Wither OST?
  • DrewPhillips
    • Oct 2023
    • 14
    Wither OST?
    I was looking for specs on some OST electrolytics and tried the link to OST's capacitor page available on Badcaps, and widely available elsewhere but it came back dead. Shortening the URL a bit, I landed on OST's main site. No headings for electronic components manufacturing were displayed but I finally found this:
    "Taiwan Ostor Corp. was established in December 1993, and listed on the Taipei Exchange (TPEx) in May 2004.(Stock code 8080) Since inception, We've been committed to acting sales of electronic products and parts, and aluminum electrolytic capacitors. Changed the direction of business in 2020. The main business is disposal of the Construction Residual Soil presently. Reducing ineffective business items, focus on spoil disposal, and expect for full-year net profit."
    I take this to mean that OST has divested their capacitor operations (with no listed successor), and is no longer in the electrolytics business. Wither OST, a beloved Badcaps icon? I could cry with both my eyes.
  • dmill89
    • Dec 2011
    • 2534
    Re: Wither OST?
    I'd hardly call OST an "Icon", they are pretty much a "meh" brand along with stuff like Teapo, not among the worst of the worst, but far from the best as well.
      • 31289
      Re: Wither OST?
      electrolytics under 50v are becomming obsolete - only their relative low price keeps them going
      if money isnt the issue you can replace anything upto 4.7uf with polyester or polypropylene and anything larger with polymer or tantalum - depending on if leakage is important
      • DrewPhillips
        • Oct 2023
        • 14
        Re: Wither OST?
        dmill89 - My naming OST as a "BadCaps Icon" was intended to be facetious, but perhaps was a bit too deadpan. OST would be an icon alright, as in the icon we love to hate. It appears as though OST is no more, and we all are shedding crocodile tears. Bring on the leaking Teapos and the Rulycons! Soldering irons at the ready!
        stj - I have used polyesters to replace very low value electrolytics such as .22 uF (that's POINT two-two) in equipment of 20-25 years ago. I haven't seen any of those very low values in newer equipment. Haven't tried the polymers to replace higher value electrolytics yet. My concern would be for polymer replacing the input capacitor of a motherboard processor VRM. That cap is located physically close to the VRM, but still is typically connected directly to the incoming 12V supply bus. That places the VRM input cap directly across the 12V output of the PSU - concern is that a polymer in this location might contribute to PSU instability.
        So long as lowest first cost continues to take priority, we'll continue to see traditional electrolytics in new equipment. And I'll be polymodding.
          • 31289
          Re: Wither OST?
          polymer on motherboard inputs works fine - i'v done it a lot
          you have the impedence of the cables between the caps and psu
          • Perry Babin
            Derating of polymer electrolytics
            by Perry Babin
            There have been suggestions for derating polymer electrolytics to below the rated values. I've seen documents that recommended this and some that indicate that derating isn't required. The documents recommending derating are often old or refer to old documents. Do polymer caps of this type still require derating for reliability?
            If they require derating, why would the manufacturer give them their rated voltage?
            This is the basic type of capacitor I'm referring to and included simply to eliminate other caps that use similar names.
            https://www.mouser.com/datashe...
            10-24-2025, 11:57 AM
          • Perry Babin
            Lowest ESR capacitors, preferably liquid electrolytics but polymer also welcome
            by Perry Babin
            I'm looking for suggestions for electrolytics that are 10mm diameter and up to 25mm tall, through-hole radial capacitors with 5mm lead spacing. The value needs to be in the range of 330uF to 470uF. I typically use 35v caps due to their lower ESR vs 16v caps. Currently, the Panasonic FC is being used but the FM series is under consideration.
            This is for the primary side of a switching power supply in a car audio amplifier.
            Is there a way to calculate power dissipation in a capacitor to predict which will operate at a lower temperature? For example, a 470uF may have a...
            10-16-2025, 05:20 AM
          • Delicieuxz
            I replaced all electrolytics in subwoofer, still get a hum in speakers - audio clip
            by Delicieuxz
            I get a faint, low hum through my PC speakers, which connect to the subwoofer in a 2.1 speaker system. The hum drives me crazy and makes me stressed. When I turn off the subwoofer, everything is quiet and I start to relax, lol.
            Here's an audio clip of the sound coming from my speakers:
            https://vocaroo.com/16HaryHwTx78
            I recorded with my phone's mic right next to the speaker, and the mic picked up a lot of speaker noise over top of the hum. But I don't hear that noise in the room, I just hear the lower-pitched hum that's buried beneath all the other...
            11-15-2023, 09:50 PM
          • Physios
            Large vs small electrolytics reliability
            by Physios
            Goodmorning.
            I have a curiosity: can low voltage/capacity electrolytic capacitors (e.g. 16V/47uf) last longer than high voltage / capacity ones (e.g. 63V/2200uf)?
            I ask because many threads indicate a life of electrolytics that does not go beyond 15 years (it seems to me that Panasonic has written something in its documents), but I have several musical instruments bought in 1980 that work perfectly: they have inside them many small electrolytics. I tried asking an electrical engineering friend to unsolder some and measure them, and these were incredibly within spec....
            03-08-2021, 01:28 AM
          • Crystaleyes
            What are the 'actual' effects of old electrolytics in a vintage radio?
            by Crystaleyes
            Hi all.
            Just trying to get a better understanding of electronics in general, and although I know that it can be general practice to replace any electrolytics in vintage gear, I was wondering 'what' are the effects from these failed components?
            I can see that a shorted cap acts as a short circuit and therefore a power drain, but what else might it cause?
            Similarly, an open cap won't be smoothing any signals but is there anything else?
            I'm sure this is basic 101 but I'm not at school, so just learning as I blow things up...
            07-05-2022, 06:41 PM
