Identify Diode Canon EOS M50
  • kalemaroni
    • Jun 2016
    • 180
    This picture is of a Canon EOS M50 camera logic board which isn't powering on.
    It gets 5v from the micro USB charger but no voltage after the diode or any nearby components.
    The battery connector is the 3 pins on the right edge of the board and also has 0v on all pins
    Am I correct in thinking that if there is 0v on the 3 pins at the bottom of the diode then there is a problem with the diode?
    If I were to replace the diode, would anyone know how to identify it for me?
  • steviewonder
    • Dec 2013
    • 183
    • england
    Re: Identify Diode Canon EOS M50
    Well,firstly ,I would be almost absolutely certain it isn't a diode.
    • Kg74
      • Feb 2013
      • 67
      • Usa
      I believe that is a diode.
      I believe the R050 DZ8N is a fuse. That is most likely the problem. What is it reading resistance wise? Plug in the numbers and do some digging. I have repaired a number of Canon and Nikon DSLRs with a single bad fuse in the power circuit.
      • kalemaroni
        • Jun 2016
        • 180
        Thanks Kg74. R050 DZ8N reads 3.7 ohms
        • Kg74
          • Feb 2013
          • 67
          • Usa
          https://html.alldatasheet.com/html-p...4/1/EMD62.html
          Does this help?
          You should post some better pictures, including the front and back of the board.
          I have searched for sometime on the RO50 DZ8N - appears to come up as a resistor - maybe the DZ8N is some further specifications. If so then it should be .05 ohms.
            • 21457
            Its a TOKO marking code i think, with that wide band.
            • Kg74
              • Feb 2013
              • 67
              • Usa
              Man I am not happy. I spent an hour working on my message and was timed out.
              Summary - I think it is a regulator of some type.
              I think there are three pins, one in the middle from the trace going down.
              Does the camera charge through the camera or does it have a separate charger? What is the problem with the camera? What happens when you supply power to the battery connector direct?
              I think you would be best served moving this to the power supply forum if the circuit is for charging which is what it looks like. The 5V in has to be brought down to about 3.7 to charge the battery.
              • hobostove
                Corsair RM1000e - Help identify 5VSB Zener diode
                by hobostove
                Hey there guys. I've got a Corsair power supply that's come across my bench dead. I usually don't mess with power supplies, but it's a slow week so I'm giving it a whirl.
                Taking it apart I heard a screw rattling around inside, and when I got it apart I found a couple blown components near what I think is the 5VSB area.
                There's a 22ohm resistor that's melted and open, but it still has the bands.
                The other part is a zener diode and it's top went to jesus, so I can't read the marking.
                It looks like the diode connects the source and drain of a TNY284...
                03-27-2025, 02:25 PM
              • jjne
                AUO M270QAN01 - identify diode?
                by jjne
                I have a small number of monitors based on the above panel and am working through them. I have at least two with a single, burned-out diode. From what I can see it's something like DI428 or DII428 or DH428. Here's a picture of a working one.
                Can anyone identify this please? Based on the number 428 it may be a shottky or a Zener according to Google. The device in question is D105.
                ETA I can confirm that the number is definitely 428 (I took a video which revealed a better image), the DII appears to be a maker's mark. There's also a code 1G. Looking around...
                01-24-2024, 08:39 PM
              • jezzaaaa
                Identify replacement diode
                by jezzaaaa
                I'm trying to find a replacement diode for one that has gone short.
                I have a generic USB charger that went short circuit to ground on 5V. I found that one of a pair of identical diodes in parallel (and in series with transformer secondary winding) has gone short in both directions, so I suspect it's bad. The marking is CSRS1045, which I believe is a low barrier Schottky with max current 10A and max reverse 45V. I found a spec sheet for CSRS1045-A that has same specs and also says 350mV drop when forward biased.
                I can't find the exact part number for sale. Similar...
                05-09-2023, 11:26 PM
              • gurj1979
                Ubiquitiu 24 port POE. Help Identify Diode 3pin)
                by gurj1979
                Hi again guys.
                Ive got a Ubiquiti 24 port POE Switch which has failed to work. Fans turn on, but no lights.
                I've ripped the board out, flipped it upside down and noticed a blown 3pin SMD Diode (at location D53). Marking is ESSP (as with all the other Diodes in the same row).
                Anyone help me identify the model of this Diode ?...
                08-23-2023, 08:39 AM
              • rddube
                Asus C423N motherboard - trying to identify diode
                by rddube
                Can anyone point me in the right direction as I am trying to identify which diode this is as in the red square.
                Many thanks!
                Ray...
                06-24-2023, 08:08 PM
