Samsung UN70NU6900F no picture and no sound
  • jchang
    • Jul 2016
    • 9
    Hi all
    I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
    Symptom:
    No picture no sound.
    When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
    No sound at all.
    What I tried:
    1. I tried unplugging the left or right ribbon cable to the panel, if I unplug EITHER cable, the LED backlight stays on and gains sound(smart hub sound when turned on) TV now stays on. If I plug both, I get the same symptom above.
    2. If I unplug the power cable from the power board to the mainboard (the mainboard gets no power), the LED backlight stays on. No sound.
    3. If I unplug EITHER the left or right panel film ribbon cable(third pic, brown cable), the power LED will STAY ON. If I press the hub button I get the smart TV sound. but no image whatsoever.
    4. I tried the tape method. simply put as long as I keep the 2nd pin from the right side from either the left or the right cable(doesn't matter both), all ribbon cables are plugged in, the backlight stays on and I get the hub sound. But still no picture. I tried covering different combinations of pins prob 10 attempts, but I got no image at all.
    I ran out of ideas and had to post here to ask for advise to you guys. Please help!
  • jchang
    • Jul 2016
    • 9
    Re: Samsung UN70NU6900F no picture and no sound
    Reserved
    • Storyteller12
      • Jun 2020
      • 624
      There is a thread on this tv already I believe.
      But basically it’s a panel issue as you have confirmed that it stays on if either side is unplugged from the panel. You can check for shorted caps on the panel/ buffer board. Most likely tape method is your best shot though. Just haven’t found he right pins to cover.
      It’s a tedious process sometimes
      • jchang
        • Jul 2016
        • 9
        Yea, I saw that post but did not help me.
        Tried the 25/30DCV from R13236 to VGH with wire and 84th pin tape did not help. I get 0.1~0.2 mV on that R13236 register pin when TV is one(without and with ribbon, same throughout the settings)
        Need little light on finding that right pin.
        I also noticed that if I plug in either ribbon after turning on the TV after unplugging the ribbon, I get the full picture perfectly. Turn it off and it does that blinking again.
        • Storyteller12
          • Jun 2020
          • 624
          https://www.badcaps.net/forum/showthread.php?t=105591
          Post #6
            • 12206
            • U.S.
            Thats a good one, I'm still wondering how Diah figured out exactly which lines to block, Diah you must be a dam tv whisperer, great work. reference from the movie "The Horse Whisperer" 1998, https://www.imdb.com/title/tt0119314/ pretty good movie.
            • jchang
              • Jul 2016
              • 9
              Tried masking 14~23(9pins), but still blinking(twice).
              • Storyteller12
                • Jun 2020
                • 624
                It’s trial and error then unfortunately.
                Keep us posted if you make any progress
                • Mgiffune
                  by Mgiffune
                  06-09-2024, 10:28 AM
                • Ierwin
                  by Ierwin
                  05-13-2025, 03:31 PM
                • marekk
                  Samsung QE55Q67RAT no sound and bad picture when streaming
                  by marekk
                  I got Samsung 55 inch QLED QE55Q67RAT where there is no sound at all and when using youtube for example picture is not clear and noisy.
                  I have swapped Burr-brown 88002A chip on the mainboard but didn't help, different set of speakers didn't help either
                  Mainboard is based on pcb BN41-02695A BN94-14007B
                  I will appreciate any help
                  Many thanks
                  Marek...
                  05-29-2025, 02:23 AM
                • kca
                  Samsung UN60F8000BFXZA ~ No Picture or Sound - 5 Res Light Blinks
                  by kca
                  Hello all ~
                  I’m working on this Samsung 60” LED and purchased a new main board a couple of days ago that did not fix the 5 blink issue. The original main board’s HDMI ports (all 4 of them) failed to work and no amount of reflow remedied that.
                  This 5 red light blink code on the front panel LED is followed (about 15-20 seconds afterward) by an automatic reboot, and results in 5 more red light blinks. Then the entire cycle repeats itself indefinitely.
                  No picture. No sound.
                  I tested all the voltages coming out of the power supply...
                  10-12-2023, 05:23 PM
                • stinger
                  Samsung UN70TU6980FXZA no sound no picture but does have backlights
                  by stinger
                  When I turn tv on, the backlights come on but there is no sound or picture. I have read that these tv's have problems with the panels going bad but the "no sound" has me questioning if the main board is bad. Is there a way to troubleshoot the main board to determine if that is the problem?
                  04-17-2024, 03:06 PM
