Hi, this has panel problem for certain (AUO panel), in the troubleshooting process, after pressing ON button i am with set making a short lamp of backlight with status light shortly white then green/yellow repeated, in this situation main board remain powered and also tcon with all their correct output voltages. I cant find in the service manual description of this state, can you brief me ? thanks
Sony KDL-42W705B panel problem
Re: Sony KDL-42W705B panel problem
Hi, this has panel problem for certain (AUO panel), in the troubleshooting process, after pressing ON button i am with set making a short lamp of backlight with status light shortly white then green/yellow repeated, in this situation main board remain powered and also tcon with all their correct output voltages. I cant find in the service manual description of this state, can you brief me ? thanksLast edited by lotas; 01-26-2023, 08:20 AM. -
Yes i was just watching now YouTube videos saying this, the tv needs an update because i have changed tcon board that was broken also, my question is, after upgrading i will have latest software installed , some years ago i bought two pmic chips to repair original tcon, if i succesfully repair it then mainboard probably will not recognize it as an original component and needs a new update, but since no more new versions available i need to copy tcon eeproms or what? thanks
ps: the panel is not already repaired, needs further effortsComment
I have flight over the doubts and done the usb update, surprisingly immediately appeared a near perfect image, the first time i have seen one, there are some intermittent black lines , there was a tape masked pin made by me and there is a shorted burnt trace onto the last tab, therefore there is more work to do...Last edited by Davi.p; 01-26-2023, 01:08 PM.Comment
The second question, the burnt traces on the cof tab, the burnt plastic substrate made an air gap between two traces (Signals HC1, HC2, two signal clocks that results shorted together), putting a paper band through it made no difference in the shorted signals, the burnt sign ends in the ACF tape area and i'm convinced that heat modified molecular structure so the glue is now always conductive in that point, how can i bear with this? I thought that pressing or sliding a very sharp cutter i can destroy the trace, is there a better way?Comment
Bad news.. very bad news, after the replacement tcon brokes i have put back original tcon, the previous situation where it requests for an update returned, but now it refuses to load it!!! My premonition was right!!
I ask to experienced users: i have noticed that plugging the power in when keep pressing On button brings to a different state with blue led steady in standby position, leaving button and pressing it again if i remember brings to a pulsating white led but no update beginning, also in subsequent boots, what stands for this function?Comment
2. If the update does not pick up, then rename your update file to "upgrade_loader.pkg" (without quotes).Comment
Executed a forum search here, two things came out, no one knows about the blue led procedure, except the Sony aut. serv. centers obviously, the method of renaming the file did not worked so i think i will have to think a different method first..Comment
Maybe i am out of slime.. executed renaming ( same folder), put pendrive in tv, done the blue light procedure, waited pendrive led stop after few pulses, removed power, reinserted, white led does 3 - pause - 7 pulses, then turned on with key, tv turned on with backlight an maybe an image, tcon is broken, i see only vertical many colors lines. Thanks Lotas.. again..Comment
by perzyk23Good morning,
I have a problem with Lenovo T580, which after error code 0288 suggests a problem with the display. I checked the display and it works on another laptop. I replaced the display cable with a new one. I programmed another BIOS (downloaded from this forum) and I still have the problem of a dead display - there is an image via HDMI, and the system does not detect the built-in LCD at all. The problem appears to be hardware. What can I check to confirm or disprove this? I found many threads on the Internet related to this problem 0288, but without specific solutions. Please advise.... -
by iglitareHi,
Or is it always a bad/shorted... -
by ChrissygizmoHello again everyone,
This is my latest mission, to try getting this Sony tv back to normal working order…
I've only just got it today, when you power it up everything is as should be, in fact it works perfectly for a few minutes then the screen starts getting horizontal lines on & eventually the full screen goes back, I will upload photos of the problem & also some photos of the board etc. You might notice that I'm busy trying the tape method, I'm not sure exactly where the clock lines are so I'm just guessing & hoping for the best lol . I've already tried... -
by multimesutHello friends,
A yellow light was flashing on my monitor. It was like it was constantly cutting power. When I opened it up, I saw that the big capacitor in the high voltage line was leaking. I replaced it. When I turned it on for the first time, it had the same problem again. But then, interestingly, it got better. The yellow light was on steady. But the monitor wouldn't turn on. When I examined them with a thermal camera, I saw that the Fli5961-LF reached 50 degrees Celsius and the EM636165TS next to it reached 100 degrees Celsius and was drawing high current on the motherboard....1 Photo-
11-13-2024, 07:00 AM -
by r3vsEngIT65x900h with the panel from a 65x930d.
900H: model yr 2020, Samsung panel
930D: model yr 2016, Innolux panel
spec wise the panels are the same. the drivers and tcons are obviously different but what made me want to give this a try is that the wiring diagrams for the data signals going into the tcon for each tv were nearly identical. there are only a couple pins that i am unsure about and that is what brings me here.
the 930d has the DPS board where the 900h has none, however, if you follow the pins to the BM1 it would appear that the signals...07-11-2023, 11:11 AM - Loading...
