Old Laser printer vs. CUPS and Windows 7
  • Maxxarcade
    • Jul 2006
    • 973
    I've got an old Epson Action Laser II that's connected to my server and shared on the network. I got it working well, other than trying to find a suitable driver for my Windows 7 machines. Only one I could get to work was the generic Text-Only driver.
    I read somewhere that I could use a Postscript driver or something, but that was for my HP Deskjet 930C that I no longer have.
    Is it possible that there is a generic driver that has graphics support for this printer? I can't find a whole lot of info about it because it's so old. I do know that is is basically an HP Laserjet II clone, and can use PCL. Win7 doesn't seem to have a LJ2 driver either, and the Laserjet 4 driver didn't work.
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Re: Old Laser printer vs. CUPS and Windows 7
    is it postscript?
    sigpic
    (Insert witty quote here)
    • Maxxarcade
      • Jul 2006
      • 973
      is it postscript?
      I'm not sure.
      • ratdude747
        Black Sheep
        • Nov 2008
        • 17136
        the old driver trhing only works for postscript. the file is a .ppd
        sigpic
          • 31285
          get the printer to do some internal test pages, these usually tell you stuff like internal driver versions.
          • bigbeark
            • Jan 2010
            • 661
            Your title line makes reference to CUPS which is a Unix/Linux application.
            Where you interested in using the printer under linux? There is a list of Linux-supported printers out there on the web.
            Generally, new versions of Windows drop support for old hardware. Manufacturers have no interest in supplying Microsoft with new drivers or the expense of certification.
            • toastygoodness
              • Jul 2005
              • 813
              it should read ESC. you could try all the HP drivers and probably get away with the older PCLs
              • Maxxarcade
                • Jul 2006
                • 973
                Got it working! Turns out that Win7 does have a Laserjet IIp driver, which this printer is a clone of.
                I guess I just didn't notice the driver in the list last time I checked, because it was way down near the bottom. Also needed to install as Generic/Text Only first, then use Windows Update to change the driver afterward.
