Which gets hotter???
  • everell
    • Jan 2009
    • 1514
    Seems that opinion polls are popular on this forum, so thought I would start one. Not sure how to set up the voting for this one, so will just ask the questions, get some opinions, and reasons from the experts on this forum.
    Question number one: which gets hotter when computer power supply is running, the main switching transistor heat sink or the output diodes heat sink?
    Question number two: which gets hotter, the main switching transformer or the output toroid transformer/coil?
    No, these are NOT trick questions. Heat is the big enemy of aluminum capacitors. So it would be good to know what the bigger heat sources are so that capacitor placement can be better.
    Old proverb say.........If you shoot at nothing, you will hit nothing (George Henry 10-14-11)
  • c_hegge
    • Sep 2009
    • 5219
    Re: Which gets hotter???
    1. I would say the secondary heatsink as it is nearly always bigger the primary one.
    2. No idea. I NEVER open the case on a PSU when it is plugged in. I've been electrocuted one too many times.
    • everell
      • Jan 2009
      • 1514
      As a safety issue, I don't recommend checking temperature of heat sinks and transformers with power ON. So anyone checking temperature of parts inside psu, turn OFF power and wait a minute or two for the electrons to drain off. Parts that get HOT will retain their heat for a few minutes.
      • Toasty
        • Jul 2007
        • 4171
        Dammit!
        Where did I put that thermal imaging camera...
        veritas odium parit
        • 370forlife
          Large Marge
          • Aug 2008
          • 3112
          I would say in the old Half-bridge designs the primary heatsink gets the hottest.
          In a single or two transistor forward design, it depends. Also depends on how the secondary heatsink is set up.
          If the secondary uses two schottky's for the 12v and/or 5v then they will stay cooler, in which case the primary would definitely be hottest, especially if it uses Half-bridge instead of the more efficient single or two transistor forward.
          I would also imagine the primary transformer gets hotter than the secondary chokes.
          • ratdude747
            Black Sheep
            • Nov 2008
            • 17136
            depends on which arcs first (powmax and the like only)!
            sigpic
            (Insert witty quote here)
            • Per Hansson
              • Jul 2005
              • 5895
              • Sweden
              Well actually I think the coil on the secondary side ranks high
              In the PSU's I have seen where the fan have failed this coil has usually turned black!
              However I have also seen the primary side actually desolder one of the transistors legs (resulting in big bang and nice fireworks) so I guess that is the hottest side afterall!
              • Th3_uN1Qu3
                Believe in
                • Jul 2010
                • 6031
                • Romania
                That's normal, those cores like high temperatures. If the wire it was wound with didn't, well that's another problem.
                That wouldn't happen if they stopped using those crap thermal pads. I'm trying to build a 2-transistor forward SMPS to power an audio amplifier. I use the heatsink and isolation pads from a crappy ATX supply. Without a fan, the heatsink sits at 80C - but the switching transistors are at 120C!!! With a fan, the heatsink sits at 35C and the transistors at 60C. That's still a 25C difference which means the thermal interface material is absolute junk. I'll have to find some mica washers.
                A working TV? How boring!
                  Mounting and Handling Guidelines for TO220 TO220F TO247 Cases / Packages
                  The TO220, TO220F and TO247 are the popular packages for power devices because of their versatility and ability to dissipate moderate amounts of heat. This application note describes the basic guidelines for handling power MOSFETs in TO220, TO220 and TO247 packages shown in Figure 1. Please note that only mechanical and soldering guidelines are covered here. Additional precautions are required for isolating high voltage rated devices to meet safety regulations.
                  Securing a good thermal interface between...
                  10-07-2024, 04:35 AM
                • eccerr0r
                  Heat sink modding... thermal mass vs surface area?
                  by eccerr0r
                  Well, my Gateway monitor seems to eat caps. So I was thinking there was some systemic issue going on here and what I'm thinking: the heatsink is blocking convection flow and thus roasts capacitors by radiation!
                  Now what I wonder. This piece of aluminum heatsink is obviously blocking convective flow. I could add a fan but there are some other issues involved here. How about...drilling holes into the aluminum?
                  The holes would add surface area and allow air to convectively flow through the heatsink which could reduce temperatures. However this would of course reduce the...
                  04-15-2022, 10:25 AM
                • harp
                  detecting heat with IR LED receiver
                  by harp
                  I have some dark IR led, and want to know if it is be situable to detect pure heat (not visable glow ir radiation) in well lighted desk?
                  So, if I put hand over it in near distance like few centimeters, that detect rising heat, not covering it from light.
                  Something like termal camera, but in one spot, any simple circuit?...
                  09-06-2023, 06:03 PM
                • ludovik
                  Moto G84 short after heat
                  by ludovik
                  i was reballing the power manger of a moto g84, after applying heat i tried to power on and it wouldn’t.
                  i injected 1.5v to some capacitor that seem in short because both side beep if tested.
                  when i inject i feel the cpu burning;
                  since the cpu is exactly on the other side of the board, is that possible that the heat from the reballing damaged the cpu? do you know where i can find schematics or what can i do?
                  i know this is not enough to explain the situation so if you need any other info ask me please!
                  Thank you very much in advance
                  11-08-2024, 02:13 PM
                • valvashon
                  Repair Success! Middle Atlantic UPS2200R-IP
                  by valvashon
                  Yesterday I successfully repaired a Middle Atlantic UPS2200R-IP that had inadvertently been used as a surge suppressor at our transmitter site. It has already been replaced with an updated one but it's coming home with me now instead of being e-cycled. To be specific, this is the MA model that has the blue backlit display and has been discontinued, although this design may have been used in many UPS units including the smaller Middle Atlantic ones in this series.
                  Here's what happened: We experienced a brownout/surge at the site, which damaged the UPS and took our broadcasting...
                  02-06-2024, 12:54 PM
