Antec Earthwatts 650W
  • Colt45ws
    • Jan 2009
    • 174
    Dead after exactly 3 months of service. Not even 5VSB. It was in my Mom's machine the whole time which isnt a screamer.
    Just for reference:
    AMD Athlon 64X2 6400+ 3.2GHz (Windsor)
    Gigabyte MA770-UD3
    4x 1GB GEIL Dragon DDR2-1066 (Running DDR2-800)
    Diamond ATi HD3870 512MB
    Pioneer DVD-/+(R)W[DL] SATA
    WD Caviar Black 750GB
    I installed my spare Cooler Master UCP 700W and its running again.
  • 370forlife
    Large Marge
    • Aug 2008
    • 3112
    Re: Antec Earthwatts 650W
    Warranty time. This is a delta, so even with lower grade Ltecs or taicon's I still wouldn't expect a failure to be cap related as I have lots of delta's with solid 10 years of constant service in poorly ventilated computers with ltecs and taicons that run great.
    • c_hegge
      • Sep 2009
      • 5219
      IIRC Earthwatts are Seasonic OEM, full of OST.
      • Colt45ws
        • Jan 2009
        • 174
        No its a delta, like the JG review sample. Samxon primarys with a grab bag for the rest. I know its wild mass guessing but what would make it fail like this. Its like the fuse is blown.
        • Rulycat
          • Apr 2010
          • 724
          Earthwatts started off as Seasonic but later the OEM was changed to Delta.
          • 370forlife
            Large Marge
            • Aug 2008
            • 3112
            I wouldn't crack it open, I would just put through an RMA. Sounds like an unusual failure, replacement should be fine.
            • seanc
              • Nov 2008
              • 1319
              Not sure about the newer Earthwatts, but the EA-380 are full of OST (sometimes a few Teapo) and usually the reason for total failure.
              I opened my 3 yr old Seasonic S12 500w the other week, the internal layout is identical to the EA-380s I've been repairing, but it's using much better caps, there's even a poly cap in there.
              • 370forlife
                Large Marge
                • Aug 2008
                • 3112
                http://www.jonnyguru.com/modules.php...tory3&reid=110
                Delta, and that review was over a year ago.
                • seanc
                  • Nov 2008
                  • 1319
                  Fair enough, they look well built.
                  • Krankshaft
                    • Jan 2007
                    • 2328
                    Wow I've been using mine since December cracked it open to check the caps they used Chemicons on the stressed rails and Ltecs on the others.
                    I also replaced the noisy Adda fan with a low speed Yate loon. Unfortunately the fan isn't speed controlled by temperature (doesn't use 3rd wire) so its running full speed all the time. Luckily for me the YL fan is quiet at full speed.
                    I'd RMA it sounds like infant mortality (manufacturing defect) to me either that or you got hit by a power surge.
                    • 370forlife
                      Large Marge
                      • Aug 2008
                      • 3112
                      There's a temperature sensor, the fan speed is controlled directly by temp. Most power supplies use this.
                      • Krankshaft
                        • Jan 2007
                        • 2328
                        So it's controlled by PWM and they don't use the 3rd RPM wire?
                        Guess the temperature is the only feedback.
                        • 370forlife
                          Large Marge
                          • Aug 2008
                          • 3112
                          No PWM, one of the monitoring IC's also monitors temperature and adjusts fan voltage accordingly.
                          • Krankshaft
                            • Jan 2007
                            • 2328
                            Ah linear regulation got it.
                            • seanc
                              • Nov 2008
                              • 1319
                              Heads up, Antec has been playing with their OEMs. The EA-380 PSUs don't look like Seasonic builds any more.
                              Looking through the grill, primary cap is a single Samxon, cables are shorter and fewer, with different connectors all placed onto one cable, rather than having one for SATA, one for molex etc. Board isn't stamped ATX 400W rev 5, there's usually a 2200uf 16v cap visible through the back, it's not there. They're rated bronze in the 80+ certification - the old ones may be too, the boxes don't specify.
                              Also, the casing is now army green, they're coming pre-installed in Antec NSK3480 - which we've been buying for years.
                              I'll see if I can get any more details off of the labels tomorrow.
                              • 370forlife
                                Large Marge
                                • Aug 2008
                                • 3112
                                Probably delta. Antec seems to slowly be moving their low-medium range to delta now.
                                • seanc
                                  • Nov 2008
                                  • 1319
                                  370 - Confirmed by Antec Europe.
                                  • sirpsychol
                                    Antec Earthwatts EA-380 smd element type/value
                                    by sirpsychol
                                    While recaping Antec Earthwatts EA-380 I've broke one side of unknown smd element, it have no print, it's flatter and darker than smd capacitors on this board, shaped more like resistor but it's not resistor ofc. Unfortunetly the printed description was under it and element was glued to the board so I cant read/tell the letter before element number too. Have anyone any idea what it is? Maybe is there any diagram of this PSU?
                                    09-03-2023, 07:58 PM
                                  • ajdrenter
                                    Picking caps for Antec SU-380
                                    by ajdrenter
                                    In my search for a proper 5v heavy ATX power supply, I selected an old Antec SU-380 that I've had in storage for a long time. Opening the power supply reveals a couple bulged capacitors. I removed all the caps and made a map for myself. I found the datasheet for the PCE TUR series in this thread:
                                    https://www.badcaps.net/forum/showthread.php?t=14159
                                    It says these are general purpose, so I assume I can replace them with any general purpose capacitors, but I don't really know anything about power supply circuits or reading capacitor datasheets. Despite this, I've been shopping for replacements:...
                                    05-13-2023, 10:40 AM
                                  • CWEastwood
                                    Antec Smart Power SL300S capacitor replacement.
                                    by CWEastwood
                                    I'm currentlly in the process of trying my first power supply repair (really my first soldering project) and have some questions with regard to which capacitors to replace the bad ones.
                                    The power supply is an Antec Smart Power SL300S ATX12V 300 watt.
                                    I have successfully desoldered every capacitor from the board without destroying anything (I think) and I am currently in the process of choosing which caps to order. This is where I'd like a little community wisdom.
                                    Now the capacitors inside are mostly Fuhjyyus (a forum favorite) with 1...
                                    03-25-2023, 12:18 PM
                                  • ratdude747
                                    Building a gaming rig for my dad...
                                    by ratdude747
                                    Have a good story for y'all.
                                    My dad has been wanting me to build him a gaming rig... nothing too crazy, just something that can run Sufferfest and Zwift (both are electronic bike trainer games) well while streaming (he's on a few teams... at age 64 no less!). A back burner project due to all the other stuff I have going on.
                                    Anyway, a coworker approached me with their teenage son's dead gaming rig... no POST, wanted me to troubleshoot it. Took it on (out of morbid curiousity more than anything)... oh boy, what a POS. This thing is clearly a bargain basement build......
                                    02-26-2021, 09:34 PM
                                  • Solvik
                                    XFX XPS 650w 3XS PSU making Ticking/clicking sound
                                    by Solvik
                                    Hello
                                    i have a older powersupply from XFX that makes this wierd electronic ticking /clicking noise. Its not the fan thats making the sound. See video below. Is anyone familiar with what component this sound can come from?
                                    All voltages are normal....
                                    02-13-2025, 02:43 PM
