Fish Tank LED Power Supply Gets Hot then shuts down
    • 31301
    Re: Fish Tank LED Power Supply Gets Hot then shuts down
    it does not do esr, it's a basic compact clamp meter with a 100A limit.
    it's fame is that it can read DC with the clamp with a 1mA resolution!
    • CapLeaker
      Leaking Member
      • 8352
      Nope. ESR meters aka LCR meters are their own, and these functions are not to find in a DMM.
      • EasyGoing1
        Shock Therapist
        • Sep 2016
        • 977
        Originally posted by eccerr0r
        No, I'm curious why it's drawing 28W on the 5V line
        Originally posted by stj
        i think you need to check the current on the 12v line.
        it could be mostly using 5v,
        those old AT psu's had mostly 5v output, the 12v was only for the harddrives.
        in that case an ATX is useless because their main output is 12v
        OK, I cracked open the LED panel itself, which turned out to be only 4 screws then slide out the plastic that covers the LEDs and it exposes everything ... as you can see... I saw a problem immediately... You'll have to zoom in on the second picture to see it but the plastic on whatever that DC power connection is, is totally fried off of the wire though the wire is not disconnected.
        Last edited by SMDFlea; 10-12-2022, 01:56 AM. Reason: copy images from imgur to badcaps
        sigpic
        • petehall347
          • Jan 2015
          • 4451
          • United Kingdom
          #64
          looks like you found the very slow blow fuse .
          • EasyGoing1
            Shock Therapist
            • Sep 2016
            • 977
            Jokes ... love it!
            Up next ... I removed the circuit board and there are some interesting places on the board with obvious over heating ... even traces where the solder mask is burned off but not even near any component ... ill have pictures soon.
            sigpic
            • EasyGoing1
              Shock Therapist
              • Sep 2016
              • 977
              So I took the circuit board out and as you can see ... several places got damaged by excessive current draw ... the side by side is the board flipped against itself so you can see that one side of the board got burnt while the other side didn't except in that one general area.
              The housing has FOUR fans, two on each end... the red and black wires connect those fans and thats all those wires do.
              Last edited by SMDFlea; 10-12-2022, 01:53 AM. Reason: copy images from imgur to badcaps
              sigpic
                • 31301
                i bet the RTC doesnt keep time anymore.
                how the hell do you use it - serial port??
                • EasyGoing1
                  Shock Therapist
                  • Sep 2016
                  • 977
                  As a matter of fact, there is an RS-232 chip on the board ...
                  Also, I forgot to show this ...
                  These are the same ... looks like a voltage regulator...
                  Also not sure what this means, but this chip has like a volcano ... zit looking protrusion coming out of it ...
                  sigpic
                  • EasyGoing1
                    Shock Therapist
                    • Sep 2016
                    • 977
                    Also, the way that these two caps are sitting next to this blue thing that is right next to the microcontroller makes me think that the blue thing is a crystal oscillator .... is that correct?
                    sigpic
                    • EasyGoing1
                      Shock Therapist
                      • Sep 2016
                      • 977
                      OK, here's what I THINK is going on with this thing...
                      this image shows that there are THREE LED "Arrays" which consists of 5 rows of LEDs that are screwed down to a heat sink.
                      The wires that come in from the two PSUs are wired straight up to the circuit boards that are mounted next to each LED array. Then, we have this controller board...
                      That feeds each panel by those connectors at the top. ALSO, each panel has FOUR MOSFETS on the underside of the circuit boards attached to each panel and the top of those boards simply have what looks like 2 or 3 watt resistors ... something like 6 per board I think...
                      I BELIEVE - based on one of the chips I looked up, which was a PWM chip, that the LED panel MOSFETS are being fed a PWM voltage.
                      There is a wide connector that feeds the display / control screen, and a COM port that was unoccupied.
                      Heres where it gets kinda weird - at least to me it seems weird ...
