • 12201
          • U.S.
          looks like the powerboard isn't turning on fully, maybe unhook backlight connector and do the same test, lets see if there's any change in those voltages.
          • Fergal22
            • Feb 2021
            • 50
            • United Kingdom
            Hi, sorry for the delay in replying,
            Power on with back light connector disconnected
            1 = 8.5
            2 = 2.95
            3 = 8.5
            4 = 0
            5 = 8.5
            6 = 2.1 to 2.85 fluctuating
            8 = 0
            9 = 0
            10 = 0
            11 = 5.23
            12 = 5.23
            13 = 5.23
            14 = 3.28
            14 = 3.28
            12 = 5.23
              • 12201
              • U.S.
              try the hairdryer test, with everything plugged in heat up the electrolytic caps for a couple minutes then try the tv, don't wait til it cools off, try it while its still hot.
              • Davi.p
                Hobbist Tech
                • Sep 2009
                • 4333
                • Italy - Milan
                post a picture of the back of power board
                • todor
                  • Feb 2023
                  • 16
                  • България
                  Hello, with the main board turned off, the 220v power supply must be turned on, the backlight should work normally without blinking. If it blinks, there is a problem with it.
                  • Fergal22
                    • Feb 2021
                    • 50
                    • United Kingdom
                    Tried doing what you suggested but still no joy, back lights still blink for a few seconds then go out
                    Pictures attached as requested
                    So you reckon it's the back lights then?
                    • todor
                      • Feb 2023
                      • 16
                      • България
                      if the backlight blinks when the main board is turned off, the backlight is wrong.!!!! It should light up steadily and without flickering. When only the power is turned on and the backlight works, there should be about 380-390 v on the 450v capacitor. If there is a fluctuation or is below 370 in not working properly pfc
                      !!!This board is finicky and may need to rewrite the emc which is a complicated process
                      • Davi.p
                        Hobbist Tech
                        • Sep 2009
                        • 4333
                        • Italy - Milan
                        Hi, watch the under side on the center left, near the optocoupler in the secondary side there is a small sot23 called QM85, if i can see, that has to be changed, tell me its marking first, don't buy it from chinese market.. if you have spare old unuseful boards take it from there..
                        before do another little test with the power board alone, test the main board outputs, if them are ok, place a resitor on the b5v , like 5,6ohm 5w, and a light bulb to the b13v, max 30w, if the voltages drops much then the thing to do is confirmed
                        • matty24
                          Samsung UE50MU6172 - red light blinking
                          by matty24
                          Hello. I have problem with Samsung UE50MU6172.
                          TV won't turn on, red standby light is blinking.
                          Power supply BN44-00807A is fine. I replaced it with the new one.​
                          Main board BN41-02568B (BN94-12530E)
                          I've read a dump (W25Q40CL). Can someone check it od fix it for me?...
                          03-02-2025, 08:57 AM
                        • Michael Long
                          No Standby Light on Samsung UN65MU6300FXZA with Mainboard BN94-12440E
                          by Michael Long
                          I had a Dead Samsung UN65MU6300FXZA with Mainboard BN94-12440E
                          Dead / No Power / No Standby Light results after power company had three
                          consecutive power outages on/off/on/off/on/off after which TV was rendered unresponsive.
                          After exploring the issue found Mainboard was the fault. Then with research on this site determined IC1604 was the suspect. The IC1604 is a surface mounted device (SMD) EEPROM, Winbond Model 25Q40CLSIP. A read on this EEPROM came back with all FF FF FF FF FF in all registers blank and empty of data. I had a spare mainboard with intact IC1604 and utilized...
                          09-13-2022, 06:55 AM
                          09-07-2024, 05:50 AM
                        • 3DDD
                          Samsung UE46D6100 LED TV blinking red light indicator
                          by 3DDD
                          Hello, I have a Samsung UE46D6100. It cannot be turned on, only the red status LED flashes, the power supply part bn44-00458a gives an output of 5V(A), it is probably functional. I don't know where to look for the error, according to the video it should be a faulty mosfet. I found a mosfet marked WAAH, I don't know what it is. Can anyone help me?...
                          02-20-2025, 12:51 PM
                        • KYBOSH
                          Trying To Fix: Samsung UN50TU7000 - Weird Fading Screen then Red blinking light
                          by KYBOSH
                          Picked this up to resurrect.
                          When I plugged it in it comes on for about 1 minute... after a minute the screen blacks out and I gets blinking red lights on the power button.
                          I read that a common issue with this model is a failed BGA so I ordered a replacement on eBay.
                          Sometimes the TV would produce an expanding blob on the screen before going black.
                          See Video here
                          I ordered a replacement board off of eBay and installed it tonight and got the same behavior.
                          Did I get another defective board or is there an issue with...
                          09-16-2024, 07:48 PM
