-12v & -5v question
  • uligli
    • Aug 2006
    • 139
    -12v & -5v question
    It's a problem that -5v is at -0.78v?
    I recapped the PSU three months ago, 3 small ones and 2 2000uF+ caps, it's been working fine then. Today i saw the -12v & -5v rails, and i'm worried, will be a problem those voltages?
  • uligli
    • Aug 2006
    • 139
    Re: -12v & -5v question
    The PSU is a Hyper TypeR 580w, bought it in 2006.
    My pc config:
    Opteron 144 oc 2.7g
    DFI nForce4 UltraD
    1G ddr ram
    X1950pro (replaced by 7300GT last week after i burned it accidentally)
    • Per Hansson
      • Jul 2005
      • 5895
      • Sweden
      That would be out of spec (the standard calls for +/- 10%) however nowdays -5v has been removed from spec and -12v is only used for legacy stuff
      So it is likely your board does not load the rails at all and then they may be way off
      Also mainboard readings are usually also way off the mark, to know you have to use a multimeter...
      This thread has more info about the usages for -5v and -12v
      https://www.badcaps.net/forum/showthread.php?t=9894
      • POM_MJ
        • Aug 2009
        • 228
        Firstly, check if your PSU have a white wire to supply -5V output.
        recently PSU don't have it anymore.
        however, DFI NF4 Ultra-D don't need -5V.
        | AMD Phenom II X2 550BE | GIGABYTE GA-MA790FXT-UD5P | GeIL DDR3 Ultra 2x2GB 1600C7 |
        | XFX GTS250 DDR3 512MB | Dell H525EF-00 | Lancool PC-K62 Black | Samsung 2232GW |
        | 2xWD7500AYYS | 2xHD322GJ Raid0 |
        • kc8adu
          • Nov 2003
          • 8832
          • U.S.A!
          measure with dvm to be sure.
          50/50 psu or misreported voltage.
          type r for ricer?
          sounds like a cheapie.
          • mur
            • 21
            Either the psu doesn't have -5v rail or mobo reading is false.
            Either way you can't trust motherboard readings. My board reports my 12V rail at 4.86V, 3.3V at 1.15V and -12V at -3.97V. Only the 5V reading seems fine at 5.03V.
            • Pyr0Beast
              • Feb 2009
              • 406
              Heh. If negative rails were that high I'm pretty sure PSU would turn itself off.
              • uligli
                • Aug 2006
                • 139
                Thanks a lot guys for the replies make me the things clear
                Actually the serial ports and FDD are disable, may be that's why readings are low.
                • uligli
                  • Aug 2006
                  • 139
                  type r for ricer?
                  Well. cost me $99 in 2006, not a cheapie at all, was one of the most expensive PSUs, i think it was one of the first modular PSUs at that time.
                  • Per Hansson
                    • Jul 2005
                    • 5895
                    • Sweden
                    Did you replace all the Fuhjyyu capacitors?
                    • Pyr0Beast
                      • Feb 2009
                      • 406
                      Sorry to say this. But this is a piece of overpriced garbage.
                      Replace ones on -12 and -5V lines as well, but those are not used for anything today but the COM port drivers.
                      Those on 5V are bloated, replace them ASAP if you didn't already.
                      • 370forlife
                        Large Marge
                        • Aug 2008
                        • 3113
                        That hiper isn't so much of a cheapie. It's from 2006, a bit more of a 5v/3.3v heavy unit but this was a early one with modular and a 120mm fan, it was $99 back then for a reason. Other than the caps, it's a pretty good performing andyson build. Voltage regulation is OK, but the ripple is very well controlled.
                        http://www.jonnyguru.com/modules.php...Story2&reid=16
                        • Pyr0Beast
                          • Feb 2009
                          • 406
                          I'd place it under same tag as a tagan. Fuhyyu caps ruin them all and recap is costly and very time consuming.
                          • uligli
                            • Aug 2006
                            • 139
                            Not all of them, couldn't find the big ones, anyway it's working fine, next time i will recap them all, because is a pain to dismantle the modular conectors.
                              master hoarder
                              • May 2008
                              • 12175
                              • Bulgaria
                              It's okay if you didn't replace the primary 200v caps, since they rarely go bad. However, it looks like there are some others that you might need to. Take a look in the picture I've attached below - the caps circled in green filter the 5vsb, and they seem bulged. Definitely replace them if they are.