                      The voltage that is powering the main controller board is taken from the end LED panel and it feeds directly into the input of a 7805 (which has burn marks on the PCB at its solder points) and THOSE are the wires that got their sheathing melted off. And take a look at these two MOSFETS where that power connection feeds from...
                      The red arrows point to the PSU wires and the two green arrows are pointing to those fried wires which are the power source for the controller board.
                      As you can see ... there is major discolleration at those two MOSFETS and it KIND OF LOOKS LIKE RUST TO ME like it got wet ...
                      Here is one of the other panels MOSFETS and you can see that they have no discoloration at all...
                      So this is where I'm not sure what to think ... clearly the main board was drawing too much power to that 5 volt regulator but yet the MOSFETS at that LED panel that feeds the power to the main board look suspect to me but they would have no role in powering the main board, they would only be powering the LED panel that they drive ...
                      So im not sure where to proceed from here...
                      sigpic
                        • 31301
                        if the main board locks up the led panels could be 100% duty cycle instead of pwm.
                        if you isolate the controller and feed 9v into the regulator, does it output 5v? and how much current does it draw?
                        • redwire
                          • 3912
                          J3 is just the DC input to the 7805 5V regulator. With the -ve black wire burning up I think would be caused by a ground fault.
                          So there is an overcurrent happening between the J3(GND) and power... somewhere. Guessing a fan or LED board or heatsink insulation failed and has shorted to power and the resulting high current is pulling ground return current through J3?
                          I would look for an open ground wire from the mosfets to the PSU.
                          Poke around with an ohmmeter and see if the mosfets are still insulated from the heatsink, ground wire did not go open-circuit etc.
                          It's a bit of a weird failure.
                          • EasyGoing1
                            Shock Therapist
                            • Sep 2016
                            • 977
                            OK, so using the bench power supply at 9 volts ... set to 5 amps, I have the board removed from the unit with nothing else connected to it and then I apply 9 volts to the 5volt regulator ... the regulator output pin reads 5 volts and the current draw is only .1 amps at the power supply ... so that's .1 amps at 9 volts from the power supplies perspective ... Im assuming that we're powering the MC with that voltage and the other chips on the board.
                            That certainly seems normal to me ... which means that it would probably become necessary to connect the light panels to see the over-current draw at the regulator???
                            Remember when the unit was still not taken apart we saw 5.5 amps being drawn on the 5 volt line coming from the PSU
                            sigpic
                            • EasyGoing1
                              Shock Therapist
                              • Sep 2016
                              • 977
                              OK, the MOSFETS are NOT shorted to their heat sink.
                              But what I find strange is that the red wire (the slow burning fuse) is actually soldered at the same point where the black wire is soldered coming from the PSU...and the ground wire (from the slow burning fuse) can be seen as the tip of the green arrow is touching it ...
                              I didn't see any kind of short at that circuit board, though with the wires having been melted, I can certainly see how the exposed wire could have been shorting but I didn't look for that before removing the wire from the main board and jostling it around.
                              The two red circles are the same solder point from opposite sides of the board
                              And NO, those white connectors next to the resistors never connected to anything ... in case you were wondering.
                              sigpic
                              • EasyGoing1
                                Shock Therapist
                                • Sep 2016
                                • 977
                                Got this today ... by the way...
                                sigpic
                                  • 31301
                                  damn that was fast!
                                  • EasyGoing1
                                    Shock Therapist
                                    • Sep 2016
                                    • 977
                                    damn that was fast!
                                    Amazon!
                                    sigpic
                                    • redwire
                                      • 3912
                                      I'm thinking +power goes to the LED's, so I would make sure the LED base is not shorted to the heatsink. Or an open high current ground wire/connection going back to the power supply. The red LED's don't seem to have insulated mounting screw holes on the PC board.
                                      The mosfets are on the low-side, switching to ground so a short (to heatsink) there would just give power all the time to the LED's, drain-gnd short.
