I was recently replacing a fan in my Antec 350 watt psu and while i had the cover off i noticed that two of the caps are bending sideways and leaking from the top. I didnt notice any instability but I'm wondering wether everyone thinks its safe to replace the caps. They are Fuhjyyu 4700uf 10 volt i think. I've never replaced a cap before but i solder and mod quite a bit and I'm willing to give it a shot if someone could point out where to buy the proper caps since i have no idea what to buy.
Caps in Antec PSU
Tags: None
Re: Caps in Antec PSU
to tell you where to buy it is useful to know which country you are in. Since you are in the States you can get caps from the forum owner http://www.badcaps.net
here are some other choices :
North America - Allied Electronics - http://www.alliedelec.com/
North America - Computek - http://www.computekinc.us/
North America - Digikey - http://www.digikey.com/
North America - Mouser - http://www.mouser.com/
North America - Newark In One - http://www.newark.com/
you will want one of these brands.
3.3 Reference of Good Capacitor Series for Motherboard Applications
Aluminium Electrolytic Radial Capacitors (Liquid Electrolyte)
Nichicon - PM, PW, HV, HD, HC, HE, HM, HN HZ (we do not recommend using HM or HN series presently due to early fails of those series.)
Nippon Chemicon - NRSZ, NRSX, NRSY, NRSJ, NRSG
NRSX is probably the best
United Chemi-con - KZE, KZH, KZG, KZJ, KZM, LXV, LXY, LXZ
KZE are used on many boards recently.
Panasonic - FC, FM, FK, FA
Panasonic FC are highly available and recommended.
Rubycon - MBZ, MCZ, ZL, ZLG ZLH, ZA, YXH, YXG
Rubycon ZL are highly available and recommended. MBZ, MCZ, ZLH, ZA are highly recommended but difficult to find.
----------Comment
Thanks alot! I'll let you know what kind i used where and how i goes maybe even with some pics!Comment
I finished installing my new Nichicon PW caps and I wanted to let everyone know it was a success! The power supply once again can hold its rails rock solid. It was tough since the Nichicons are about twice as big as the Fuhjyyu caps that were in there but i only needed to replace two. I bought enough o recap all of them but didnt since it didnt need it just yet. I'll just have to keep my eyes on it.pics later if i can
Hmm, better check my True 430...Ya'll think us folk from the country's real funny-like, dontcha?
The opinions expressed above do not represent those of BADCAPS.NET or any of their affiliates.Comment
Why do Antec use such trash? I know they're in my Antec TrueBlue 480 as well, and that cost a hell of a lot of money for a PSU.
I can understand it in the cheap PSUs but really, don't they want a good reputation? Isn't that worth a couple of cents?Comment
Originally posted by MD WillingtonHmm, better check my True 430...
LOLYa'll think us folk from the country's real funny-like, dontcha?
I got something to tell you guys. One time at work an Antec TrueControl 550W power supply blew its transformer and all its caps! Even the tiny caps blew. It suffered catastrophic damage. It was also a horrible smell of power supply death.My gaming PC:
AMD Phenom II X6 1100T Black Edition 3.3GHz Six-Core CPU (Socket AM3)
ASUS M4A77TD AMD 770 AM3 Motherboard
PowerColor AMD Radeon RX 480 8GB GDDR5 PCI-Express x16 3.0 Graphics Card
G.SKILL Value Series 16GB DDR3-1333 RAM (4x4GB dual channel)
TOSHIBA DT01ACA200 2TB 3.5" SATA HDD (x2)
WD Caviar Green WD20EARX 2TB 3.5" SATA HDD
ASUS Xonar DG 5.1 Channel PCI sound card
Antec HCG-750M 750W ATX12V v2.32 80 PLUS BRONZE Power Supply
Antec Three Hundred Mid-Tower Case
Microsoft Windows 10 Pro 64-bit
Microsoft Windows 7 Ultimate SP1 64-bitComment
Originally posted by MD WillingtonLooked good...I forgot to get the brand name though...time constraints...
LOL
(NOTE: Sorry for double posting!)My gaming PC:
Most Antec power supplies are actually manufacturered by CWT (Channel Well Technology), and that company loves Fuhjyyu caps. TruePowers are manufacturered my CWT, so they contain these Fuhjyyu caps.My gaming PC:
by momakaI know I've been a little scarce lately (like the last 2-3 years), but I'm still here and still doing my thing with fixing PSUs.
https://www.badcaps.net/filedata/fetch?id=359177... -
by eryjusHello,
by ajdrenterIn my search for a proper 5v heavy ATX power supply, I selected an old Antec SU-380 that I've had in storage for a long time. Opening the power supply reveals a couple bulged capacitors. I removed all the caps and made a map for myself. I found the datasheet for the PCE TUR series in this thread:
https://www.badcaps.net/forum/showthread.php?t=14159
It says these are general purpose, so I assume I can replace them with any general purpose capacitors, but I don't really know anything about power supply circuits or reading capacitor datasheets. Despite this, I've been shopping for replacements:...-
by Paxman_SwedeHello!
I have studied the board and...-
by captain150I'm trying to repair two old VCRs, they both have bad caps. One has leaky ones, the other would barely run until I subbed in some caps from another power supply I had laying around (though they are the wrong values). This vcr works for an hour or two, but then the power supply starts whining and the picture gets lines in it. I didn't replace all the secondary caps, so another voltage might still be problematic, or the values I used are too far off.
I've been on mouser and digikey but the options are a bit overwhelming. I just need some new ones that will work. They don't need to be top quality,...-
- Loading...
