Samsung "MU" series (UN, UA, UExxMUxxxx) fault dump IC1604 25Q40...
    Hello, TV Saamsung UE50MU6102K, BN94-12432B, BN41-02568B damaged W25Q40CL insert, please repair.
      Ready. Try...
        Thank you, I will let you know about the results.
          Hi Lotas, can you fix the file, please?
          I tried some other files, but I managed only to have the stand-by led on.
          Thank you
            Thank you
            Try.
              Hi Lotas,
              I tried with the fix file but the TV set is dead. The standby LED turns on for 1 sec every 15 sec. The standby voltage from 8v goes to 13v. At first, the TV was totally dead. Now it looks like there is some life in it but there must be a hardware problem in the mainboard.
              Anyway, I want to thank you for your effort and time. I wish you the best. Thank you.
                The TV does not turn on, there is no standby mode! SAMSUNG UE55mu6192 ver01
                  Try.
                    Originally posted by lotas View Post
                    Try.
                    Thank you very much!! Everything is working!
                      Hi Lotas UE55MU6172 IC401 can you fix please.
                      Regards,
                      Pat.
                        Regards,
                        Pat.
                        I can, but it (dump) is working for you, your problem is not in it.
                          Thank you Lotas, much appricated.
                            Hi Lotas, my TV model is UN50MU6100GCZB, Board Code: BN41-02568B from Argentina. I'm having the same issue as another user before. The standby LED turns on for 1 sec every 15 sec. When Flashing an incorrect bin, the board stays completely dead. So I guess it could be bios related. could you help me? Thanks in advance
                              Strange damage to the dump, usually if in this series the MU dump is damaged at the beginning of the dump, then the TV's standby LED does not light up at all. Try this one, I adjusted it a little, and don't forget about the status register after recording the dump.
                                Hello
                                Please I need your help with this mb bn41-01587e
                                5vdc exist but standby led not light and no action with power button
                                IC 1401 should be reprogrammed or what?
                                  Dear Sir can you help me with dead main board ( BN41-01587) for Samsung ua40d6400un and power board (BN44-0427A)
                                  i uploaded the flash files from 24c02 (IC 1205) & 24c512 (IC 1401)
                                  A5 & 3.3 vdc are exist.
                                  thanks in advance.
                                    Where did you get the idea that the problem is in these firmwares, if there is no standby mode and the LED is not on, then a common problem in this chassis is IC204 (stabilizer from 5v to 3.3v) and micom Weltrend, check the resistance at 1.2 pin IC203 relative ground and is there 3.3v power on these pins
                                      Thanks for your your support. i found that sub eeprom (24c02) is connected to this ic1203 so i thought this may be the problem.
                                      I measured the regulator and i/p 5.3 v & o/p 3.3 v so it is good, also the voltage at pin 1&2 3.3v and no short with ground. i tried to press the reset button but nothing happened
                                      how can i check ic1203 (61P805) is healthy ??
                                      does it need programing? if yes can it be done by CH341?
                                        What initially happened to the TV? In service mode, at the point you clicked on “Micom Update” and after that the TV stopped turning on?
                                        If yes, then the firmware has been erased in micom, you need to program it.
                                        And also, you have some strange dump 24C512, or it is so badly damaged or poorly read, try this one.
                                          Hi lotas,
                                          can you help me with this firmware???
                                          Samsung UE55MU6400U
                                          M/B BN41-02568B (BM94-12401R)
