Samsung DM48E TV
  • KSnod
    • Jan 2023
    • 3
    Samsung DM48E TV
    Hello everyone, I have a problem that has me scratching my head. I have a Samsung DM48E monitor that was used as a display for advertising. The screen seems to be zoomed in too far to se any Icons on the screen. I have hooked a mouse to it through usb, and the pointer seems overly large, and just moving it around on the screen I cannot access any other functions. I hooked up a keyboard (usb) and was able to cycle through sources on the home screen just by using Function key F6 and access home F5. I am looking to find a fix for the zoom so I can actually see the icons on the home screen. Also the remote acts like it is locked out because I cannot access any functions with it or even turn the monitor on or off. I have tried two different remote that work on other samsung tvs but am at my wits end. Please help! thanks.
  • R_J
    • 9625
    Re: Samsung DM48E TV
    I suspect it could have been part of a video wall (multiple monitors to display one image)
    I suspect you need to set it to video wall OFF
    Can you see any of the menu?
    Do you have the user manual?
      • 12331
      • U.S.
      did you try hooking it up to a different device?
      • KSnod
        • Jan 2023
        • 3
        I have hooked it to two different devices, the picture is clear and viewable. it has sound and works properly but the remote still will not control sound or picture aspect or on\off. I cannot access the menu or see it. I found a manual online but it does not address the remote not functioning. I cannot access the menu from the control button on the tv either.
          • 12331
          • U.S.
          and you are sure you have the right remote, guess they look like these: https://www.ebay.com/sch/i.html?_fro...fLoc=2&_sop=15
          • Chrissygizmo
            by Chrissygizmo
            02-10-2025, 12:33 AM
          • Chrissygizmo
            samsung galaxy ao2s very temperamental after screen replaced
            by Chrissygizmo
            Hi , I've recently replaced the screen in my Samsung galaxy ao2s, at first it wouldn't even turn on, it had the charging symbol on the screen when plugged in but the green circle wasn't going around to show it charging....
            Ive eventually managed to get it on and working but it's very temperamental...
            The battery icon always reads as 50% , when the phone goes into lock screen mode i sometimes can't get the screen back on unless I plug the charger in to get it to light up, also it keeps putting the camera app on.. u think it could be something to do with the side buttons. ...
            05-26-2024, 12:05 AM
          • JunkmanJimbo
            Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and won't turn off
            by JunkmanJimbo
            Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and then tv won't turn off.
            No picture. No sound that I can tell. Backlights are on and have been checked. Flashlight test no image on screen. I replaced the Eprom chip hoping that was the problem but nothing changed.
            Please help. Thanks in advance!
            08-12-2025, 11:45 AM
          • Kiberge
            Samsung LH82QENELGC/EN Help needed - Static line on screen
            by Kiberge
            HI guys!
            I've got a Samsung LH82QENELGC/EN with a problem and need some advice and I hope this is the forum to use?
            I'm from Norway so I'd like to apology in advance if my description of the fault is kind of simple or the names on the components are way off. 😊
            the TV is powering up, working as normally and picture is all good, except a 1.5-inch-wide vertical line of snow/static across the screen.
            This TV is a Signage Display/Public Display version and it's been used at my work for 4-5 years showing commercials 24/7. The fault occurred when...
            04-22-2024, 11:28 AM
          • Ryan.man
            by Ryan.man
            02-04-2025, 12:23 PM
