Old Fortron FSP250-60GTM
  • Behemot
    • 4845
    • CZ
    Re: Old Fortron FSP250-60GTM
    I used KZG's for output and KMG's for small capacities. Two 330uF KZG's used for output, too (for -12 and so). As I said, I'll watch them from time to time and maybe sometimes borow ESR meter...
    • c_hegge
      • Sep 2009
      • 5219
      They may be OK for now, as long as they are cooled well enough. Just keep an eye on them
      • Behemot
        • 4845
        • CZ
        Yeah the fly resistor mod should keep them cool...
        I even mounted the resistors on main heatsink in the second Fortron today (the FSP-300GT one), this one has fan controller and they would burn comonents around them with fan in slow mode.
          master hoarder
          • May 2008
          • 12175
          Originally posted by Behemot
          I applied the glue on top of the coil, I won't be able to get it under it, it's impossible
          That should be fine then .
          The sound is coming from the PSU only when it's turned on and it varies according to load. That's what leads me to main transformer.
          I think you might be right then. I re-read you first post and noticed that you said the PSU whistled even before the recap.
          I get exactly the same 5.22 volts even when the PSU powers the motherboard. And yes, as I wrote, I replaced every single one electrolytic capacitor.
          That's strange. Changing the critical cap on 5vsb *usually* makes the voltage normal. Samxon RS and Chemicon KMG are good choices for the small caps too. You said it was 3.6v before the recap, correct? I'd definitely look into it. A faulty 5vsb can kill a motherboard. Just search for Bestec ATX-250 12E on here if you need examples .
          As for the caps, I believe ESR is not the problem - e.g. Samxons RS have much lower ESR and they are actually meant for power supplies. Are not caps in PSU's almost only low-ESR ones anyway? I've been quiet surprised when I saw recommendations of caps which usually are in VRM's on motherboards as a replace for failed caps in PSU's.
          Samxon RS are actually an excellent choice for PSUs since they are low ESR, but not too low. On the othe hand, Rubycon MBZ/MCZ, Chemicon KZG, and Nichicon HM/HN/HZ have really low ESR and shouldn't be used in PSUs. I know that some people here have done it with no problems, but PSU output circuits are tuned to a certain frequency, so generally it's not a good idea to deviate from the ESR of the original caps (unless of course the original caps were not adequate in the first place, such as what you might find in a really cheap PSU).
          On the top of all, I'll let the KMG's there and see...there are definitelly better than bulged OST's and Teapo's now, aren't they?
          Absolutely.
          once again, what was the reason for them to fail, they did not handle the heat or even the ripple?
          Heat more likely. This is how I got a few good PSUs - their fan seized and the caps bulged .
          Well, maybe I won't use the PSU to one of my normal computers...maybe I'll keep it for running in oil. I plan it for quite some time now
          That would be interesting. Maybe even run the whole computer in mineral oil. I've seen people do it. If you put a Pentium 4 Prescott, you can even use it as a frier .
          • tartuf
            PSU: Seasonic G360 and Fortron FSP-350GLN
            by tartuf
            Note, I don't know if it's proper subforum or should I post in PSU one.
            I am looking for schematics for two ATX PSUs: Seasonic G360 and FSP-350GLN.
            01-17-2023, 06:51 PM
          • lordmmx
            Lenovo Thinkbook 15 G4 ABA - LA-M062P motherboard
            by lordmmx
            Hello smart people of Badcaps forum,
            I have this absolute beast on my bench and I'm having a hard times with it.
            Laptop posts fine, goes into windows and behaves normaly. Unless, it gets moved or somehow bent even a little bit - at this point it immediately freezes and screen goes black.
            I tried to search for shorts, cold joints, only issue I have found was cold joint at Usb-c port, that is fixed now.
            I think board may be broken, but laptop is visualy fine, nothing is damaged or indicating that it was dropped.
            here's a video...
            10-08-2025, 07:47 AM
          • BMCappelletti
            Asus XG32V monitor with lines
            by BMCappelletti
            Hello.
            I have here a Asus 32' curved display showing these lines.
            A short clip of what shows when I turn it on.
            https://imgur.com/a/Z8fyqym
            Here are some pictures of the boards. Visualy they seem fine.
            There are lots of videos on Youtube on possible solutions, but I could not find a similar problem with a similar board layout.
            Any help is appreciated.
            Thanx....
            10-08-2023, 07:31 PM
          • sandrabrnelic
            Hisense TV 40A5600F Dead - Wan't start
            by sandrabrnelic
            When powered on LED goes red indicating standby.
            After pressing the power button LED blinks 6 or 7 times, i don't know do i need to count last led blinking because it's faster then previous 6 and remain's lit and in standby again. Nothing is visible on the screen, backlight is off all the time. All caps on board are looking visualy OK. 12V is present. Anyone has service manual or schematic for this TV or any ideas what could 6 blinks code mean.
            Main board is RSAG7.820.9867, power supply is on same board.
            Update: I think backlight is dead because voltage on backlight...
            09-21-2023, 02:48 AM
          • Brainless
            Repairing Fortron Epsilon 600W
            by Brainless
            I want to restore one old PSU. I found the main reason to not working. It was small cap (100uF/25V) on the Vdc bus going to the PWM controller. I replaced the cap with 470uF/25V (don't have currently 100uF) and PSU now works, tested under load with old GPU (ATi HD5830) and Furmark software. The replaced cap doesn't have any external signs of malfunction, even with capacitance meter is value is OK. But with it Vdc bus is ~11V and adding a small value like 4.7uF put the bus right, where it should be ~15.5V.
            What currently doesn't like is the spikes on 12V and 5V buses. Please see...
            02-06-2018, 11:11 AM
