Braview PSU fraud.
  • cheese007
    • May 2009
    • 85
    Braview PSU fraud.
    Was on hardware secret's Brazillian affiliate when I found this article. I won't spoil the details, but let's just say that these PSUs weren't exactly new...
  • RJARRRPCGP
    • Jul 2004
    • 6304
    Re: Braview PSU fraud.
    WTF is that connected to the MOSFET?! Is that a resistor?!
    ASRock B550 PG Velocita
    Ryzen 9 "Vermeer" 5900X
    Arc A770 16 GB
    eVGA Supernova G3 750W
    Alienware AW3423DWF OLED
    • cheese007
      • May 2009
      • 85
      Yes, in fact, it is.
      • cheese007
        • May 2009
        • 85
        There's also some reviews of the higher-end sunpro/leadman stuff. Did anyone else know that Leadman could do modular?
        http://translate.googleusercontent.c...KXu6eH09A_8dTA
        http://translate.googleusercontent.c...BnyCZSTtDxtjFg
        • 370forlife
          Large Marge
          • Aug 2008
          • 3112
          Wow. Terrible job doing rework there.
          On the other hand on clubedohardware i found the datasheet for the famous ATX2005 chip always found in deer/solytech psu's.
          • cheese007
            • May 2009
            • 85
            After a little more digging on the site, I managed to find this: http://www.sunpro.cn/newEbiz1/EbizPo...=1280883815099
            Sadly no internal shots, but might clear up the OEMs of those clear Logisys and Apevia units.
            • Krankshaft
              • Jan 2007
              • 2328
              PCB reworked look at those solder joints! With what a blowtorch?
              • 370forlife
                Large Marge
                • Aug 2008
                • 3112
                Those ones aren't leadman. Those are sunpro's. I don't really know if sunpro and leadman are in bed together, or if they are two seperate companies. I think they are kind of both. Different designs, different components, but still owned (or one owns the other) by one company. Many leadman products share the KY-XXXATX part numbers that sunpro has. Remeber that powsun website kc8adu linked to a while back? It had a whole bunch of units on there with leadman model numbers and very leadman-ish design and build quality. Maybe Powmax (leadman's own brand) and Sunpro combined to make this company? Pow from powmax + sun from sunpro = Powsun.
                Powsun has a psu that looks identical to this one in every way, shape, and form. Now, it may be powsun and KK are one in the same, or someone copied someone else's design.
                • cheese007
                  • May 2009
                  • 85
                  Your link goes nowhere. Surprised they're both different companies, considering the designs are usually so similar...
                  • 370forlife
                    Large Marge
                    • Aug 2008
                    • 3112
                    http://translate.google.com/translat...80-BRHE%2F2028
                    There, that should work.
                      master hoarder
                      • May 2008
                      • 12170
                      When I saw the overall look of those PSUs I though they weren't that bad. Then I saw the "rework" on the next page .
                      As for Powmax, Leadman, Sun Pro, etc. - don't know if they are related not, but don't care that much either. They just make crap PSUs, that's all everyone needs to know.
                      Thanks alot man, I've been looking for that data sheet. Guess I didn't look hard enough. I do have a L&C PSUs that uses it. Wonder if it's similar to the chips marked with 2003 (ATX 2003??) - I have one with that as well.
                      • cheese007
                        • May 2009
                        • 85
                        http://translate.googleusercontent.c...XzoDZzklZa2LWg
                        World record capacitor failure?
                        • 370forlife
                          Large Marge
                          • Aug 2008
                          • 3112
                          Ha ha, sapcon. Yeah, you're a real sap if you use them (Bad-Pun Haw haw)
                          • Per Hansson
                            • Jul 2005
                            • 5895
                            • Sweden
                            That was some really good work by Gabriel, I hope he publishes it on hardwaresecrets.com aswell
                            • goodpsusearch
                              • Oct 2009
                              • 2850
                              • Greece
                              This is not bad at all:
                              http://translate.googleusercontent.c...v1ZGHjA3uHOdXQ
                              • RJARRRPCGP
                                • Jul 2004
                                • 6304
                                Looks like it's Leadership not Leadman.
                                Arc A770 16 GB
                                • 370forlife
                                  Large Marge
                                  • Aug 2008
                                  • 3112
                                  Originally posted by goodpsusearch
                                  That one looks like a andyson or some andyson knock off.
