what is this symbol on tvs diode ?
  • petehall347
    • Jan 2015
    • 4440
    • United Kingdom
    can't figure out this strange symbol
    can see its a 1.5ke series but its the next bit . 1?ca .. is it an 8 i wonder ?
  • R_J
    • 9605
    Re: what is this symbol on tvs diode ?
    likely 1.5KE18CA
    • petehall347
      • Jan 2015
      • 4440
      • United Kingdom
      Originally posted by R_J
      likely 1.5KE18CA
      that's what i was thinking thanks
      • CapLeaker
        Leaking Member
        • 8339
        Just this one is bi-directional, since the band on on side of the diode is missing.
        • petehall347
          • Jan 2015
          • 4440
          • United Kingdom
          1.5KE18CA is bi-directional, according to the datasheet .
          • CapLeaker
            Leaking Member
            • 8339
            I didn't look at the datasheet, as I just looked at your pics and noticed no bands and nothing was mentioned. Carry on! :-D
            • asr
              Finding replacement diode iPad Pro 3rd gen A1701
              by asr
              Hello, I am looking for help to replace a damaged diode. The tristar was replaced and a diode was damaged in the process. I have a picture of the diode but dont have an exact donor. I mostly have macbooks for donors and only a few ipad and iphone boards. Diode part number: DSF01S30SCAP
              Im not sure where to find the ipad board number. Anybody have an idea where else this diode is used on other boards? Thanks....
              07-09-2024, 06:24 PM
            • unimatrix93
              TV backlight zener diode
              by unimatrix93
              Hello everyone, I'm repairing an LG TV backlight and I noticed some strange behavior when I touching the backlight strip with a missing Zener diode.
              So I replaced the leds on the strips and they seemingly working fine, but soon as I touch the strip which has a missing Zener diode the whole backlight turns off for a few seconds and then turns back on.
              Is this caused by the missing diode? If so what kind of zener diode should I use to replace it?.
              The led strips has 9 6V leds.
              02-10-2025, 12:13 PM
            • Baste
              MBR3045CT and SR3045LCT Schottky diode testing help.
              by Baste
              Hello experts,
              Can anyone educate me on how to test MBR3045CT and SR3045LCT Schottky diodes? I'm totally a newbie in electronics, so forgive me if I have cheap tools. In my effort to repair a Gigabyte PSU, I stumbled upon the two diodes, which I suspect are leaky. I tested this with my two cheap multimeters and the newly bought LCR-T4 MC328, and I got confusing results. Below are my test results.
              Aneng ST182 Meter.
              Diode mode.
              MBR3045CT:
              Diode mode
              Pin 2-1 - 0.150v
              Pin 2-3 - 0.150v ...
              10-21-2025, 06:14 AM
            • NicRac
              monowheel repair,Is the diode the problem?
              by NicRac
              Hello everybody☺️ I am glad to be here and looking forward to a good discussion.
              First of all, I am new here. Therefore I will shortly introduce myself.
              I am Nico and currently I study Physics.
              In my freetime I like to build and repair stuff. Especially big battery's.
              A few years ago I got myself an electric unicycle, monowheel or however you call that.
              The battery bms was broken so I replaced and resolder that. Nothing big.
              I used this thing for some years and had a lot of fun. Unfortunately I used it last time in heavy rain. Usually everything...
              07-26-2024, 06:13 AM
            • dennis_elx33
              NO BODY MARKING Diode
              by dennis_elx33
              Hello Everyone,
              I have 1 diode on a circuit that I suspected to be faulty because the forward and reverse bias has a voltage drop reading.
              While compared to the reading of another diode from the next channel it won't read at reverse bias.
              Now the problem is; it does not have any body marking.
              So I tried to sketch the diagram and found out that it is connected to the base and collector of the C3632 transistor.
              What do you think is this diode?
              Can you please suggest what part number can i use to replace this faulty diode instead?
              Hoping that you...
              06-14-2024, 12:36 AM
