Hello everyone, I have a problem that has me scratching my head. I have a Samsung DM48E monitor that was used as a display for advertising. The screen seems to be zoomed in too far to se any Icons on the screen. I have hooked a mouse to it through usb, and the pointer seems overly large, and just moving it around on the screen I cannot access any other functions. I hooked up a keyboard (usb) and was able to cycle through sources on the home screen just by using Function key F6 and access home F5. I am looking to find a fix for the zoom so I can actually see the icons on the home screen. Also the remote acts like it is locked out because I cannot access any functions with it or even turn the monitor on or off. I have tried two different remote that work on other samsung tvs but am at my wits end. Please help! thanks.
Samsung DM48E TV
Re: Samsung DM48E TV
did you try hooking it up to a different device?Quit because THIS SITE LETS A ROGUE MEMBER TYPE ANY GARBAGE HE PLEASES AND THE POWERS THAT BE NEVER DO ANYTHING ABOUT IT SO HE NEVER QUITS. THEN YOU GET A PENALTY FOR RESPONDING TO HIS ATTACKS. BEEN GOING ON FOR WAY TOO LONG. DONE SUPPORTING A SITE THAT ALLOWS THIS BS.Comment
I have hooked it to two different devices, the picture is clear and viewable. it has sound and works properly but the remote still will not control sound or picture aspect or on\off. I cannot access the menu or see it. I found a manual online but it does not address the remote not functioning. I cannot access the menu from the control button on the tv either.Comment
and you are sure you have the right remote, guess they look like these: https://www.ebay.com/sch/i.html?_fro...fLoc=2&_sop=15Quit because THIS SITE LETS A ROGUE MEMBER TYPE ANY GARBAGE HE PLEASES AND THE POWERS THAT BE NEVER DO ANYTHING ABOUT IT SO HE NEVER QUITS. THEN YOU GET A PENALTY FOR RESPONDING TO HIS ATTACKS. BEEN GOING ON FOR WAY TOO LONG. DONE SUPPORTING A SITE THAT ALLOWS THIS BS.Comment
by ChrissygizmoHello everyone, I’ve just been given a Samsung UE55JU6800K smart tv as it had white spots on the screen due to the led lenses falling off. After refitting them & putting the tv back together I thought it was a nice easy fix for a free bedroom tv , then I tried it before screwing the back into place. I realised that the right side of the screen was darker than the other side, I removed the screen again as I thought the backlights had failed but they are fine.
I put the screen back in place & turned it back on . The screen seemed to be ok again but different screens on the same... -
by ChrissygizmoHi , I've recently replaced the screen in my Samsung galaxy ao2s, at first it wouldn't even turn on, it had the charging symbol on the screen when plugged in but the green circle wasn't going around to show it charging....
Ive eventually managed to get it on and working but it's very temperamental...
The battery icon always reads as 50% , when the phone goes into lock screen mode i sometimes can't get the screen back on unless I plug the charger in to get it to light up, also it keeps putting the camera app on.. u think it could be something to do with the side buttons. ...05-26-2024, 12:05 AM -
by JunkmanJimboSamsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and then tv won't turn off.
No picture. No sound that I can tell. Backlights are on and have been checked. Flashlight test no image on screen. I replaced the Eprom chip hoping that was the problem but nothing changed.
Please help. Thanks in advance! -
by KibergeHI guys!
I've got a Samsung LH82QENELGC/EN with a problem and need some advice and I hope this is the forum to use?
I'm from Norway so I'd like to apology in advance if my description of the fault is kind of simple or the names on the components are way off. 😊
the TV is powering up, working as normally and picture is all good, except a 1.5-inch-wide vertical line of snow/static across the screen.
This TV is a Signage Display/Public Display version and it's been used at my work for 4-5 years showing commercials 24/7. The fault occurred when... -
by Ryan.manHello everybody! Posting this in hopes somebody has some expertise that leads to a clear path of troubleshooting that saves me a lot of time!
This time the original cable broke too close to the screen, it can't be fixed without tearing the screen... - Loading...
