TNY27x thermal shutdown issues
  • pavithra_uk
    • Nov 2010
    • 45
    Few years ago I found a PSU (Delta, 500W) that works fine few minutes and then turn off itself. later I found that standby 5V (and ~12V to controller) ic TNY279 overheats and then shut down. replaced with new one and problem solved.
    and I found few other PSUs with same problem. two mobile USB power packs too. all these had TNY278, 279
    Anyone here had similar experience ?
    How these chips fail such a way? looks like internal mosfet on resistance increase or current sense element failure..
    • Jul 2011
    • 6069
    Re: TNY27x thermal shutdown issues
    I have replaced a few of them myself I think they might just be over stressed and just fail
    • limo
      • Jan 2021
      • 5
      • P
      While main competitors like ST or Fairchild or Linear have different package which require PCB thermal pads / vias on PCB to dissipate heat the top line TNY290PG claim 36W in SO-8 package (magic!). Conclusion is yours.
      • PeteS in CA
        • Aug 2005
        • 3581
        • USA, Unsure of Planet
        Ummmmm ... is Power Integrations claiming their TNY290PG will dissipate 36 watts? Or are they claiming it can, with appropriate circuitry, produce 36 watts of output power? I think this is a, "To ask is to answer," situation.
        Power Integrations has been around for at least 25 or 30 years. They aren't fly-by-night flakes.
        PeteS in CA
        • DriversScrew
          • Dec 2021
          • 32
          Found the TNY279PN faulty in a 580W bq atx power supply. Generating the 5VST. First checked all electrolytic caps and desoldered many other parts.
          The power supply only works for about half a minute with all voltages ok. Then shutting down and after one more minute it is ready again.
          Finally I had the chance to look at the ps with a thermal cam and could clearly see the TNY (half under heat sink) heating up until about 85°C. Then it shuts itself down and when cooled to around 50°C it comes back on...
          I will look for a replacement part but it seems not the best solution in a ps like this to me.
          • redwire
            • Dec 2010
            • 3912
            +5VSB is running 24/7 constantly and every year is 8,760 hours. The Power Integrations TNY appear to age. The power mosfet inside seems to fade away and have high on-resistance and heat generation.
            • CapLeaker
              Leaking Member
              • Dec 2014
              • 8339
              All the TNY27x I come across had their lids blown off…
              • DriversScrew
                • Dec 2021
                • 32
                Short update:
                After replacing the TNY, the psu is running fine.
                The new TNY279PN isn't warming up at all.
                • Gcnewbie
                  Dell Latitude 5570 Ambient thermal sensor reading -127 Degrees C
                  by Gcnewbie
                  Forgive me this is my first request for help on this forum, so if i've screwed up or not followed the rules i should have i apologise profusely.
                  I have a Dell Latitude 5570 that was randomly shutting down, on further investigation i found that the machine had been shutting down due to thermal events as noted by windows event viewer.
                  My investigations lead me to the dell diagnostics screen, where i found that there were two sensors out of range which had been causing the shutdowns, one of which was the GPU thermal sensor and the other the ambient sensor.
                  I opened the...
                  03-29-2024, 06:55 AM
                • Veyron7887
                  Laptop overheating after replacement thermal paste
                  by Veyron7887
                  Hi. I have Asus X55C laptop from year 2013. It has i3-2328M CPU. I replaced stock thermal paste with high quality thermal paste. Before thermal paste replacement, I measured CPU temperature Around 65-70 degrees Celcius with stock thermal paste. If after the replace thermal paste, I measured CPU temperature around 80-84 degrees Celcius and fan don't stop when system is idle. I replaced the thermal paste several times but still did not change. Where is the problem?
                  11-24-2024, 05:08 AM
                • m1ch43lzm
                  by m1ch43lzm
                  05-12-2025, 08:37 PM
                • ajvpb
                  Denon AVR-S740H thermal shutdown help
                  by ajvpb
                  The culprit - A new to me Denon AVR-S740H. Protection history shows 60 instances of thermal detector (A) shutdown.
                  Powering it up for a few minutes and it gets noticeably warm on the bottom of the case where the +12, -12, +5 voltage regulators are. After 20 minutes I would call it hot, and approaching too hot to keep your hand on that part of the case. So the thermal detection is doing its job and not tripping erroneously.
                  The heat is clearly coming from the small voltage regulators that use the case as a heat sink. It has a bridge rectifier that converts the AC...
                  12-18-2020, 10:25 AM
                • gretti
                  MSI Z370-A Pro, works but does not power off or reboot and USB issues
                  by gretti
                  I have a MSI Z370-A Pro. The board does not reboot or shut down from the Windows recovery console. USB communications stop and the status light on USB 1 stays on and does not blink. I have programmed a new BIOS with a CH341A programmer already, swapped RAM, PSU, CPU. The board will power off when the power button is held and resets when the reset switch is pressed, but it will not react to the reset switch if already told by software to shut down or restart. The board will reboot from BIOS after a save and exit command.
                  The MSI BIOS included the ME firmware for the board. The size...
                  10-16-2025, 02:14 AM
