Should I recap this unit?? FSP 350w
  • jackywhatever
    • Jun 2010
    • 18
    I would like to recap this power supply as I use this on a computer for music reproduction.
    How would you rate this PS at the first place?
    Should I change some or all of these caps?
    OST 200v 470u x2
    OST 16v 3300u
    Teapo 10v 2200u x5
    Teapo 10v 1000u
    some more but all under 100u, mostly teapo as well
    By the way all of these caps are not very good... surprisingly though the PS runs very cool, um
  • Per Hansson
    • Jul 2005
    • 5895
    • Sweden
    Re: Should I recap this unit?? FSP 350w
    Teapo and OST are usually fine for powersupply duty so long as the fan spins somewhat decently (so it does not get too warm in there)
    Unless you have identified caps as starting to fail I would just leave it alone
    It looks like a decent PSU to me
    • jackywhatever
      • Jun 2010
      • 18
      Thank you for your input.
      Will changing caps end up giving
      1. more stable voltage (minimizing spikes) or
      2. make the PS run at lower temperature?
      • Per Hansson
        • Jul 2005
        • 5895
        • Sweden
        If the capacitors have started to fail then yes it will improve the stability and reduce the operating temperature
        However if they are fine there will be no difference
        (Might even get worse depending on how well matched the new caps are to the PSU's Pi Filters etc)
        • jackywhatever
          • Jun 2010
          • 18
          thank you, it sounds like I can live with it for many more years, which is great
          I even tried to touch the small-ish heatsink inside the PS after having the computer on for a day. Still cool and safe to touch
          • Per Hansson
            • Jul 2005
            • 5895
            • Sweden
            Ok, with the power off I presume
            Be aware that in most powersupplies the primary heatsink (the one you did not touch per your explanation) is live at AC voltage!
            (Yea, before you ask I found out the hard way...)
            • jackywhatever
              • Jun 2010
              • 18
              argh... thanks for reminding
              just wondering, per my limited knowledge on caps, those caps used to smooth output current are mostly over 1000uf. what do the smaller caps do (those under 100uf)? for control circuits?
              • mockingbird
                • Dec 2008
                • 5484
                Is that an FSP 350-60THN or a 350-PN/B?
                • etnietering
                  • Apr 2009
                  • 379
                  You are correct. The large caps are for filtering the output voltages, and the small ones are for control/timing/whatever. Most of the time...in this power supply I had a 47uF cap in parallel with a 2200uF cap on the 12v line.
                  If/when you end up recapping this, you should replace the small caps too. If they go bad the voltages can go way way out of spec and toast motherboards and hard drives and everything else.
                  • jackywhatever
                    • Jun 2010
                    • 18
                    it says only ATX350F on its case, it's a fairly aged unit
                    thank you for your input.
                    I have two other PS units that runs quite hot and over-voltage (e.g 12V at 12.3V)
                    Should I replace all of these caps to new same value caps or I should go for larger uf?
                    200v 820u x2
                    16v 2200
                    16v 470 x2
                    10v 2200 x3
                    6.3 4700 x2
                    all Su'sscon (spelling maybe off)
                    In a PS, should I go for longer life caps or lower ESR caps?
                    2000 hrs enough for a PS?
                    is 105C a minimum?
                    • Per Hansson
                      • Jul 2005
                      • 5895
                      • Sweden
                      All decent caps are rated for 105°C
                      For PSU usage it would be preferable to aim for longer life vs lower ripple
                      That being said many (including me) use caps that are "intended" for CPU VRM usage in powersupplies and it works fine too...
                      But as I said before it is important to stay atleast reasonably close to the original caps spec, since that is what the whole Pi Filter is tuned for (otherwise you could end up with more ripple when using a capacitor that in reality has much better ESR rating for example)
                      Su'sscon (spelling) are known crap, I would replace those
                      The large input filtering cap(s) can generally be left alone, because they don't operate under as harsh conditions as the secondary side, so they are generally fine (Unless you do use them in a place with very poor incoming line voltage of course)
                        • 31254
                        panasonic's new FK series look good!
                        • jackywhatever
                          • Jun 2010
                          • 18
                          Do you mean the 200v+ ones?
