Hello, I recently got a free Sony XBR-65X810C from my neighbor and it works great except for a bluish tint caused by blue LEDs (I checked the vents and the LEDs are giving a blue light instead of white.). I plan on replacing the LED strips and was wondering how difficult it is to do that on this TV. Is the LCD panel glued down? Easy to lift off using suction cups? I appreciate any tips or suggestions!
Sony XBR-65X810C - LED Replacement
Re: Sony XBR-65X810C - LED Replacement
https://www.youtube.com/watch?v=mofOjGM9SOk -
This video may help you get a idea of whats involved
https://www.youtube.com/watch?v=mofOjGM9SOkComment
by timonix20hello everyone I am looking for a solution for my tv, I think corruption of the eemc,
the TV starts, LG logo, then nothing (rear backlight)
no reaction to rear command or infrared
the usb procedure that I tried on the LG site is a procedure with the screen and the remote control so I can't.
I have a chance with a usb procedure or other if you have .bin
if any people have this main board
Sony LG 60la620s EAX64797004 (1.1)
thank you... -
by FZGHello there, helpful forum people!
I am in the process of fixing an old (ca. 1990) Sony BVM1410PM CRT monitor and need some help. The PSU board of this monitor had failed and I had to replace quite a few capacitors and other parts but now - with my limited knowledge - I ran into a wall.
On the board there is a coil choke that has failed (tested with inductance meter) and I don´t know what to replace it with. According to the device´s service manual the part in question is a "Coil, Choke 525 uH (Sony P/N: 1-459-643-11)".
The original part... -
by PipolupsHi there !
I'm having an issue for several weeks with my quite old K70 LUX RGB keyboard. I haven't used it for few months, and once I setup up again my desktop computer, I got several dead LEDs on that keyboard. I tried the Corsair troubleshooting thing (disabling options in iCUE, ...) but nothing changed so I conclude that for some reason some LEDs went in retirement...😅
Decision taken to change these LEDs as I have access to desoldering iron and binocular magnifier, I wrote a ticket to tech support, hopping to obtain the LEDs reference and... They refused to tell me 🙄...10-08-2024, 11:58 AM -
by ltiI'm looking at the transmitter from these wireless headphones because the range is too short. One of the LEDs failed many years ago (nine years ago - I found pictures that I took then) and was simply bypassed to make them work again, but it seems like the range has been degrading since then. They're near-IR LEDs (I can see them dimly lit red, so they aren't the standard 940nm), and I haven't been able to find the actual wavelength. Does anyone here happen to know what replacement LEDs I should use? Maybe I can adjust the transmitter was well while I'm in there, or there's another fault. I should...
by labelloHi guys I have this tv with this problem, I found it one strip led broken so I decided to change all of them (4) but the problem remains, the tv turn on wit sound led on but after second rebottet and then give me red led blinking (6 times) probably is something in the board broken, i replaced some capacitor that have lower value , take some measurements you're will se on the picture, but I don't have any schematic for this tv. Every reply is accepted! Thank you6 Photos
- Loading...
