Vestel 17MB230 and panel VES400UNDS-2D-N11
  • 147selespeed
    • Dec 2022
    • 8
    • España
    First, sorry for my bad English.
    I have installed this board in my TV and has a VES400UNDS-2D-N11 panel.
    The tv turn on the panel but don't show anything.I can't access in the service menu.
    Is it possible to fix it?
    My old remote control works on a Vestel 17MB97.Should it work on this one too? Turn on the tv,but since there is no image I don't know if it does something else.
    I hope you can help me. Thanks!!
  • comptek
    • Aug 2013
    • 606
    Re: Vestel 17MB230 and panel VES400UNDS-2D-N11
    What’s the 23 number it will be on a white label on the ci slot or on the edge of the board at the top being furthest away from the aerial socket
    • 147selespeed
      • Dec 2022
      • 8
      • España
      Originally posted by comptek
      What's the 23 number it will be on a white label on the ci slot or on the edge of the board at the top being furthest away from the aerial socket
      1905 237313315 286241970247 10126379 1280
      I hope it works!
      • lotas
        • Jan 2016
        • 4459
        • Russia
        I hope it works!
        It's not that, there should be such a tag with the number 23xxxx, on the other hand it is not there?
        • 147selespeed
          • Dec 2022
          • 8
          • España
          No, there are no tags on the other side.
          • cheeky2
            • Dec 2012
            • 336
            All newer Vestel boards have the model numbers etched into the edge as pictured by images shown, together with the serial number as well. The model number of this board I cannot find any details for.
            So I would ask to the OP (original poster) what was the original mainboard in the TV (with pictures of the label) and what was the make and model of it? You cannot put any old main board in a Vestel TV and expect it to work.
            As you may have found this out with this already with the board you have replaced! Each board is tailored to the screen, the side control buttons if any, the remote control codes and any peripherals like wireless cards dvds players etc. So you cannot put any same main board from the same range and expect it to work!
            • comptek
              • Aug 2013
              • 606
              It won’t work it’s from a completely different to set
              You need a 17mb97 (type) mainboard you need to match the 23 number on you original mainboard, the one you have in the pictures is a 17mb230 and probably 4k,
              Use eBay search for 17mb97 then the 23 number, also cross reference with the original tv model number!
              Hope this helps
              • 147selespeed
                • Dec 2022
                • 8
                • España
                It won't work it's from a completely different to set
                Hope this helps
                Ok! I understand.
                I have another board 17MB97.
                Should this work?
                Thanks for all!
                • comptek
                  • Aug 2013
                  • 606
                  Hi there, the 23 number needs to match exactly otherwise you could ruin the screen
                  They use all different screen panels for the same model numbers….
                  Regards
                  • 147selespeed
                    • Dec 2022
                    • 8
                    • España
                    Regards
                    I don't understand. There are two stickers with the 23 number. The board was for this TV:
                    Telefunken Supra 42E.
                    -White Tag 23309114
                    Yellow Tag 23309116
                    I can't give more information, sorry.
                    • comptek
                      • Aug 2013
                      • 606
                      Here in the uk there’s nothing showing up, the we number on the white label is the one to go by, 23309114, have a look on eBay in Spain for the board under the 17mb97 and the 23309114, failing that go for the model of tv, last screen number you may get a board for that screen just make sure all connections are the same including screen connector, but be warned the remote may not work with the different board….
                      What was wrong with the tv in the first place ?
                      • 147selespeed
                        • Dec 2022
                        • 8
                        • España
                        Here in the uk there's nothing showing up, the we number on the white label is the one to go by, 23309114, have a look on eBay in Spain for the board under the 17mb97 and the 23309114, failing that go for the model of tv, last screen number you may get a board for that screen just make sure all connections are the same including screen connector, but be warned the remote may not work with the different board….
                        My TV is from a Movistar, named screen fusion with a proprietary main.
                        I have another 17MB97
                        23301677
                        Thanks again!
                        • comptek
                          • Aug 2013
                          • 606
                          Put the number 23301677 into your eBay over there and see what panel it’s for going by the screen number on the first post it’s a Samsung screen VES400UND(S)-2D-N11 (S) means Samsung
                          • comptek
                            • Aug 2013
                            • 606
                            That board won’t work either as screen connection is wrong
                            • 147selespeed
                              • Dec 2022
                              • 8
                              • España
                              Hi, I have image with the first 17MB97.
                              I installed the archive of this post of @yokoono
                              https://www.badcaps.net/forum/showth...ghlight=17mb97
                              And apparently everything works fine
                              • tommyaaa
                                Change Panel Settings (Vestel 17MB230)
                                by tommyaaa
                                after my TV didn't turn on anymore I decided to find the problem.
                                I took my DMM and checked the power board - ok.
                                Then I decided to swap the mainboard for a few bucks. (Vestel 17MB230)
                                After the replacement I stumbled upon a faulty looking display image.
                                The picture size an the picture itself is distorted. (shown in the pictures)
                                I did some research found out, that somehow you can change the
                                display settings but I only found instructions for Vestel MB1xx Mainboards, not for the MB230.
                                I checked the display type on...
                                11-23-2022, 02:34 PM
                              • porfyriadhs
                                Vestel 17mb230 mainboard.No Sound
                                by porfyriadhs
                                Hello to everyone . I have a vestel mainboard 17mb230 with no sound on the speakers only on the headphones . I think that hotel mode is on but I cant find a way to fix .. Any help will be good thanks
                                03-19-2024, 01:12 AM
                              • howardc64
                                LG 49UJ6500 LCD panel lighter band that goes away
                                by howardc64
                                49UJ6500 LCD panel has a lighter band on top when first powered on. Goes away (or gets much fainter) after TV on for a few min. After powered off for awhile and power back on, same band appears. If powered on immediately after powering off, no or much fainter band. Running the latest firmware.
                                Disassembled the TV and lifted the LCD panel during testing. Band is on the LCD panel (can see the band on the panel as I lift it slightly) Backlight is perfectly even at the top edge. Double checked LCD panel alignment in the frame and is perfect but since band moved with the panel, its on...
                                02-19-2023, 12:13 AM
                              • stav242
                                Vestel VES550QNUS-2D Panel issue.
                                by stav242
                                i just spent quite a few hours trying almost everything i could find out to check why this panel wasnt working.
                                MB was detecting a fault and going into fault mode.
                                i could se the AVDD go high for a second then drop to off.
                                check all CAPs and diodes on bottom buffer boards.
                                in the end i gave up and removed the panel, only to find burnt tracks on the cof tab..
                                i learnt a lot in the process, but wont go doing all those checks first next time.
                                so word of advice... if your panel is suspect, save youself a few hours and check...
                                02-28-2023, 11:51 AM
                              • triplefour
                                SAMSUNG UN50TU8000F rebooting, backlight ok. No 12v to panel boards.
                                by triplefour
                                TV flashes backlight then reboots over and over. no image. Client said it used to have image for a bit before rebooting. Got worse over time.
                                tcon is built into mainboard.
                                Only one cable goes to panel boards.
                                there is a cable from one panel board to the other that links them.
                                cost cutting measure that results in us having harder time to diagnose.
                                removing the link to the second panel board allows TV to stay on with stable backlight but no image.
                                used cut off tape method to mask 1 maybe 2 pins on the side of the cable that goes to that second panel board....
                                07-28-2022, 07:59 PM