                          • Per Hansson
                            • Jul 2005
                            • 5895
                            • Sweden
                            Yes
                            • Scenic
                              o.O
                              • Sep 2007
                              • 2642
                              those are new? o_O
                              http://cgi.ebay.com/290416806311
                                • 31254
                                i would never buy caps off ebay!
                                specaially those japanese caps that the site says are made in malasia and ship from HK!
                                • Behemot
                                  • 4845
                                  • CZ
                                  I've seen several unit of this age, most of them were almost identicall no matter how they was labeled. But interesting are these small heatsinks in your piece.
                                  I'm maybe little bit paranoid, but I recap everything I can just for the feeling everything is and will be allright much much longer than with these crap caps. Also overclocking is better with recaped PSU
                                  • Scenic
                                    o.O
                                    • Sep 2007
                                    • 2642
                                    that store i linked to above is one of the very few that only sells genuine caps. he's aware of the fakes.. talked to him a lot via ebay PM's..
                                    • jackywhatever
                                      • Jun 2010
                                      • 18
                                      is it a nice idea to increase capacitance on the output side of the PS? google did not give me a definite answer.
                                      my understanding so far is,
                                      1. increasing capacitance will help with ripple, but decreasing the speed of a cycle. does that matter at all in a PS?
                                      2. increaseing capacitance may induce more instantaneous load to the PS. due to higher surge at startup. Is that true and how bad it is?
                                      2. let's say a PS is fine on ripple, but constantly giving lower/higher than desired voltages. Can this be solved by the mean of recap? What's the strategy?
                                      • 370forlife
                                        Large Marge
                                        • Aug 2008
                                        • 3113
                                        I frequently increase the capacitance on any psu's I repair. Capacitance may not help much with ripple, that has to do more with ESR and the PI filters. On a ps you don't want to stray too far from the ESR of the original caps as the pi filters are "tuned" in a way to the ESR of the caps and increasing or decreasing the ESR can increase ripple. More capacitance can help with transient response and may help voltage regulation, that also can be helped by using higher capacity schottky diodes.
                                        • bauto601
                                          KDM 480W PSU upgrade succes! (opinions?)
                                          by bauto601
                                          Back in 2020 i bought a (2nd hand) compact ATX psu to replace my current one. My PC case only fits very short ATX power supplies so i didn't really have the choice of buying a decent 80Plus unit. The current unit is a modded YoungYear unit that i made a thread about a while ago:
                                          A "nice" YoungYear unit? - Badcaps
                                          The "new" unit is a KDM-M6480 480W psu, the 480W number is a typical KDM bullshit claim of course, but the 24A rating on the 12V rail seemed reasonable and the "Active PFC" claim gave me a bit of hope that this was going to be decent-ish....
                                          12-26-2023, 03:05 PM
                                        • ngml
                                          Repair of an LG split AC system indoor unit PCB
                                          by ngml
                                          I am trying to repair an LG split AC indoor unit, which does not start and gives a CH05 error code.
                                          This indicates an error in the communication between the outdoor and the indoor unit.
                                          The outdoor unit is fine, so the problem is the indoor PCB.
                                          The indoor unit is an LG PC09SQ NSJ (3SNM09JA2FA), and the PCB has the following type number: EAX35907219-1.2 (see photo1)
                                          I changed optocouplers ICO1X & ICO2X and the NPN transistor S9013 which drives optocoupler ICO2X (see photo2), but this did not remedy the fault.
                                          Does anybody have the schematics of this board,...
                                          02-01-2025, 12:55 PM
                                          by momaka
                                          03-15-2023, 10:17 PM
                                        • CoinCoin88
                                          Garage door RX unit (Cardin S38C) does not short relay to send opening signal
                                          by CoinCoin88
                                          I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
                                          Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver...
                                          09-15-2025, 03:36 AM
                                        • DrDos
                                          Unit runs but no speaker output kenwood KR-6030
                                          by DrDos
                                          I have finished my work. The new lights come on except the one for stereo, I reversed the bulbs to no affect, anyway, the unit powers on, relay clicks. I have no DC voltage in speaker outputs, I also do not have any AC in the speaker outputs. There is some faint crackling in the speaker. This unit cranks up loud so I had the volume on very low. Everything seems to be fine but I can't really check the switch until I can get sound out of the outputs. I was going to do caps for the power supplys and the tone board but thought if it was cranking loud at one time maybe just leave it alone until it...
                                          09-14-2025, 09:57 PM
