Antec TruePower 2.0 TPII-550
  • Behemot
    replied
    Re: Antec TruePower 2.0 TPII-550
    Check my stock.
    As for 4700, so far I have been replacing them with 3300 as there was nothing better. Now there are 4700/6.3 available, but I'll stock them late this year or early 2018…can only invest so much each year and there is already more than 10000 new pcs on the way or planned.
  • shane41
    replied
    Thanks buddy....... feel like I'm home now
    Now I'm struggling on replacing the taller caps.
    These are x2 3300uF 16v & x4 4700uF 10v dimension 10mm x 35mm.
    You see my store here RS Online only has the 12.5mm wide.
    It's the 3300uF though really needed.....assume for 12v rail.
    Watched this fluctuate in my bios screen hardware tab. 0.3V
    Now I can ship OK from USA shortly ...... if a store is recommended to me
  • Per Hansson
    replied
    Since the thread was revived anyway I'll provide a link for ver_arocena 4 years late about R117, maybe it will help someone else
    https://www.badcaps.net/forum/showth...863#post435863
    Welcome to Badcaps and happy recapping!
  • shane41
    replied
    Hello guys, Shane from Australia here. Reviving thread again.
    I have this power supply & smaller caps are domed.
    Do wish to keep these old school psu's matched to my 462, 939 boards of that era. So I may ask some questions later, though there is plenty of info in here
  • ver_arocena
    replied
    Just to revive an old thread, anyone knows the value for the R117 resistor located near the high voltage line. Mine was burnt and cannot get any reading and color code faded out.
  • aidynphoenix
    replied
    thanks a bunch thats what i needed.. im short only a single 1uf 50v cap. but its on the way. hopefully il have this psu working again in a few days.
  • PCBONEZ
    replied
    Physical location isn't that reliable.
    You can use a DMM [resistance/continuity check] from a yellow +12v wire to the caps to make sure which is which.
  • Wrog
    replied
    Originally posted by aidynphoenix
    can you guys assist me with this psu please.. awhile back i replaced all the large caps, not knowing about the low esr factor when choosing caps.. and i replaced the 4700uf and 3300uf caps all with 25v caps.. now, im not sure which caps were the 10v ones or the 16v ones.
    im assuming the two caps next to eachother are the 3300uf 16v caps and the 4 caps next to eachother are the 4700uf 10v caps? im assuming this because the two caps next to eachother are near the 12v rail (yellow) but i want to be sure..
    My notes on this indicate the following reference designators and values. Hope it helps:
    C6 47uF 35V
    C7 10uF 50V
    C22 470uF 25V
    C23 220uF 16V
    C27 3300uF 16V
    C29 3300uF 16V
    C32 4700uF 10V
    C33 1uF 50V
    C34 4700uF 10V
    C37 4700uF 10V
    C38 1uF 50V
    C39 4700uF 10V
    C45 1000uF 10V
    C46 1000uF 10V
    C58 22uF 50V
  • Behemot
    replied
    On 12V rail are usually 16V caps, on other rails 6,3 or 10V caps. Just trace the tracks to the actuall rails.
  • aidynphoenix
    replied
  • Wrog
    replied
    Re-installed and it's up and running perfectly. Thanks to all that have helped -- now on to the second one!
  • Wrog
    replied
    Originally posted by PCBONEZ
    Where is this list?
    That's probably a typo and I should fix it.
    Click the link where it says PCBONEZ's list. Will report back after work today.
  • PCBONEZ
    replied
    Originally posted by Wrog
    Had a chance to desolder all caps tonight, and found a slight surprise. I was going by PCBONEZ's list for the TPII-550 he did awhile back when I originally posted, and lo and behold, my actual list has one difference. C38 (under one of the coils) isn't a 22uF 50V as I had assumed, but rather a 1uF 50V. So his list has quantity 2 of the 22uF 50V and mine has quantity 2 of the 1uF 50V, everything else is the same. Very strange... good thing I ordered extras!
    Where is this list?
  • Wrog
    replied
    Got all caps swapped out tonight, but too late to do any testing. I probed purple to ground (standby) and got 5.1v so that's a good start! Hopefully tomorrow I can fire it up in one of my PCs and report back.
  • Wrog
    replied
  • Wrog
    replied
    Awesome, thank you guys. All parts ordered, I'll post updates when I have some time to work on them.
  • PCBONEZ
    replied
    PW and FM would both work for that one.
  • Wrog
    replied
    Thanks! I will inspect where they sit to check if 8mm diameter can be used. If they fit, would the Nichicon PW be a good choice? Actually, I think I may have some 220uF 25V with an 8mm diameter that I could use (Panasonic FM).
  • Toasty
    replied
    See PCBONEZ remarks (6 & 7) on this thread regarding endurance hour ratings:
    https://www.badcaps.net/forum/showthread.php?t=10764
    Also, can an 8mm fit in for that 6.3mm? If so, you have a much larger number of choices.
    Cheers!
    Toast
  • Toasty
    replied
    These are only 85°C caps. Need 105°C.
    Use KMG - http://search.digikey.com/scripts/Dk...me=565-1293-ND
    -or-
    NHG - http://search.digikey.com/scripts/Dk...&name=P5530-ND
    by momaka
    03-12-2025, 03:42 PM
  • eryjus
    by eryjus
    05-10-2023, 11:21 AM
  • Paxman_Swede
    by Paxman_Swede
    Hello!
    01-14-2025, 09:51 AM
  • captain150
    by captain150
    03-16-2025, 07:34 PM
  • Foetuss
    Gigabyte GA-6OXT :: caps question
    by Foetuss
    Good evening
    I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
    Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
    But I was also suprised about the bigger boys, which are 330µF 25V.
    Could it be they used 25V caps because they were cheaper / available at that time?...
    02-11-2025, 12:22 PM
