Should I recap this unit?? FSP 350w
  • c_hegge
    • Sep 2009
    • 5219
    Re: Should I recap this unit?? FSP 350w
    Originally posted by stj
    specaially those japanese caps that the site says are made in malasia...
    Panny are made in malaysia. Even known good stores like RS components say that.
    Edit: If you would rather get them from RS then here you go
    http://australia.rs-online.com/web/s...duct&R=0571656
    • jackywhatever
      • Jun 2010
      • 18
      Hi I would like to post another question:
      I recapped another unit (the FSP was in use so I turned to a Delta 350W APFC unit)
      Most output caps were Ltec and replaced with Samxon with all same capacitance and voltage, not most are high temp/long life capacitors, due to limited availability
      450v 220u Samxon LP ------ left as it
      35v 220u some cheap capacitor, can't recognize --> Samxon GT high temp/long life
      25v 470u some cheap capacitor, can't recognize --> NCC LXG high temp/long life
      16v 2200u x2 Ltec --> Samxon GT high temp/long life
      16v 1500u Rubycon YXG ------ left as it
      10v 3300u Ltec--> Samxon RS high temp/long life (not as long as samxon GT though)
      10v 1500u Ltec--> Samxon GC ultra low ESR
      10v 1000u Ltec--> Samxon GT
      6.3 3300u Ltec x2 --> Samxon GA ultra low ESR
      Result:
      the unit turned out running cooler.
      Did NOT give any improvement in overclocking
      3.3v reads 3.38 stable, 5v reads 5.01 rock stable, 12v reads 11.79~11.80 go back and fro every half second. Am I getting a problem here?
      • 370forlife
        Large Marge
        • Aug 2008
        • 3113
        Doesn't look like any problem, but it's just a consumer grade delta. Will do it's job but your not going to be able to OC much.
        • jackywhatever
          • Jun 2010
          • 18
          before recap the 12v rail didn't go up and down that much
          Is it because of the voltage now sit right between 11.79/11.8 or because I am getting more ripple by now?
          • 370forlife
            Large Marge
            • Aug 2008
            • 3113
            Ripple happens so fast you can't measure it with a DMM. Just wiggly voltages.
            • uligli
              • Aug 2006
              • 139
              #26
              Those are okay for the psu, and is normal it runs cool because of low power consumption, recap them when its needed ( may in 3 - 4 years )
              • bauto601
                KDM 480W PSU upgrade succes! (opinions?)
                by bauto601
                Back in 2020 i bought a (2nd hand) compact ATX psu to replace my current one. My PC case only fits very short ATX power supplies so i didn't really have the choice of buying a decent 80Plus unit. The current unit is a modded YoungYear unit that i made a thread about a while ago:
                A "nice" YoungYear unit? - Badcaps
                The "new" unit is a KDM-M6480 480W psu, the 480W number is a typical KDM bullshit claim of course, but the 24A rating on the 12V rail seemed reasonable and the "Active PFC" claim gave me a bit of hope that this was going to be decent-ish....
                12-26-2023, 03:05 PM
              • ngml
                Repair of an LG split AC system indoor unit PCB
                by ngml
                I am trying to repair an LG split AC indoor unit, which does not start and gives a CH05 error code.
                This indicates an error in the communication between the outdoor and the indoor unit.
                The outdoor unit is fine, so the problem is the indoor PCB.
                The indoor unit is an LG PC09SQ NSJ (3SNM09JA2FA), and the PCB has the following type number: EAX35907219-1.2 (see photo1)
                I changed optocouplers ICO1X & ICO2X and the NPN transistor S9013 which drives optocoupler ICO2X (see photo2), but this did not remedy the fault.
                Does anybody have the schematics of this board,...
                02-01-2025, 12:55 PM
                by momaka
                03-15-2023, 10:17 PM
              • CoinCoin88
                Garage door RX unit (Cardin S38C) does not short relay to send opening signal
                by CoinCoin88
                I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
                Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver...
                09-15-2025, 03:36 AM
              • DrDos
                Unit runs but no speaker output kenwood KR-6030
                by DrDos
                I have finished my work. The new lights come on except the one for stereo, I reversed the bulbs to no affect, anyway, the unit powers on, relay clicks. I have no DC voltage in speaker outputs, I also do not have any AC in the speaker outputs. There is some faint crackling in the speaker. This unit cranks up loud so I had the volume on very low. Everything seems to be fine but I can't really check the switch until I can get sound out of the outputs. I was going to do caps for the power supplys and the tone board but thought if it was cranking loud at one time maybe just leave it alone until it...
                09-14-2025, 09:57 PM
