Sony KDL60w685a need firmware update
  • madyoyo
    • Aug 2018
    • 12
    • france
    Hello everyone.
    I replaced the mainboard on a KDL60w685a, and now it blinks green and yellow. I think i need to update the firmware. But it's not available from Sony website.
    Does anyone have the firmware for this TV?
  • lotas
    • Jan 2016
    • 4708
    • Russia
    Re: Sony KDL60w685a need firmware update
    Maybe all the same KDL-50W685A (50, not 60).
    • madyoyo
      • Aug 2018
      • 12
      • france
      Oops, i made a typo, its KDL50W685A, 50 inch panel
      • lotas
        • Jan 2016
        • 4708
        • Russia
        I understand that you need firmware 4.600?
        • lotas
          • Jan 2016
          • 4708
          • Russia
          sony_tvupdate_2013_4600_eua_auth
          https://drive.google.com/file/d/1gN9...3DhRfExSH/view
          • madyoyo
            • Aug 2018
            • 12
            • france
            Thank you. The mainboard in my tv was dead, so, i bought one on ebay. It now gives me a red and yellow light, from what i understand it needs to have the firmware updated to recognize the panel.
            Ps: i can't edit the first post, maybe a moderator can fix the model number, in case someone needs this firmware
            • nomoresonys
              • 12218
              • U.S.
              so what is your result?
              • madyoyo
                • Aug 2018
                • 12
                • france
                Sorry for the late answer, i hadn't much time to take care of this. The firmware worked fine, another TV saved from the landfill
                • nomoresonys
                  • 12218
                  • U.S.
                  Excellent, glad to hear it, be sure to save that firmware, never know when you might need it again.
                  • gtferrari
                    • Aug 2017
                    • 10
                    • Greece
                    Originally posted by lotas
                    Hi! Can you please upload the firmware again? I have the same tv with 5 red blinks and I want to try the firmware. I know that the say that it is T-CON problem but giving a try with the firmware may help.
                    • lotas
                      • Jan 2016
                      • 4708
                      • Russia
                      https://drive.google.com/file/d/1Szr...ELRNuV12-/view
                      • gtferrari
                        • Aug 2017
                        • 10
                        • Greece
                        Thank you. I have put the file in a fat32 usb on the root folder but when I turn on the tv it does start the firmware upgrade. Instead it starts the 5 blinks.
                        Has anyone experienced the same problem?
                        I can measure the 12V on the t-con (which in this model is embended on the panel flex and I can't just replace it) that comes ON and after a second OFF. Any suggestions?
                        • lotas
                          • Jan 2016
                          • 4708
                          • Russia
                          For the update to take place, the TV must go into update mode, that is, the LEDs must blink one after another, try disconnecting the cable from T-CON and turning it on without the panel, then connecting it and turning it on again. (Or disconnect the cable from T-CON and turn on the TV carefully Without distortions, sharply insert the cable back when the TV is turned on, just be careful when inserting this cable!).
                          • gtferrari
                            • Aug 2017
                            • 10
                            • Greece
                            I had already test to start the TV without the T-CON cable with no luck. The same problem. How to put the TV into update mode? I also tried to reset the TV with Vol- and Power but it won't do it. I have a white light for 1 second only and then the red blinks starts. I have measured all the capacitor and the fuses of the T-CON and they are ok without any short on the capacitors and no blown fuses. I have seen in videos that the TV should starts normal (without video signal on the screen of course) but mine it starts the blinks immediately. If the T-CON was faulty shouldn't the TV started normally?
                            • lotas
                              • Jan 2016
                              • 4708
                              • Russia
                              When you turn on the Sony TV, a self-diagnosis occurs, and if something is not working properly, it blocks the loading of the TV itself and displays an error.
                              • Diah
                                • Feb 2013
                                • 6421
                                check yours LED BL... put yours DM on each group and measure the high and low it goes at the point 1 second blink
                                • nomoresonys
                                  • 12218
                                  • U.S.
                                  Doubt it's a firmware issue, if you get 5 blinks and no boards were changed, then prolly is a tcon related issue, pretty sure there's no count number for tv needing update, if it needs update it goes with the two color blinking BUT sometimes a tv needs updated even if it isn't throwing the 2 color code.
                                  • gtferrari
                                    • Aug 2017
                                    • 10
                                    • Greece
                                    I have manage to fix the 5 blinks. The problem was the tcon cable that the owner has destroyed when he opened the TV. And now I am dealing the original problem of the TV. It makes a noise on the tcon board and one of the flex of the panel is on fire and you can see it on the photo. I have found a video with the exact same problem. https://m.youtube.com/watch?v=MXWlbXeuyig
                                    Does anyone have seen this problem? If I remove the cable from the half of the screen the other half works fine!
                                    • flexto
                                      • Jan 2024
                                      • belgium
                                      Hi, does anyone know if the firmware above "sony_tvupdate_2013_4600_eua_auth" would work with a KDL-46W905A ?
                                      • flexto
                                        • Jan 2024
                                        • belgium
                                        Update and solved: it worked
                                        • thesteve
                                          Sony experts? 2nd bricked BAT Board after firmware update KDL-55EX720
                                          by thesteve
                                          So I bought another main board from eBay and the same thing happened.
                                          I got the firmware file from the Sony website. My model was listed and everything matched.
                                          sony_tvupdate_2011_4027_aaa_auth.zip was the file.
                                          Extracted to a folder: "sony_dtv0FA10A01A0A1_00000301"
                                          with file: 00000301_07e8046a.bin inside.
                                          Loaded it into the root of an otherwise empty USB thumbnail bought from around the same time as the TV. Not too old, not too new.. under 2Gig.
                                          The file reads perfectly. Lots of "disk activity"...
                                          07-17-2021, 04:59 PM
                                        • ahmedtou
                                          HOW CAN I UPDATE HL-DT-ST BD-RE GGW-H20N XA02
                                          by ahmedtou
                                          help me please
                                          I have an HL-DT-ST BD-RE GGW-H20N with ROM version: XA02.
                                          When I tried to burn a 25GB Blu-ray disc using ImgBurn, I got an error.
                                          I will share all the details with you, including the disc information.
                                          Code:
                                          HL-DT-ST BD-RE  GGW-H20N XA02 (ATA)
                                          Current Profile: BD-R
                                          Disc Information:
                                          Status: Empty
                                          State of Last Session: Empty
                                          Erasable: No
                                          Free Sectors: 12,219,392
                                          Free Space: 25,025,314,816 bytes
                                          Free Time: 2715:27:17 (MM:SS:FF)
                                          Next
                                          08-27-2025, 08:49 AM
                                        • TheUser
                                          Thinkpad Docker G2 Type-C 40AS - Firmware Unknown
                                          by TheUser
                                          Hello to everyone ,
                                          This is my first post here, and i would like to share with you a small story in case you can help me.
                                          Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
                                          All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
                                          I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help...
                                          02-10-2024, 02:07 PM
                                        • dkneyle
                                          Sony KDL-46HX850 Can't upgrade/update firmware
                                          by dkneyle
                                          Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
                                          Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
                                          09-25-2024, 10:44 PM
                                        • rumpumpel1
                                          ThinkPad X12 Detachable Gen 1: keyboard after firmware update without function
                                          by rumpumpel1
                                          Lenovo System Update offered me an update for the firmware of the Folio keyboard for my X12 Detachable Gen 1. The update got stuck and after 20 minutes I switched off the laptop. Since then, the keyboard and touchpad have been without function. Does anyone know how I can revive it?
                                          10-24-2024, 08:59 AM
