Adding a clock battery to action camera to retain date&time when changing batteries Campark X25
  • flat-earther
    • Dec 2022
    • 119
    • palestine
    I have a cheap action camera with an annoying trait, every time I change batteries the date & time gets reset and I have to set it again.
    To solve this problem I want to add a small internal battery inside it which will keep supplying power to the camera for a while while I change batteries so the date & time is retained.
    I have opened the camera and I think there is enough room to add something inside to accomplish this:
ID:	3654673 Click image for larger version
ID:	3654674 Click image for larger version
ID:	3654681 Click image for larger version
ID:	3654675 Click image for larger version
ID:	3654676 Click image for larger version
ID:	3654677 Click image for larger version
ID:	3654678 Click image for larger version
ID:	3654679 Click image for larger version
    The camera is powered by a 3.7V nominal single cell lithium ion battery.
    So I need to connect another battery in parallel to ground and battery + on the PCB.
    What battery, or perhaps capacitor should I use?
    I have on hand such capacitor visible in my photos which will fit, 25V 220µF, would that work?
    And should I add a resistor in series with the capacitor to limit the inrush current charging the capacitor when plugging in the battery, if so what value resistor?
  • harp
    • Jun 2022
    • 606
    • Planet Earth
    On scrap pc motherboard you can find smaller size and bigger capacity electrolitic caps for 6.3v... I also seen that for retain clock is used special supercapacitor look like ordinary small battery with tht tabs. You may want to concern to separate your battery from mains one, to overcome discarging system battery for filming... maybe to inspect pcb in off state to see where is present voltages for system standby...
      • 31084
      find the 32.768KHz crystal and see which chip it connects with.
      then get a datasheet for that chip
      • flat-earther
        • Dec 2022
        • 119
        • palestine
        Thanks guys for your suggestions,
        The component marked EAFC is the 32.768KHz oscillator, I think it's MC-146. one side is ground and the two pins on the other side are at 0.85V at standby,
ID:	3656268 Click image for larger version
ID:	3656269 Click image for larger version
ID:	3656270 Click image for larger version
        I didn't find continuity from it to any pin on chips XR819 or AXP233.
        On the other side of the board the chips B649SN and the covered one are BGA so can't test pins.
        In standby I found few places at 1.8V, maybe adding a cap there would keep the time? IDK... everything is extremely small so I think I will connect a capacitor to some place on the main battery rail,
        I found online 6.3V 2200µF10x12mm capacitor, looks like there's enough space to fit it so I want to try that.
        board iT_X16_V1.2 2019.06.24
        • harp
          • Jun 2022
          • 606
          • Planet Earth
          On pc motherboard, cpu rail have small 2.5v caps arround 560uF... if you want to connect it to 1.8v places... I would solder thin isolated wires to that 1.8v points, and connect 1.8v lab psu, dissconect battery, wait few minutes, and take it back and see if time is reset.
          • flat-earther
            • Dec 2022
            • 119
            • palestine
            Good idea, but first I want to try if adding cap to battery rail works because it looks easier.
            • flat-earther
              • Dec 2022
              • 119
              • palestine
              Oh no all my photos in this thread have been lost.
              I added a 6.3V 2200µF10x12mm capacitor.