                              Also, I think this PSU has 2-transistor 5vsb design as well - in such design, there is one small cap that is critical to the regulation of the 5vsb - when it goes bad the 5vsb can get as high as 12v and kill the motherboard. The cap circled in red (22uF, 50v?) seems to match the specs of what is usually used for those critical caps. Get a low ESR cap from a good brand to replace it. Stick with the same exact specs as the original one.
                              • uligli
                                • Aug 2006
                                • 139
                                Thanks momaka for the advices, the bulged caps have already recapped, thoses pics were taken before the recap. I will replace the cap in the red circle.
                                • skwarszczow
                                  Macbook Pro A2141 020-01700-A GPU Artifacts then no S5 rails
                                  by skwarszczow
                                  This is my first post on the forum
                                  I recently purchased a MacBook A2141 from a colleague at work, which had issues with the dedicated GPU. The system occasionally displayed artifacts on the screen and sometimes experienced kernel panics related to the GPU. Interestingly, applying pressure to the VRAM module would temporarily resolve the artifact issues, which made me optimistic about the ease of repair.
                                  Board: 020-01700, Config: Intel i7, 512GB SSD, 16GB Ram.
                                  Before completing the purchase, we decided to erase...
                                  03-23-2025, 06:04 PM
                                • SarcasticOP
                                  General question about MacBook power rails for repair.
                                  by SarcasticOP
                                  I am looking at an A2337 and found this for the order of power rails and what they do. Can this be confirmed before I dive into hunting down power rails that do not exist or are not neccisary?
                                  • PPBUS_G3H (12.6V-12.8V)
                                    • This is the main power rail that supplies power to the entire system. Check this rail first, as it must be present for other power rails to work.
                                  • PP3V42_G3H (3.42V)
                                    • This power rail is derived from PPBUS_G3H and is used to power the SMC (System Management Controller) and other essential circuits. It should be present if PPBUS_G3H is working correctly.
                                  • PPVRTC_G3H (3.3V)
                                    • This
                                  12-12-2024, 05:50 PM
                                • Cemal Odabasioglu
                                  MacBook Pro A1707 Motherboard Diagnostic Help – CD3215 heating and Fluctuating Rails
                                  by Cemal Odabasioglu
                                  I'm currently diagnosing a MacBook Pro A1707 motherboard that does not power on. I've gathered some data but am stuck and need expert advice.
                                  Note that i'm a beginner in electronics and i'm trying to learn while trying to repair this macbook that my work gave me. I'm really curious and love understanding how thing works and i already learned so much.
                                  Only one usb c port is taking 20v and have 12.5v on PPBUS_G3H. when trying other ports, 2 are not going to 20v and one is going to 20v but the CD3215 is getting really hot.
                                  Observations...
                                  01-14-2025, 03:54 PM
                                • ferah831208
                                  help with AMD Ryzen 5 7535hs power rails
                                  by ferah831208
                                  Hello there, does anyone have info about AMD Ryzen 5 7535hs power rails or an schematics from a compatible CPU?. I have a quanta G3PR from a HP victus laptop, I suspect cpu is damaged but I would like to know what power rail is the one I guess is damaged. There are 4 coils aprox 4.2 ohm to gnd in parallel next to CPU (I guess vcore) ,one coil same size next to those 4 around 0.7ohms to gnd (damaged rail I guess), and other two smaller I guess associated to less current power rails for CPU logic purposes. Anyone have more specific info? I attached picture.
                                  03-09-2025, 01:59 AM
                                • DrewPhillips
                                  SFX PSU - Need High Current on 3.3V & 5V Rails?
                                  by DrewPhillips
                                  I have an older system which was built in the Windows 7 era and which has developed, I suspect, a power supply problem. The system had the same problem, random crashes, a couple of years ago, which I subsequently remedied with a new power supply.
                                  The power supply which came with the machine is a no-name "Safe Power PE-300". It is SFX form factor and claims a high current capacity: +3.3V @ 22A and 5V @30A (the +12V rail claims a meager 16A). Problem is that SFX supplies (or even ATX supplies for that matter) having high current ratings on the 3.3V and 5V rails seem to be...
                                  02-18-2025, 01:03 PM
