Aerocool cylon 700watt Atx psu
  • Davemack69
    • Mar 2022
    • 38
    • United Kingdom
    Hi
    Trying to find a schematic or info on a 7 pin dip ic that has exploded in my psu.
    One of the fets has also had blown.
    The top of the 7 pin ic has blown off into lower earth orbit so I'm a bit stuck.
    The ic is on the high voltage side of board.
  • Davemack69
    • Mar 2022
    • 38
    • United Kingdom
    Re: Aerocool cylon 700watt Atx psu
    Pin 4 is not connected and pin 7 is missing as far as I can tell.
    • PeteS in CA
      • Aug 2005
      • 3581
      • USA, Unsure of Planet
      I think it's a Tiny Switch type all-in-on regulator. The "missing" pin 7 is probably the spacing between pin 8, the output MOSFET Drain, and pin 6, the Source. Whether it's literally is a Tiny Switch or a similar product, I don't know.
      PeteS in CA
      • lotas
        • Jan 2016
        • 4611
        • Russia
        Dp2358
        • Davemack69
          • Mar 2022
          • 38
          • United Kingdom
          Thank you!
          • lotas
            • Jan 2016
            • 4611
            • Russia
            The first photo shows that they replaced the wrong PWM, it looks like TNY27xPN and turned it over.
            • Davemack69
              • Mar 2022
              • 38
              • United Kingdom
              Your right I guessed and I was wrong.
              I can't seem to find the part you posted picture of to buy anywhere?
              • lotas
                • Jan 2016
                • 4611
                • Russia
                https://aliexpress.ru/item/100500364...archweb201603_
                • Davemack69
                  • Mar 2022
                  • 38
                  • United Kingdom
                  Thanks again got them ordered
                  • lotas
                    • Jan 2016
                    • 4611
                    • Russia
                    Before installing a new PWM, you need to check the entire wiring of this PWM - resistors, diodes, an optocoupler that is connected to it, if some component is not corrected, the power supply will not start or the PWM will explode again. The main thing is that the standby transformer would not suffer (interturn short circuit of the primary winding).
                    • Davemack69
                      • Mar 2022
                      • 38
                      • United Kingdom
                      I've taken the exploded pmw driver back off board and the resistor which is open circuit I'll desolder diodes and check them next. how can I test optocoupler operation?
                      • Davemack69
                        • Mar 2022
                        • 38
                        • United Kingdom
                        aerocool cylon 700w Zener diode identification
                        hi i have a zener zener marked c24 also t5 any one any idea of its value as its blown open circuit?
                        I have removed it from board to test.
                        It's out of a aerocool cylon 700w power supply I think it to do with a ic that exploded I belive for 5vsb.
                        • R_J
                          • 9547
                          Re: Zener diode identification
                          Post a clear picture of the component, What case style? Are you sure it is a zener diode?
                          • Davemack69
                            • Mar 2022
                            • 38
                            • United Kingdom
                            Its marked z02 on p.c.b
                            • lotas
                              • Jan 2016
                              • 4611
                              • Russia
                              "C24" - bzx79-c24 (ZD-24V-500mW).
                              https://projectpoint.in/index.php?ro...d=502038390712
                              • cmlewis89
                                LG 47LB5DF blown power supply board
                                by cmlewis89
                                Hi folks,
                                I'm new to this forum. So my trusty 17-year-old LG 47" LCD recently died. As I was booting it up, I heard a hum followed by a loud bang, sounds of pieces flying around, and loss of power to the unit. Inspecting the PSU, I saw two obvious problems: a blown thermistor (bang + flung pieces) and a visibly bulging main cap. Inspecting as many components as I could with my Fluke MM, I diagnosed that the following components on the "hot side" of the board were also bad: one of the 2 main MOSFETs, main 8A fuse, small cap (25V 47uF) connected to main caps, and a blown...
                                09-03-2024, 07:50 PM
                              • drscoot
                                HP X360 convertible battery blown fuse error, not charging
                                by drscoot
                                HP Modelnumber: 14-dh0061nb​
                                This laptop had a shorted cap on a Vcore section. After replacement is works again. But there is still a battery issue.
                                The battery is HT03XL and with the built-in component test from HP, in the Power section, I get an error: Logic State: Calibration required (20), Charge state: Blown Fuse (42)
                                I have another same battery, also with error: Logic State: Very Weak (70), Charge state: Blown Fuse (42)
                                And a third battery TF03XL (looks identical) with error: Logic State: OK (0), Charge state: Blown Fuse (42)
                                All these 3 batteries are charging...
                                12-15-2023, 05:54 AM
                              • swerg
                                Part selection for possible blown inductor on ASUS GX531-GW-AB76 laptop mobo
                                by swerg
                                Hey everyone,
                                I'm a novice trying to repair my laptop. The LCD screen has an image, but no LED backlight for the image. It also produces an image when connected to an external monitor.
                                I have found what I believe to be a blown inductor labeled "L4502" and "120 Ohm" in the schematics (zoomed in image, blue arrow to blown component). I have included an image of the general area of the mobo and an excerpt from the schematics as well.
                                I am having trouble selecting a replacement component, which I believe to be a 120 Ohm ferrite bead, from the components...
                                06-06-2024, 03:39 PM
                              • MrzPdlch
                                Blown fuses on Gigabyte GTX 980TI 6GB
                                by MrzPdlch
                                Hey everyone,
                                I just went ahead and unscrewed a faulty GTX 980 TI from Gigabyte. What I found beneath the cooler was, as it seems, a common issue of that card. Two blown fuses on the bottom right corner of the card next to a MOSFET.
                                Now my question would be if there is any schematics of that card available to figure out which are the blown components so I can try and replace them together with the mosfet if needed.
                                Find some pictures of the actual GPU together with a picture of how it should look like.
                                I also wonder whther it might be a problem that there...
                                03-10-2024, 04:14 PM
                              • cheeky2
                                Samsung BN44-00262A H37F1-9SS power supply help finding blown value components!
                                by cheeky2
                                This Samsung combined power supply and inverter was replaced a while ago from a Samsung 37inch LE37B530P7W TV. However I would like to repair this one.
                                I have replaced the Mosfets Q1820 and Q1821 ( FDPF7N50U) which were both blown and the fuse FM802S. The schematic for this power supply that is attached doesn't relate to this power supply as the driving transistors and diodes are D1830, D1831, D1832, D1833, Q1811 & Q1810 are nowhere on the schematic!
                                Does anyone know what the components for D1830, D1831, D1832, D1833, Q1811 & Q1810 should be? I ask as I did change the Mosfets...
                                06-15-2025, 05:12 AM
