Fish Tank LED Power Supply Gets Hot then shuts down
  • EasyGoing1
    replied
    Re: Fish Tank LED Power Supply Gets Hot then shuts down
    Also, the way that these two caps are sitting next to this blue thing that is right next to the microcontroller makes me think that the blue thing is a crystal oscillator .... is that correct?
  • EasyGoing1
    replied
    Originally posted by stj
    i bet the RTC doesnt keep time anymore.
    how the hell do you use it - serial port??
    As a matter of fact, there is an RS-232 chip on the board ...
    Also, I forgot to show this ...
    These are the same ... looks like a voltage regulator...
    Also not sure what this means, but this chip has like a volcano ... zit looking protrusion coming out of it ...
    replied
  • EasyGoing1
    replied
    So I took the circuit board out and as you can see ... several places got damaged by excessive current draw ... the side by side is the board flipped against itself so you can see that one side of the board got burnt while the other side didn't except in that one general area.
    The housing has FOUR fans, two on each end... the red and black wires connect those fans and thats all those wires do.
    Last edited by SMDFlea; 10-12-2022, 01:53 AM. Reason: copy images from imgur to badcaps
  • EasyGoing1
    replied
    looks like you found the very slow blow fuse .
    Jokes ... love it!
    Up next ... I removed the circuit board and there are some interesting places on the board with obvious over heating ... even traces where the solder mask is burned off but not even near any component ... ill have pictures soon.
  • petehall347
    replied
  • EasyGoing1
    replied
    Originally posted by eccerr0r
    No, I'm curious why it's drawing 28W on the 5V line
    i think you need to check the current on the 12v line.
    it could be mostly using 5v,
    those old AT psu's had mostly 5v output, the 12v was only for the harddrives.
    in that case an ATX is useless because their main output is 12v
    OK, I cracked open the LED panel itself, which turned out to be only 4 screws then slide out the plastic that covers the LEDs and it exposes everything ... as you can see... I saw a problem immediately... You'll have to zoom in on the second picture to see it but the plastic on whatever that DC power connection is, is totally fried off of the wire though the wire is not disconnected.
    Last edited by SMDFlea; 10-12-2022, 01:56 AM. Reason: copy images from imgur to badcaps
  • CapLeaker
    replied
    Nope. ESR meters aka LCR meters are their own, and these functions are not to find in a DMM.
    replied
    it does not do esr, it's a basic compact clamp meter with a 100A limit.
    it's fame is that it can read DC with the clamp with a 1mA resolution!
  • EasyGoing1
    replied
    UT210e
    Originally posted by diif
    Yeah, another vote for the UT210e from me.
    Uni-T, Bside, Extech, Fluke…
    Could this meter replace my MESR-100 ESR meter? Does it have ESR capability? If so, I could send this one I just bought back and get the UT210E almost at a straight swap - cost wise.
  • diif
    replied
  • CapLeaker
    replied
    The only thing about Uni-T is that you have to make tripple sure it’s the meter you want. Some are doing only DC, not AC, etc. Your better off to go to the official Uni-T website and see what you want, then look for that specific model. Then compare pics etc.
    replied
    UT210e
  • EasyGoing1
    replied
    dont you have a DC clamp-meter btw?
    i thought everybody got one when uni-T released the cheap one!
    I don't have a clamp meter ... got a recommendation?
    replied
    maybe the opamp died - easy to diagnose the fault in them.
    replied
    I had one but I did not think it was that cheap but it only lasted a couple of years and then it would not read any dc current anymore
    I just have not bought another one yet but plan on doing this again when I need to have one for something that I can not use my meter for
    replied
  • eccerr0r
    replied
  • EasyGoing1
    replied
    Take the lamp apart and see how it's wired. Using that much +5 when +12 is available is kind of weird.
    Are you thinking that might have been a possible cause for the one power supply dying?
  • eccerr0r
    replied
  • flibidy
    Magnum IA.100 Amplifier Switches on, No Output, Possible Input Side fault?
    by flibidy
    I have here a Magnum IA.100 which belongs to my parents.
    The unit powers on & when the relay kicks in, you get a pop from the speakers (this might sound weird but is usual behavior for this amp). However, you get nothing coming through it from any of the inputs & no pops and crackls from any of the controls.
    Because of the sound from the speaker when the amp turns on I have assumed that the output section probably works but I could be wrong & I'm not sure how to test that side of things further.
    What Ive done........
    01-01-2025, 01:26 PM
  • bouny56
    Lenovo E15 Nm-c421 usb-c work only in one side
    by bouny56
    ​Hello
    Laptop E15 I5 10gen
    Mb nm-c421
    I have a problem with the usb-c power dc.
    The motherboard start only in one side of the usb-c
    Replace the usb-c port 2 times same problem
    With the usb-c meter, one side 20v ok, other side the usb-c meter don't come on
    Try to test the pin with the Mechanic Tail insertion tester and every pin are ok ?
    Can the pd controler be the fault ? Or something else maybe ?
    Thx
    02-11-2025, 03:15 AM
  • huzo
    HP Omen shuts down when loading OS
    by huzo
    The model is 15ec-1061nm
    Board number is DAG3EDMB8D0​
    SO i turn the laptop on , and as soon as it starts booting from disk, from usb, windows,linux,HBCD,anything i boot it just turns off....while in bios menu or in linux boot menu it stays on normally...It's like when it starts to use graphics it shuts down...But i measured 0.72V while working on the GPU power line,no excess heat is comming from GPU or CPU, i even removed the heatsink and turned the laptop on and everything worked fine, got a bit hot, fan span to full speed, but it worked like that for few minutes in bios...
    10-29-2024, 12:05 AM
  • howardc64
    by howardc64
    07-24-2025, 05:17 PM
  • Stephen
    A2442 MacBook Pro 14" Two Left SIDE USB C ports charge but no data
    by Stephen
    Right SIDE usb.c port charges and transfers data without issue, two left side uSB c ports charge but do not receive or see data. Was liquid damaged, and repaired significantly and thought we were in the clear but appears this is the last issue that is rearing its head. I am trying to locate the RETIMER chip that communicates the DATA TX/RX but I cannot seem to find it on the schematic or maybe I am just so tired my eyes wore out lol. Any help would be great.
    05-29-2025, 10:35 AM