              I connected the capacitor to a ground and battery rail point I found on the camera's PCB, and added a 150ohm resistor I found in series with the capacitor to limit inrush current when plugging in the battery:
              Click image for larger version  Name:	IMG_3495.jpg Views:	0 Size:	1.89 MB ID:	3679037
              First I taped and glued the capacitor to the lens housing but the cap was too high so the case didn't fit:
              Click image for larger version  Name:	IMG_3496.jpg Views:	0 Size:	1.56 MB ID:	3679022 Click image for larger version  Name:	IMG_3497.jpg Views:	0 Size:	1.57 MB ID:	3679029 Click image for larger version  Name:	IMG_3498.jpg Views:	0 Size:	1.34 MB ID:	3679028 Click image for larger version  Name:	IMG_3499.jpg Views:	0 Size:	1.70 MB ID:	3679033
              Then I moved the capacitor and attached it lower, right on the PCB:
              Click image for larger version  Name:	IMG_3500.jpg Views:	0 Size:	1.51 MB ID:	3679023 Click image for larger version  Name:	IMG_3501.jpg Views:	0 Size:	1.27 MB ID:	3679026 Click image for larger version  Name:	IMG_3502.jpg Views:	0 Size:	1.62 MB ID:	3679027 Click image for larger version  Name:	IMG_3503.jpg Views:	0 Size:	1.22 MB ID:	3679024
              But there was one protruding feature on the camera housing that was still interfering with the capacitor:
              Click image for larger version  Name:	IMG_3504.jpg Views:	0 Size:	1.35 MB ID:	3679038
              So I ground the plastic away:
              Click image for larger version  Name:	IMG_3505.jpg Views:	0 Size:	1.42 MB ID:	3679025
              After that it fits:
              Click image for larger version  Name:	IMG_3506.jpg Views:	0 Size:	1.81 MB ID:	3679032 Click image for larger version  Name:	IMG_3507.jpg Views:	0 Size:	1.95 MB ID:	3679035 Click image for larger version  Name:	IMG_3508.jpg Views:	0 Size:	1.15 MB ID:	3679021 Click image for larger version  Name:	IMG_3510.jpg Views:	0 Size:	1.39 MB ID:	3679030 Click image for larger version  Name:	IMG_3511.jpg Views:	0 Size:	1.63 MB ID:	3679036 Click image for larger version  Name:	IMG_3512.jpg Views:	0 Size:	1.72 MB ID:	3679034 Click image for larger version  Name:	IMG_3513.jpg Views:	0 Size:	1.36 MB ID:	3679031
              I tested it and after changing battery the time is retained now.
                Modification of a Fluke multi meter that uses three AA batteries to use a 14500 lithium ion battery
                by sam_sam_sam
                I have had with regular AA batteries that leak this meter is expensive new I already replaced the battery battery clips once and the same thing happened again and I am tried of so it is getting modified to accommodate lithium ion batteries that are the same size excluding the positive terminal and removing the battery clips I will have enough room for the BMS protection board
                I going to put 3 lithium ion battery in parallel with the BMS protection board and a way to charge the battery externally and heat shrink the battery pack and use a JST connector so I easily remove the battery...
                12-31-2023, 06:04 AM
              • pabloroggeri
                Lenovo V310-15ISK - It doesn't work after changing the battery
                by pabloroggeri
                Good guys. I changed the battery to a Lenovo V310-15ISK.
                The laptop worked perfectly, I changed the L15C4A02 battery because it didn't last very long.
                When I connected the new battery, the charging LED stopped lighting up and the one next to the charging pin also did not react when I pressed the power button. Minutes before changing the battery it worked perfectly and stopped working after putting the new one in. Even if you put the oroginal battery in or connect it without the battery, no LED lights up when you press the power button nor does it give an image, nor does the...
                08-23-2024, 12:01 PM
              • mkdj
                ASUS X571 no power : battery issue?
                by mkdj
                Mark and model: ASUS X571
                Symptoms: not turning on. There is only the LED battery indicator working. The owner of the laptop told me this problem arrived one week after having changed the battery. He then managed to power on the laptop only once, and then it never powered on again.
                Tests already made:
                - Battery is charging when laptop is plugged in. The LED battery indicator turns white after a couple of hours of charge, indicating that battery is fully charged. However, laptop won't turn on anyway, with or without AC plug.
                - I have removed...
                07-14-2025, 09:16 AM
              • huzo
                HP ELITE X2 1013 G3 weird battery issue
                by huzo
                Hi, so the old battery was getting error stated it's capacity is starting too get low and should be replaced, so the customer bought a new one and replaced it, but the new battery was also getting this notice that it's capacity is getting low and should be replaced, so i took the laptop for testing and the battery is charging at the terminal at 8.03V , the voltage of the battery is 7.7V, and drawing around 600mA when charger is put and the laptop is off...so that should be ok... but the bios system test doesn't recognize the battery and can't do the battery test and so is the hp battery manager,...
                01-31-2025, 12:09 AM
              • trepachka
                iPad Air A1475 Boot loops after replacing battery
                by trepachka
                This iPad was working fine except the battery was not holding charge for more than 40 minutes. I replaced it with a new battery. I haven't glued the battery yet, just inserted it into the slot and held it with battery screw.
                The iPad was powered on with the new battery and I am getting white screen with Apple logo for about 10 seconds, then the screen turns dark. It then cycles like this forever.
                I know the battery is working because the iPad continues to boot loop without the charger until it depletes to 0% and the message displays I need to plug in the charger.
                11-08-2024, 03:17 PM
