Antec TruePower 2.0 TPII-550
Mann-Made Global Warming.
- Dr Seuss
Re: Antec TruePower 2.0 TPII-550
Click the link where it says PCBONEZ's list.
Will report back after work today.
can you guys assist me with this psu please.. awhile back i replaced all the large caps, not knowing about the low esr factor when choosing caps.. and i replaced the 4700uf and 3300uf caps all with 25v caps.. now, im not sure which caps were the 10v ones or the 16v ones.
im assuming the two caps next to eachother are the 3300uf 16v caps and the 4 caps next to eachother are the 4700uf 10v caps? im assuming this because the two caps next to eachother are near the 12v rail (yellow) but i want to be sure..Comment
On 12V rail are usually 16V caps, on other rails 6,3 or 10V caps. Just trace the tracks to the actuall rails.Less jewellery, more gold into electrotech industry!
Half of the computer problems is caused by bad contacts
Exclusive caps, meters and more!Hardware Insights - power supply reviews and more!Comment
My notes on this indicate the following reference designators and values. Hope it helps:can you guys assist me with this psu please.. awhile back i replaced all the large caps, not knowing about the low esr factor when choosing caps.. and i replaced the 4700uf and 3300uf caps all with 25v caps.. now, im not sure which caps were the 10v ones or the 16v ones.
C6 47uF 35V
C7 10uF 50V
C22 470uF 25V
C23 220uF 16V
C27 3300uF 16V
C29 3300uF 16V
C32 4700uF 10V
C33 1uF 50V
C34 4700uF 10V
C37 4700uF 10V
C38 1uF 50V
C39 4700uF 10V
C45 1000uF 10V
C46 1000uF 10V
C58 22uF 50VComment
Physical location isn't that reliable.
You can use a DMM [resistance/continuity check] from a yellow +12v wire to the caps to make sure which is which.
.Mann-Made Global Warming.
- Dr Seuss
thanks a bunch thats what i needed.. im short only a single 1uf 50v cap. but its on the way. hopefully il have this psu working again in a few days.Comment
Just to revive an old thread, anyone knows the value for the R117 resistor located near the high voltage line. Mine was burnt and cannot get any reading and color code faded out.Comment
Hello guys, Shane from Australia here. Reviving thread again.
I have this power supply & smaller caps are domed.
Do wish to keep these old school psu's matched to my 462, 939 boards of that era. So I may ask some questions later, though there is plenty of info in here
Since the thread was revived anyway I'll provide a link for ver_arocena 4 years late about R117, maybe it will help someone else
https://www.badcaps.net/forum/showth...863#post435863
Welcome to Badcaps and happy recapping!
"The one who says it cannot be done should never interrupt the one who is doing it."Comment
Thanks buddy....... feel like I'm home now
Now I'm struggling on replacing the taller caps.
These are x2 3300uF 16v & x4 4700uF 10v dimension 10mm x 35mm.
You see my store here RS Online only has the 12.5mm wide.
It's the 3300uF though really needed.....assume for 12v rail.
Watched this fluctuate in my bios screen hardware tab. 0.3V
Now I can ship OK from USA shortly ...... if a store is recommended to me
Check my stock.
As for 4700, so far I have been replacing them with 3300 as there was nothing better. Now there are 4700/6.3 available, but I'll stock them late this year or early 2018…can only invest so much each year and there is already more than 10000 new pcs on the way or planned.Less jewellery, more gold into electrotech industry!
by momakaI know I've been a little scarce lately (like the last 2-3 years), but I'm still here and still doing my thing with fixing PSUs.
https://www.badcaps.net/filedata/fetch?id=359177... -
by eryjusHello,
Channel: General Capacitor Questions & Issues
by Paxman_SwedeHello!
I have studied the board and...-
by captain150I'm trying to repair two old VCRs, they both have bad caps. One has leaky ones, the other would barely run until I subbed in some caps from another power supply I had laying around (though they are the wrong values). This vcr works for an hour or two, but then the power supply starts whining and the picture gets lines in it. I didn't replace all the secondary caps, so another voltage might still be problematic, or the values I used are too far off.
I've been on mouser and digikey but the options are a bit overwhelming. I just need some new ones that will work. They don't need to be top quality,...-
by FoetussGood evening
I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
But I was also suprised about the bigger boys, which are 330µF 25V.
Could it be they used 25V caps because they were cheaper / available at that time?...-
- Loading...
