Hisense TV 40A5600F Dead - Wan't start
  • sandrabrnelic
    • Mar 2012
    • 34
    • Croatia
    When powered on LED goes red indicating standby.
    After pressing the power button LED blinks 6 or 7 times, i don't know do i need to count last led blinking because it's faster then previous 6 and remain's lit and in standby again. Nothing is visible on the screen, backlight is off all the time. All caps on board are looking visualy OK. 12V is present. Anyone has service manual or schematic for this TV or any ideas what could 6 blinks code mean.
    Main board is RSAG7.820.9867, power supply is on same board.
    Update: I think backlight is dead because voltage on backlight connector rises to 140V and there is no light and no current through LED's
  • EazyBone
    • Jun 2023
    • 1341
    • United states
    Re: Hisense TV 40A5600F Dead - Wan't start
    I was going to suggest testing the backlights. I had some Hisense do this same code and my problem was backlights. One went out. I use LED tester on mine and it reads as open if they don't light up on my tester. Plus, I've only had Hisense have bad backlights lol
    • etbmikenel
      • Dec 2018
      • 17
      • South Africa
      On Hisense if you bet on backlights or capacitors, you'd win more than you'd lose
      • jesterace
        Samsung UE49MU6400 acts dead until disconnecting backlights, then works.
        by jesterace
        Hi everyone I have this TV which was dead one day when I tried to turn it on. I've had the cover off and there was just a pulsating/electrical clicking/ticking noise from the PSU. I disconnected the mainboard as sometimes this works to just fire it up with backlights on? That didn't help. Same noise. Then I disconnected the backlight cable from the PSU and the TV came alive. It appeared to respond to the remote and i'm pretty sure it's fully operational when there is no backlight connected.
        However, I am in a dilemma.
        I tested the backlight outputs with the lights disconnected...
        10-20-2024, 10:15 AM
      • mecha1166
        XR-77A80K Dead set, red light blinks 8 times. Cannot find error code list.
        by mecha1166
        I have a XR-77A80K here. When plug in & press power, white lindicator light flashes on & off. about 30 seconds later, indicator light flashes 8x red. Checked Sony, Power reset = unplug & plug in. Factory reset involves turning it on, then pressing remote buttons when a picture shows. Well, neither of these "resets" are for a dead set like this. Anyone know what 8 blinks indicates, from the schematic? Thanks!
        07-01-2024, 05:47 PM
      • chris89
        How to fix Hisense 43A6H 4k Google TV - 10 Blinks?
        by chris89
        Hi I replaced the mainboard, the t-con, and wifi, still no dice.
        Any idea on what it could be, causing the tv to not turn on? Just blinking LED light.
        Processor gets hot so I know the Mediatek MT9612 is functional.
        03-15-2025, 06:46 PM
      • Biruslapio
        Panasonic P58V11B 8 and 12 blinks error "fix"
        by Biruslapio
        Bought this TV used not working, panel flashed briefly on power up and it was blinking 8 times, a quick look on SS board revealed a common fault on the 3uF 250V capacitors, C201 to C205 (C1620X in the service manual), the solder joints were all cracked, C201 and C205 pins were darkened and some sparking had occurred on them, C201 was split open and clearly overheated in its last hours, replaced that one and resoldered the others, 8 blinks fixed.
        Also the previous owner broke the antenna connector by taking the TV out of the wall mount forgetting to unplug it, I desoldered the tuner...
        04-13-2021, 07:13 AM
      • htv239
        LG UH8500 Backlight Troubleshooting Help
        by htv239
        I am currently troubleshooting an LG 60UH8500 TV (2016 TV). Any help or suggestions would be appreciated.
        Overall Issue: When TV is turned on, backlights all come on for about 10 seconds, then all go out. There is sound and there is a picture on the display (obviously hard to see without backlights, but it is there).
        What I Have Done So Far: 1) Removed the back TV cover to expose the boards (Power Supply, Tcon, and Main), 2) blew out any dust and cleaned all connections, 3) Noticed that the LED backlights are fed from two separate connectors...
        10-11-2021, 01:53 PM
