Philips 43PUS6703/12 screen flickering intermittent
  • fanaticgames
    • May 2017
    • 138
    • italy
    Hi guys,
    I have this philips with this defect, I tried cleaning the flats of the t con but nothing changes, is the screen the problem??
    https://streamable.com/0zl6y3
  • William1967
    • Nov 2017
    • 203
    • Netherlands
    Re: Philips 43PUS6703/12 screen flickering intermittent
    The display is the culprit, tape of some gate lines and maybe it will work.
    • Ado02
      Lenovo Thinkpad X1 Gen 10 - Flickering Screen
      by Ado02
      We recently replaced the OLED screen on a Lenovo ThinkPad X1 Gen 10. After about a month, the replacement screen began to flicker. Initially, updating the IntelĀ® IrisĀ® Xe graphics driver resolved the issue for about a week. However, when the problem recurred, updating the driver again had no effect.
      The flickering only occurs once the system reaches the Windows login screen. Interestingly, if we disable the Intel GPU driver or connect the laptop to an external monitor, the flickering stops. We have tried installing two different replacement screens,...
      12-16-2024, 02:33 PM
    • Ryan.man
      by Ryan.man
      02-04-2025, 12:23 PM
    • survivalbloke
      HP ENVY HP 13-aq1013dx - screen flickering black if using touchpad or external mouse
      by survivalbloke
      SN: 8CG0213H8W
      ProdID 3C311UA
      This device came in due to the screen flickering if you use the touchpad or external mouse. It will flicker black when this occurs. If you use the touchscreen, the behavior does not appear. Also, if connected to external monitor, the external monitor is not affected by the flickering. I did a good amount of research on this, and concluded that it is due to the display driver. HP does not offer Windows 11 drivers for this model so I got the replacement drivers direct from Intel. I installed them and the problem...
      05-08-2025, 12:21 PM
    • smic717394
      by smic717394
      07-25-2024, 10:16 AM
    • RetroComputingGrotto
      LG 42LN540V LED Backlight Flickering After Replacement When Connecting The Screen
      by RetroComputingGrotto
      This TV has been on the wall in our reception area for around 10 years and the other day the backlight failed. You could see a feint picture so we knew the screen was OK. I took the TV apart to get to the failed backlight and inject voltage in to each half of the LED strips to identify which ones had failed and 4 needed replacing. I ordered a set off of Amazon and they arrived the next day.
      On fitting the new LED strips I plugged in the TV was blinded by the light!!
      It was only when I partially put it all back together (including the screen) that...
      10-23-2024, 04:17 AM
