Brother Inkjet Constant Clogging on Magenta Only. Tips?
  • nobbnobb1
    • Nov 2019
    • 76
    Hi guys,
    I have a Brother MFC990CW inkjet of which I am using refillable cartridges. I know this printer is close to a decade old, but everything is (mostly) working properly and I keep it serviced nicely so I'm just trying to squeeze as much life as I can out of it.
    The only issue I am having is that the magenta color clogs up very frequently and I have no idea why. I've been having this problem for the last year and my solution has been to print full color pages regularly to unclog it. However, once it unclogs, a few days later it it will streak again. I have already taken the printer apart and forced a cleaning solution through the inkjet nozzles (distilled water and alcohol) but the problem always comes back. Strangely I am not having any problems with the other colors.
    Does anyone have any ideas? Are there certain brands of bulk refill ink that might be better at not clogging? Or perhaps there's something I can add to the ink to help it?
  • ron350
    • Feb 2014
    • 296
    Re: Brother Inkjet Constant Clogging on Magenta Only. Tips?
    With Canon ink printers when a color starts streaking you flush all the old ink from the sponges in the cart and refill with fresh ink.
    • CapLeaker
      Leaking Member
      • Dec 2014
      • 8340
      You can try sticking that thing in an ultrasonic cleaner. There a YouTube vids about that. I’ve put a lots of things that needed cleaning (incl. engine ECU’s) into my ultrasonic cleaner with good results. It all depends on how strong the ultrasonic cleaner is and what cleaning solution you use.
      • smile
        Brother MFC Inkjet Printer prints Unidirectional mode only?
        by smile
        My friend brought his MFC-5895 for repair. Same problem "No ink in the ink tubes". Quick FIX when you have 3D printed parts.
        But his printer has this problem of only printing in Unidirectional mode, else the text is blurry.
        All service manual adjustment done and make no difference.
        timing strip is OK
        See nozzle check is also out of alignment.​
        12-27-2024, 05:34 AM
      • bseinfo
        Brother MFC-J480DW printer stuck in maintenance mode
        by bseinfo
        I have a Brother MFC-J480DW printer stuck in maintenance mode (BHL2 USB Maintenance). The screen only shows white bars, and it’s completely unresponsive. The official Firmware Update Tool doesn’t detect it, and I’ve tried multiple versions.
        I’m looking for the raw firmware file LZ5313_L.blf (or .djf), compatible with FILEDG32.exe, so I can attempt a manual recovery.
        If anyone has a full dump of this model (or a compatible one like MFC-J485DW or J885DW), or knows a private Discord or Telegram group where this kind of firmware is shared,...
        07-05-2025, 10:53 AM
      • Raymond red (mon)
        Brother J2730-DW stuck on Brother Logo
        by Raymond red (mon)
        hello, I have this Brother J2730-DW printer that was brought to me by a friend, it was supposed to be converted to continues ink but the printer wouldn't turn on completely. The printer powers on and plays a tune but it gets stuck in the brother logo. Upon checking, the printer was infested by many small cockroaches. I do checked the board cleaned and tested some corroded capacitors but all seems to be fine, I couldn't find any short circuit or any missing component on the board. Also checked the power supply and it was working fine.
        please help.
        11-08-2024, 09:19 AM
      • meeotch
        Samsung PN64H5000 flickering magenta problem
        by meeotch
        My 6 year-old Samsung PN64H5000 plasma t.v. has developed a flickering problem recently. It primarily manifests as a magenta color that flickers on and off. It's most visible in areas that are blurred / low contrast / subtle gradients. But it's also visible as a very slight brightness flicker in other scenes, even when the magenta cast isn't present. It happens most in bright scenes, but not always. It's also intermittent - it will sometimes go away for several minutes.
        I'm sure it's not the cable, the video source, the files being played, or the HDMI input, having switched out...
        08-18-2021, 06:27 PM
      • rxyzm
        Brother MFC-T910DW
        by rxyzm
        Request to share, If anyone has Service Manual and Schematic for Brother MFC-T910DW Inkjet printer.
        I am in need of it as my printer does not print GREEN letters. Also, the LCD Panel has gone south on my printer.
        This printer uses Cyan, Yellow, Magenta and Black Color Inks.
        Thank you in advance.
        Warm Regards,
        09-16-2023, 04:45 PM