                                  • Rulycat
                                    • Apr 2010
                                    • 724
                                    A resistor?! On the MOSFET?! Would that thing even work? Would it not just catch fire?!
                                    • Khron
                                      • Sep 2006
                                      • 1350
                                      • Finland
                                      Well, in all truth/fairness, that resistor *is* on the gate of the FET (the "control" leg; the other two are hooked up to the "power" side, source to + and drain to -), so it might actually do some good there (limiting the switching speed, slightly). I'm guessing it's just a cheap method to "cheap out" on circuit or pcb design
                                      Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - Shenanigans
                                      • Joe24
                                        Maytag Whirlpool Kenmore clothes dryer data bus
                                        by Joe24
                                        Patient is a Maytag/Whirlpool/Kenmore clothes dryer. Not sure of exact model, doesn't matter. All boards are out of production.
                                        Specific problem is a Maytag 8544799 / WP8544799 motor-control board, aka Diehl Controls 708879-05. Customer states the board "doesn't work, motor doesn't run". Not sure how the repairman made that assessment, or if it's even accurate. He can't get replacement boards, and the owner decided to buy a new dryer, so whether this board is the problem is speculation on his part. Again, doesn't matter.
                                        I've been over the board looking for...
                                        01-13-2025, 06:50 PM
                                      • BOSCHNJAK
                                        by BOSCHNJAK
                                        ABOUT ME INTRODUCTION FILE
                                        2
                                        024 BEV, BIH, SARAJEVO START PROJECT: ELECTRIC VEHICLE TOYOTA 4 RUNNER CONVERSION http://www.bev.ba/TOYOTA4RUNNER/index.html
                                        2023 BEV, BIH, SARAJEVO START PROJECT: SECRETS AND MANUFACTURING PLANS (AS MY REPLICA) OF THE LIBERTY ENGINE 2.0.
                                        2022 BEV, PROJECT ?
                                        2021 BEV, PROJECT ?
                                        2020 BEV,BiH, Sarajevo: PROJECT IS: HOW TO SWITCH OFF PERMANENT MAGNET FIELD and HOW TO SWITCH ON PERMANENT MAGNET FIELD?
                                        2019 BEV, Croatia, Ston:, Broce: PROJECT - PROJEKT ELEKTRIČNI GLISER http://www.bev.ba/ELEKTRICNIVANBRODSKIMOTOR/indexHR.htm...
                                        12-28-2023, 02:09 PM
                                      • DrewPhillips
                                        Wither OST?
                                        by DrewPhillips
                                        I was looking for specs on some OST electrolytics and tried the link to OST's capacitor page available on Badcaps, and widely available elsewhere but it came back dead. Shortening the URL a bit, I landed on OST's main site. No headings for electronic components manufacturing were displayed but I finally found this:
                                        "Taiwan Ostor Corp. was established in December 1993, and listed on the Taipei Exchange (TPEx) in May 2004.(Stock code 8080) Since inception, We've been committed to acting sales of electronic products and parts, and aluminum electrolytic capacitors. Changed the...
                                        11-08-2023, 01:09 PM
                                      • redbaron1007
                                        Arcade PSU blown resistor ID
                                        by redbaron1007
                                        I'm working on one of the PSU's in my backlog today that came out of an NBA Jam arcade machine a year or so ago. The PSU is a Pan Yes brand with a model number PY-TV-C. From what I remember the 12v rail wasn't outputting anything. I opened it up and was reminded that the resistor at R28 had blown it's shell off and I have no idea how to ID a replacement for it. (see pictures) The color bands that are still intact a little are brown, black, missing band/bands, and what I'm assuming is silver. When I check it with my DMM it's reading 100ohms exactly but I don't know if that's what it's supposed...
                                        01-06-2023, 04:13 PM
                                      • kchxaz
                                        Sony XBR-55X930D - Stuck in svc/test mode? How to fix?
                                        by kchxaz
                                        Hi guys, this is my first post here so thanks for reading. Hopefully you all might have come across this issue before. first let me apologize for the length of the post but if you are to help me then it warrants giving you as much detail as possible, right?
                                        So, I'm trying to bring back to life my Sony XBR-55X930D. Here is the situation: Removed and sent out power board for repair (due to no LED, red or otherwise, good power brick putting out the required 24V)). First time the board came back it did not work so I bitched at the place, mostly for not wanting to identify the parts...
                                        05-16-2021, 05:24 PM
