-------------- Background Info.. (skip if you like) --------
I recently found an abandoned low-end P4 computer with a generic power supply inside. The computer was able to boot properly. Suspecting power supply malfunction as a possible cause of the abandonment, I opened the PSU (Y2K YoungYear PS-IV 350-1, actually 250W) and discovered a leaky fuhjyyu and a burnt out resistor, adjacent to a mildy burnt patch on the pcb.
I replaced the leaky fuhjyyu and the other identical fuhjyyu next to it with two working caps (can't remember brands) in an attempt to raise the +12V,-12V, and -5V rails which were registering at 11.12,-10.92,-4.27 volts respectively. All other rails are working within the acceptable +/- 5% range.
After the two cap replacements, I'm getting 11.4/-11.08/-4.37 volts respectively. The improvement wasn't significant probably because of the burnt out resistor. I was unable to replace it because the color coding has burnt off and I don't have a schematic for the psu. However, the computer still boots as expected. (I plan to move the psu onto a P3 1ghz psu-less computer lying around)
----------------End background info --------------
So question is: What is the purpose of the -5V and the -12V rails? Do they do anything at all these days?
