double lugged molex wiring
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    ok, i have a couple ultra V 500w units, brand new. other than a bad choice of lytics, they are fine in every way:
    lots of coils, x/y caps, proper bridge, decent heatsinks and parts on them, good transformers, decent wire...
    BUT- the wires going to the molex/sata connectors are double lugged- about an inch of 16AWG, then inline spliced to 2 18AWG lines for drives. PCI-E, 20+4 atx, and p4 conntions are not doulbe lugged.
    i am a bit concerned about it, i doubt there is room to try to straight-wire them to the pcb... i could try in a last resort.
    is double lugged ok or should i try to cram the wiring in the pcb holes, or should i scrap it?
    edit- there are open holes... WHY did they double lug it?
    edit2- i will likely fix the issue when i eventually get to recapping them.
    sigpic
    (Insert witty quote here)
  • 370forlife
    Large Marge
    • Aug 2008
    • 3112
    Re: double lugged molex wiring
    As long as it's not double lugged into a real high current wire like 1 18ga into three 18ga's for the pci-e, it should be fine.
    16ga into multiple 18ga's for the molex and sata isn't a big deal.
    • ratdude747
      Black Sheep
      • Nov 2008
      • 17136
      ill fix it anyway... why not?
      sigpic
      • ratdude747
        Black Sheep
        • Nov 2008
        • 17136
        ok, i was able to fix one of them, and i was able to do a nearly full recap:
        280uf jee primarys---> 680uf chhemicon primaries
        bye-bye 240/120 switch, jumpered for 115v
        removed all double and a few triple lugs (the singles that recieved the lugs was 18awg, not 16awg, so they needed to go bye-bye)---> every wire has its own solder hole
        got all secondary caps worth recapping execpt for 2 of the 4 680uf 16v caps, those i will replace later.
        it should be a lot better now. i shall test it.
        sigpic
        • ratdude747
          Black Sheep
          • Nov 2008
          • 17136
          got it running, i also forgot to say that i swapped the 4 pin 12v to a better quality connector with beefier wire. running fine so far, i'll have to order caps to finish the recap..
          sigpic
          • ratdude747
            Black Sheep
            • Nov 2008
            • 17136
            ultra V 500w
            still running great... powering my socket 939 dualcore gaming box right now..
            sigpic
            • Rulycat
              • Apr 2010
              • 724
              • United Kingdom
              Does better wiring (and therefore less resistance) improve the efficiency by any measurable amount ratdude?
              • ratdude747
                Black Sheep
                • Nov 2008
                • 17136
                yes... that way it can deliver the power it's capable of.
                sigpic
                • Wizard
                  • Mar 2008
                  • 2296
                  Yes, all the more vital on 5V design. This is major reason Intel specified 12V for less current and therefore cut down on power losses. High end machine even use 24V.
                  Cheers, Wizard
                  • ratdude747
                    Black Sheep
                    • Nov 2008
                    • 17136
                    next week ill post before and after pics. the second unit is unmodded right now... i may fix it as well someday.
                    sigpic
                    • howardc64
                      by howardc64
                      Problem
                      08-04-2024, 10:36 PM
                    • howardc64
                      TCL 49S405 double image
                      by howardc64
                      LCD displays a 2nd image slighty offset vertically. And multiple pairs of black lines along the bottom. Probably common as google "TCL 49S405 double image" pulls up this ifixit post ( link ) with identical ( nearly, but their fault seems to be on the other half of the panel than mine ) problem without solution.
                      This one looks to be a more difficult to diagnose because most? of TCON seems integrated ( CSOT BGA on buffer baord) into the left panel edge board ( looking from rear of TV) There are 2 buffer boards for each 1/2 of the screen. Main connects to the left buffer board...
                      06-23-2025, 03:20 PM
                      by momaka
                      03-15-2023, 10:17 PM
                    • Cornito
                      Samsung UE55RU8000 reboot and then double image after heating up
                      by Cornito
                      Hello team,
                      I'm back with another tv and another problem.
                      I try to improve my knowledge on fixing TV, and all technics used until now are not fixing correctly the problem.
                      First, reboot issue, I use tape Method to find out the right side that cases the issue.
                      Then using this it's working for quite 1hour30, then at some point of time the image became double on the bottom for half the screen.
                      Then double image reduce in height and move to the top.
                      The image is like folded on around 1cm and the bottom has been moved to the top by 1cm.
                      When I...
                      03-31-2024, 01:37 PM
                    • Xristakis795
                      le40b530w colour problem and double letters
                      by Xristakis795
                      hi to all on the above model i have solarized picture and double letters
                      it uses tcon board FHD60C4LV1.1
                      i think as about as the double letters maby the problem is the same display
                      but as about as the colours it likes as solarized picture
                      i look to find the schematic for the above tcon card without success
                      has anybody measure the voltages from the above tcon card to advice me how can i measure the gamma voltages ?
                      thanks on advance
                      07-10-2023, 02:31 PM