                                      • EasyGoing1
                                        Shock Therapist
                                        • Sep 2016
                                        • 977
                                        The red and black wires go to the main controller board (not the red and black wires in this picture ... the ones that fried) and provide it power via the 7805 ... and here is a picture of one row of lights but they are all like this ... soldered on one side only, the other side is aluminum and screwed down to a heat sink.
                                        sigpic
                                          • 31301
                                          before we get sidetracked,
                                          where does the 5v and 12v from the psu go to?
                                          • flibidy
                                            Magnum IA.100 Amplifier Switches on, No Output, Possible Input Side fault?
                                            by flibidy
                                            I have here a Magnum IA.100 which belongs to my parents.
                                            The unit powers on & when the relay kicks in, you get a pop from the speakers (this might sound weird but is usual behavior for this amp). However, you get nothing coming through it from any of the inputs & no pops and crackls from any of the controls.
                                            Because of the sound from the speaker when the amp turns on I have assumed that the output section probably works but I could be wrong & I'm not sure how to test that side of things further.
                                            What Ive done........
                                            01-01-2025, 01:26 PM
                                          • bouny56
                                            Lenovo E15 Nm-c421 usb-c work only in one side
                                            by bouny56
                                            ​Hello
                                            Laptop E15 I5 10gen
                                            Mb nm-c421
                                            I have a problem with the usb-c power dc.
                                            The motherboard start only in one side of the usb-c
                                            Replace the usb-c port 2 times same problem
                                            With the usb-c meter, one side 20v ok, other side the usb-c meter don't come on
                                            Try to test the pin with the Mechanic Tail insertion tester and every pin are ok ?
                                            Can the pd controler be the fault ? Or something else maybe ?
                                            Thx
                                            02-11-2025, 03:15 AM
                                          • huzo
                                            HP Omen shuts down when loading OS
                                            by huzo
                                            The model is 15ec-1061nm
                                            Board number is DAG3EDMB8D0​
                                            SO i turn the laptop on , and as soon as it starts booting from disk, from usb, windows,linux,HBCD,anything i boot it just turns off....while in bios menu or in linux boot menu it stays on normally...It's like when it starts to use graphics it shuts down...But i measured 0.72V while working on the GPU power line,no excess heat is comming from GPU or CPU, i even removed the heatsink and turned the laptop on and everything worked fine, got a bit hot, fan span to full speed, but it worked like that for few minutes in bios...
                                            10-29-2024, 12:05 AM
                                          • Giggle2562
                                            Lenovo V15-IIL motherboard swap (in V15-IKB) shuts down when internal display is connected
                                            by Giggle2562
                                            I have a Lenovo V15-IKB that had a damaged motherboard. I replaced it with a motherboard from a Lenovo V15-IIL.
                                            The board powers on, but it shuts down after about 10-15 seconds. This only happens when the internal display (LCD panel) is connected.
                                            Here's what I've tried so far:
                                            • When the internal display is disconnected, the laptop works perfectly fine via HDMI.
                                            • The laptop shows an image on the internal display for a few seconds before it shuts down.
                                            • I tried swapping the LCD panel with a known good one.
                                            • I tried swapping the LCD cable
                                            11-06-2025, 12:36 PM
                                          • riko 656
                                            Lenovo Legion Slim 5 16APH8 (RTX 4070) - Turns on for a few seconds then shuts off. BIOS issue.
                                            by riko 656
                                            I need help with my Lenovo Legion laptop. It turns on for a few seconds and then immediately shuts down. I believe this is a BIOS corruption issue.
                                            Laptop Model:
                                            • Model: Lenovo Legion Slim 5 16APH8
                                            • GPU: NVIDIA GeForce RTX 4070
                                            • Main BIOS chip size: 32MB
                                            • VBIOS chip size: 16MB
                                            Problem Description: The laptop was working perfectly. Now, when I press the power button, the keyboard lights up and the laptop powers on for just a few seconds, then it shuts itself off completely. After researching, I am convinced it's a corrupt BIOS.
                                            What I Have Tried So Far:
                                            1. I
                                            11-04-2025, 05:14 AM
